Question about Toshiba 40H80 40" Rear Projection Television
My HD DLP Projection TV has a rolling picture with a green tint. Can I get this fixed?
  • beckypearl Sep 07, 2010
    Thank you!
    I accidentally posted this question under the wrong TV model - but it's similar, just bigger I think...
    I actually have a Toshiba 62" HD DLP Projection - 62HM15
    I'm assuming your answer would still apply.
  • 10,515 Answers
Understand that I am not in the room with the TV. I can only give you information based on previous experience with this type of set.
I would diagnose this as a bad light engine. This is not a cheap part unfortunately (over $800) and a quick search of the web will turn up a lot of Toshiba DLP owners with the same problem. The light engine can be replaced by you if you are reasonably technically minded.
The only wise option would be to call Toshiba and feel them out. See if they will offer you any help. This model is a couple of years old so I doubt you have a warranty but they may be in a good mood and meet you half way with the repair costs - stranger things have happened to people who kick up enough of a stink.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 05, 2010
  • taran_2005
    taran_2005 Sep 07, 2010
    Thanks for your response!!
    Yes, as i gave a reply for Toshiba rear projection TV.
    Hope i helped you.
My screen has a green tint that will not adjust out ?????
The light engine on this TV uses a 3 lens DLP system. You probably have a section of the DLP engine that is dirty or going bad. I have one that is overly yellow the way yours is green. I tried to clean it out, that helped but did not cure the problem. The actual DLP lenses are nearly impossible to get to. That is a good thing because they are very fragile, too! It is watchable but not perfect. Life is hard... with the age of these TV's watch classified ads or Craigslist. Sometimes you can find them for a very low price or even free! They are very easy to work on and really a pretty good tv with working correctly.
May 03, 2012 | JVC HD-61G787 61" Television
Green tint on sony kds-r5xbr1 rear projection tv. picture in hd is still great looking just green.
What media device are you using and how is it connected?
If its an external device (that is your not using a built in blu ray player or such) and your using compost video (it should be three wires for video, blue, green, and red) check the red wire on both ends. Most of the time this is the problem.
If your using a HDMI cable, or the above does not fix the problem, try replacing the cable.
If its only a slight tinting there should be a setting on your tv for fixing it. (Usualy named Tint)
-Forest
Feb 27, 2011 | Sony KDS-R50XBR1 50" HDTV
Screen has green tint, it is an LCD 42 inch
First of all, that is not an LCD tv. It is DLP, which is a common mistake because the picture is very similar. DLP tv's use a high-power lamp that reflects light off of thousands of tiny mirrors into a spinning color wheel which gives the reflections color. Each little mirror is one pixel, which can be any color depending on the hole that it goes through on the color wheel. The color wheel may be spinning slower than normal, which could make all of the light go through the green filter on the color wheel, and give your screen a green tint. Have a trusted mechanic take your tv apart and dust the inside. If that doesn't fix it, you may need a new color wheel or bearings for it (that help it spin). You should not pay more than $200 for a bearing replacement on this tv.
Thanks for asking.
-Josh
This pic might help your understanding.
http://static.howstuffworks.com/gif/projection-tv-1-chip-projector.jpg
Feb 28, 2010 | Panasonic PT-43LC14 43" Rear Projection...
My LCD projection HD TV model KDF-50WE655 has an
Is your TV LCD or DLP? Encompass Parts shows your model to have Lamp with part number for lamp as A-1606-034-B which then means DLP ,which then it means you may have your light engine going bad which is called optics unit Block part number is
A-1084-660-A They do have them in stock Call 1-800-638-3328 or visit their website www.Encompass Parts.
Nov 30, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Projection tv flashes green and purple tints
Find your reciept then call mitsubishi . if you purchased it less than 3 years ago mitsubishi will pay to have the expensive light engine replaced.
Oct 05, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Rear projection HD Hitachi Ultravision always has greenish tint
This is what you're going to do, Turn on the Tv and go to the service manual, if the green tint is still there, you have a defective dmd board, but if it's no there, then you have an issue with your video board
Jul 09, 2009 | Hitachi Televison & Video
Help me willtab guru man...Please.
What is the make and model of your television.. green tint and vertical lines indicat a problem with the light engine..although the clear menu says otherwise..im not sure what type tv you have. lcd plasma change the light im guessing you mean bulb .. this indicates to me you have a dlp. but green tint to me indicates a tube projection type tv... so im just guessing hear. vertical lines also indicate a bad buffer board on a plasma or lcd. so let me know what you have
Jun 16, 2008 | Televison & Video
Green tint to everything on my Samsung HDTV Digital 1080i television
I have the same problem here on this Samsung 40" LCD. its a 2007 model. everything was fine until recently. I had to reset my digital cable box. now the picture has the green tint. its ruined what was a nice tv, and it won't go away.
Mar 11, 2008 | JVC HD-56G886 56" Rear Projection HDTV
HITACHI ultrascan hd tv....
toni, you`ll need a tv tech for this problem, spark gaps need to be cleaned, crt sockets need to be cleaned and crt pins on all 3 crt`s need to be sanded, this is a common issue with this model set, good luck, BMW Rider
Dec 17, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Green tint to hd picture
Sister PCB==PIP or video bad,also==PVAT! Look for any Crt leak damage.Solder all bad connects.
Sep 16, 2007 | Samsung HCM4215W 42" Rear Projection...
Toshiba 40H80 40" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
