Question about LG DLE2514 Electric Dryer
My DLW2514W dryer works for a few minutes and then cuts off. When I try to restart it, even the controls refuse to light up. I find that if I unplug the appliance and then plug it back in, it runs again for a few minutes before conking out. What do you think is happening? Is it a quick fix or do I need to find another dryer?
SOURCE: my envy2 wont charge
After speaking to Verizon's replacement department, I find that this a common problem with the ENV. The charging jack on the bottom of the phone breaks loose on the inside. If you've had your phone less than a year, it's under warranty and they will replace it free....
Posted on Aug 30, 2008
larryyb
  • 291 Answers
SOURCE: LG Gas dryer will not keep heating
sounds like the heat sensor on side of heater pan is bad and needs to be replaced ,,, its mounted on side of pan the flame blows into and has 2 wires plugged onto it / larry
Posted on Dec 12, 2008
MNTECH
  • 1543 Answers
SOURCE: Gas LG dryer works fine,
First, check to see if there is strong air flow out the house at the exterior dryer vent. It is very important to have good air flow for gas dryers. Second, if you do have good air flow and you do get ignition but the burner shuts down quickly and won't relight, the most likely cause is the coils on the gas valve. They heat up when current passes through them and can open up electrically. When they cool down, the process can repeat. The coils for LG gas valves are not available as separate parts. You have to order a complete gas valve, but you can then take the coils off the new valve and swap them out onto the original valve so you don't have to change out the entire valve. If you need instructions on how to get at the gas valve, let me know (with your model number).
Remember, check your air flow first !
Please rate this solution once you have completed your repair. Thanks.
Posted on Dec 13, 2008
frankgant
  • 250 Answers
SOURCE: Kenmore Series 70 Dryer cuts off after a few minutes
The bearings in the motor have probably worn out. Disconnect the motor and take it out of the dryer. See if it turns roughly or not at all by hand. Also try and move the post left to right and up and down and see if there is play in it. It should move very little if at all in those directions and should spin freely if it's good.
Posted on Dec 17, 2008
SOURCE: my dryer operates well but cuts off during operation.
when i put a load of clothes in set the dial and press the start button my dryer does not start, help help
Posted on Jan 30, 2009
Refrigerator will not restart for a very long period of time after power cut.
there may be a faulty capacitor for the compressor motor
I would suggest a technician check it out as it should come back working within minutes of a power cut
there will be a short delay until the pressures even out as compressors have difficulty starting under pressure but you delay is extreme and needs checking out.
Apr 27, 2015 | LG Refrigerators
My gas dryer started beeping intermittantly while not in use. When I went to check on it, the lights for the towel setting were on (which was not even the last setting used). When I pushed the...
I say it depends what its going to cost to repair. I had a dryer that worked twenty years and when I replaced it they told me I would be lucky to get eight to ten years out of a new one. Its a throw away society now days.
Mar 03, 2017 | Whirlpool GGW9868K Gas Dryer
Dryer will run for about 20 minutes then it cuts off.
Are you able to restart the Amana dryer right back up when it shuts down? If you can, there is a short issue. If you have to wait a few minutes and you might even hear a faint click, then it will start, your motor needs replaced.....If Ic an help further, I am here.....
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Amana DLE330RAW Electric Dryer
Kenmore Electric Dryer wont start or runs only occassionally
sound like you have a microcomputer problem / some calls it a even heat board ,,,, it will cause the problems your having / if need help on part contact me and i will see if i can help on part / larryyb
Dec 03, 2008 | Dryers
Kenmore HE 2 Dryer
sounds like the problem is in the user interface(pushbuttons and knobs)check your warranty some models came with 2 yr warranty on electronics
Aug 25, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Duet dryer
look for a button with lock symbol beside it press and hold button 3-5 secs lock light should go out and control resume operating
Aug 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Locked
Sounds like we need to try to reset the system!
Huuum At your service!
Lets try this,
Like with an error code.
This can reset the system if it is electronic!
Unplug the appliance and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Let me know how it works!
Waiting for your reply!
Please remember to leave a appropriate rating when you are done!
Thank You
Huuum
Please remember to leave a rating before you go!
Thank you
Jun 27, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
LG DLE2514 Electric Dryer Logo
22 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
