Question about Bissell 35962 Cleanview Bagless Revolution UprightVacuum
Bissell 35962 Cleanview Bagless Revolution Upright Vacuum hose is clogged with sock where hose meets handle attachment. Attempted to use broom handle to push back through suction opening. Sock is compacted. Any home repair advice?
  • 377 Answers
If you have access to a small sink "snake" used to clear clogs in sinks, you might be able to use it to "snag" the sock and pull it out. Needs to be a metal sewer snake so that you can tug on it if and when it snags the sock.
Posted on Sep 06, 2010
Will not **** when just using the hose nozzle.
If the normal head works fine then you have a clog in the hose or where the hose connects.
Remove the hose from the unit and check the opening where it goes in. Next look inside the hose and see if you can see debris trapped in there.
When you try to clear the line you need to be in a place where its ok to get dusty. Outside, garage etc.
Shake the hose and keep at it until ALL debris is gone. Also check to see it a stick. pencil. or some other rigid item is stuck in there. If there is it will clog again.
If shaking doesnt work try a broom handle.
Jul 02, 2011 | Bissell 20Q9 CleanView II Plus Upright...
I misplaced manual for Bissell Bagless Cleanview II, nothing being picked up in the plastic bin, where to I look for clog other than bottom of hose near bottom plate please?
Recline the vacuum fully to the floor when looking for clogs in the lower hose. You can run a broom stick through the upper hose to remove any clog. Also, check the brush to make sure there is no obstruction. Lastly, make sure all 3 filters are clean and clear because if they are dirty that can restrict air flow drastically. You can purchase filters at www.bissell.com
May 29, 2011 | Bissell Cleanview Helix Deluxe Bagless...
The suction has stopped working
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright
Vacuum not working
heatman101
Feb 06, 2011 | Bissell 8975 CleanView Bagless Upright...
There is little to no suction. What do I check to fix it?
Vacuum not working
heatman101
Dec 24, 2010 | Bissell 3576 CleanView II Bagless Upright...
I have a bissell powerforce bagless vacum cleaner model # 6579-3. Its not suctioning up anything. What should I do?
Bissell Bagless Upright Vacuum not working
heatman101
Aug 29, 2010 | Bissell 8975 CleanView Bagless Upright...
Bissell 8975-R CleanView Bagless Upright Vacuum - motor is loud when vacuuming
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution"><span>Hi,<br />Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...<br /><br />Bissell Bagless Upright <a href="http://www.fixya.com/support/t4975919-vacuum_pick_up" target="_blank">Vacuum</a> not working<br /><a href="http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not" target="_blank">http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not</a><br /><br />heatman101 <br /></span></span>
Aug 26, 2010 | Bissell 8975 CleanView Bagless Upright...
There is no suction, even though the container is empty
Your hose is clogged and needs to be cleared. You may have to remove one or both ends of the hose that connects the dirt to the container.
You might have success trying to "back vacuum" the hose. A broom handle is sure to clear the clog, however.
Thanks for posting at FixYa.com
Dec 13, 2009 | Bissell 3576 CleanView II Bagless Upright...
Makes a extremely loud alarm sounding noise while vacuuming and the cord in the back doesn't have good suction at all.
When you hear the whistling noise, means there is a clog either in the hose itself, or in the elbow where it goes in or from where the bottom tube bends and goes up. To clean hose, remove it, stick on top of broom/mop handle and push all the way down to clear out any debris on it.
Nov 20, 2009 | Bissell 6591 Power Trak Revolution Bagless...
High pitched screeching/broken handle release
For the handle problem, detent lever part #2030052 and costs $4 to $5. A bearing in the motor is what is making it sound bad, part #2032211 and will cost around $60. You could try bissell.com or call them. They can at least let you know who has Bissell parts near you.
Mar 25, 2008 | Bissell CleanView 3596 Bagless Upright...
Bissell 35962 Cleanview Bagless Revolution UprightVacuum Logo
97 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
