Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Fabric softener dispensor does not completely empty
The actual dispensor cup will empty but underneath it does not empty. Is something clogged and how can I clean it? I may have a buildup of pet hair.
I discovered that the risne cup dispenser holder will pull off letting you clean out the inside. Why they don't show this in the manual is beyond me. And by the way, what came out was gross and obviously you need to clean this frequently.
Posted on May 16, 2008
  • bonnetnicole
    bonnetnicole Aug 14, 2012
    and how do you do that ?
The fabric softener drawer does not empty after a washing cycle so how do I solve this
It is normal for some water to remain in the fabric softener dispenser after the wash cycle is complete
Jan 10, 2013 | Washing Machines
Whirlpool duet ghw9100lw2 fabric softener dispenser does not empty. I checked and the drawer is not clogged
I do not know your particular machine but most softener dispensing works in a similar manner.
If you haven't actually removed the whole drawer it is necessary to do so. Some will not come out without releasing some sort of catch. Often this is a lip at the rear middle which requires pressing down as you pull the drawer out. Others have the catch underneath or on the side of the drawer.
Once out remove the cover which is (probably) over the softener bit.There is (probably) a small pipe/tube down which the softener and water should pour. So often this tube is clogged with gunge- a mix of softener and powder. It must be absolutely clear and clean for the mix to escape and empty.
This is well worth checking even if you have washed out the rest of the softener drawer, especially if you have done it 'in'situ'!
I do hope this sorts your problem out.
Good luck,
John C
Feb 12, 2011 | Washing Machines
Fabric softener dispenser fills up with clear water after washing cycle is complete. I do not use fabric softener .
Purchase some fabric softener and place it in its normal location at the beginning of the cycle. At the end of the cycle check to see if fabric softener has been dispensed and whether there is water in the cup.
If the fabric softener is gone, but there is water in the fabric softener cup, then your problem may be with the water valve assembly. The water valve assembly (as one complete unit) has a separate solenoid for hot and cold water temperatures, bleach and fabric softener. The fabric softener solenoid on the water valve assembly could be defective (allowing water to fill the fabric softener cup).
Contact an appliance service company.
Feb 17, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
The detergent dispenser want despense the fabric softner
Hello. This is a common problem due to the fact that fabric softener collects in the dispenser and gums it up. Begin with an empty washing machine. Add two cups of vinegar to the fabric softener dispenser and then run the machine on the maximum water and hottest water setting. Once the cycle is complete check it out. It will be as clean as a new machine. If this treatment didn't completely clean out the dispenser, repeat the cleaning a second time with two more cups of vinegar. regards, Joe
ps - kindly rate my answer as helpful. Thanks.
Feb 10, 2010 | Washing Machines
My Whirlpool calypso top loading washer poured water from underneath, water everywhere, what do I do and how do I do it?? No codes showed up. Thanks for any info. Rose
Sounds like the seals & gaskets have failed. If you removed the wash plate trying to unjam the washer and did not also replace the gasket kit, you may have violated the integrity of the water tight seals. However, sometimes also the fabric softener dispenser especially, gets clogged and may overflow and leak if the tubes are clogged with coagulated fabric softener. As I am writing this, my washer's fabric softener dispenser is clogged and the method I use to clear it has not worked this time - a cup of boiling water to melt the congealed fabric softener. One has to open the top lid (method varies by Calypso model - Whirlpool or Kenmore) to get to the dispenser tubing and reservoir underneath to get things flowing again, and in fact I have a small water leak on the floor where the dispenser overflowed a bit. That you have a leak, if it happens to come from such a clog, at least gives you a sign that your dispenser solenoids are not malfunctioning, requiring replacement of one of the circuit boards.
Apr 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Fabric softner does not empty
I had a similar problem and removed the complete dispenser drawer and washed it in with hot water. The small inner cups for the fabric softener and bleach should be removed and the hot water directed into the small "stand pipes" on the back side of the covers. It appears the fluids in the cups are siphoned out and if the pipes are clogged at the bottom there will be no flow. Also is the plate is not fully seated, the siphon effect is will not work.
Also, my wife said she does not use the cheaper brands of fabric softener anymore because we think that might have caused some of the clogging.
As a side note, if you remove the top of the washer, there is an adjustable dial where you can fine tune the amount of liquid dispenced. You can try adjusting that too. I think my final fix was to clean the back side of the face plates inside the dispenser and ensure they are fully seated to allow the proper siphon effect.
Jan 15, 2009 | Frigidaire GLTF2940ES Front Load Washer
Leaking // bleach/fabric softener dispener isnt emptying
Remove the dispenser cup and clean it. Be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Fabric softener doesn't dispense
Fabric softener dispensers are notorious for getting all gummed up and clogged. Remove the dispenser cup and soak in some hot water to dissolve all residue. While you have the dispenser removed check under the dispenser cap in the agitator for gummy residue as well. Clean with hot water. There should also be an agitator seal cap under the dispenser. Make sure the cap and rubber o-ring are seated properly. Last of all, if the dispenser has a cone shaped cup inside, make sure it is inserted cone-side UP. The cup is designed to allow fabric softener to roll down the sides of it, NOT hold it. I hope this helps.
Apr 09, 2007 | Kenmore 24982 Top Load Washer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
120 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
