Question about ASUS P4SP-MX Motherboard
Monitor doesnt switch on
My monitor doesnt switch on when you turn the computer on. the power supply went got a new one, now i got this can anyone help ples...
  • 1 more comment
  • loudplumber May 12, 2008
    will i get a answer or will i have to pay first?
    when i plug the montior in i get no signal, [in to the mobo]. tried an APG CARD, but still no signal computer's fans are running just no bleep,no screen,no signal.
  • Mark Gil
    Mark Gil May 11, 2010
    You're saying that the power of the monitor is not turning on of it just wont open up?
  • 2,351 Answers
Hi loudplumber, I doupt you're monitor functions in the manner you're stating. Does the monitor have a on/off button? If yes than you need to turn on the monitor. Check you're monitor, it will have a seperate power cord (That pluges into a wall AC jack) & a data cord which connects to the PC. If everything is connected correctly as I mentioned you should have a display on you're monitor. If you are not getting display than you're onboard integrated graphics card is not working. To test this you can add an AGP 4x 1.5v only graphics card to you're motherboard.
You can buy an AGP 4x 1.5v video card at this link. (Click on the link).
This video card can run both 8x & 4x. You can tell it supports the 1.5v because there are only two copper connections (Not counting the end locking tail). If the video card you are buying has three copper connectors it is not 1.5v compatible. The 4x video card arena is getting smaller. Mfg's are not making AGP card that much any more.
Have more questions? Please feel free to ask.
Posted on May 12, 2008
  • Mike Peluso
    Mike Peluso May 13, 2008
    I did not mention you have to enter you're bios to set the AGP card to enable. You're manual is a little lacking board. Goto Advanced menu in you're bios & set the AGP card to be seen first. This will automatically disable the onboard VGA.
My monitor hp w1858 wont turn on
Your monitor may have developed a power supply problem since being refurbished
Jul 04, 2013 | HP Refurbished 18.5" Widescreen Monitor...
I have an Acer AL1916W monitor. After the breaker tripped to the room where the computer is located, the monitor will no come on. It's as though it has no power supply. The monitor was not the reason for...
The power supply has been compromised, if you are very lucky the fuse needs to be changed, in order to check this, remove back cover and follow the power cord to the power supply, see if you can find a blown fuse, replace to see if it will power up, if not probably more cost effective to replace monitor.
Jan 03, 2011 | Acer AL1916W 19" LCD Monitor
Blinking blue power light and greenish tint....
Is the monitor still under warranty? (probably only the first 12 months)
Try connecting the monitor to a different desktop/notebook computer, to see if it is fine.
If it is, you have a problem with the video-card in your computer, not a problem with your monitor.
There are "capacitors" inside the monitor, that serve to supply "smooth" and "ripple-free" power to the electronic circuits. If you have "bad" capacitors, they are not doing what they should be doing, which causes the electronics to malfunction.
So, if your monitor is a CRT monitor, it's time to responsibly recycle it, and buy a new one.
If your monitor is an LCD monitor, take it to any TV/video repair shop, and pay them $25 to $50 to "inspect" it, looking for "bad caps". Or, spend that $25 to $50 to buy a new LCD monitor.
May 31, 2010 | eMachines E19T5W 19" Monitor
Asus A7V8X MX SE loooong beeps
It is either a memory issue or the power supply issue....
Try to reset memory modules.....If the machine still beeps after this and there is different memory modules installed try to remove each and boot(switch on) verify if any memory module is faulty.....if this doesnt work try replacing the memory.
If the problem persists try to verify if the power supply is ok.....
Nov 08, 2008 | ASUS A7S8X-MX Motherboard
Balance Monitor
Same exact thing has happened to me. We have determined that the monitor itself is good, but the DC adaptor is what went bad. Now I am on the hunt for the power adapter.
Sep 20, 2006 | Balance CM2017 17" Monitor
When it's turned on, the light on my monitor doesnt show any signal of power supply
I'm assuming that you mean the green indicator light is not on. This could be caused by a host of problems. Assuming that you know the AC receptacle is live by testing with a standard light the next step would be to unplug the unit and remove the back. Check the fuse for continuity. If the fuse is good you have a problem with the power supply or a short which is keeping the power supply from powering up. The most likely culprit is the Horizontal Output Transistor. Unless you are an electronic tech and know how to check this you probably need to take the unit to a shop for further diagnostics and repair.
Jun 22, 2006 | Samsung SyncMaster 753S 17" CRT Monitor
Envision 17" LCD display will not stay on
Seems the N-Channel MOSFET switch in the power supply is the culprit. NTE does not list a replacement part for this, so a sub is necessary (any N-Channel 600V MOSFET in same TO220F case should suffice). I have to look one up for mine.
Jun 21, 2006 | Envision EN-7100e 17" Flat Panel LCD...
ASUS P4SP-MX Motherboard Logo
66 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
