Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Bad odor in machine, clothes come out smelling sour
  • 15,935 Answers
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
Posted on Sep 28, 2010
Dryer has sour odor that is transfering to the clothes
This smell usually is a washing machine issue. Run a washing machine cleaner through on a monthly basis and the smell will be gone.
Jun 20, 2011 | Miele Novotronic T1515A Electric Dryer
Clothes smell like body odor after washing. using tide ultra he2 detergent.
i had what sounds like a similar problem. i complained of our laundry smelling sour then finally like sour sewage and a flooded laundry room. i was told that when its not draining properly, it can create a siphon-effect and actually pull the dirty water back out of the drain lines-yuk! i hope this isnt true.
there was a baby sock stuck in the pump preventing it from draining properly. hope your problem can be remedied as easily.
as for the smelly clothes, i always add 1/2 cup white vinegar to each load. it does wonders for odors.
Aug 13, 2010 | Washing Machines
Clothes are sour after wash
The odor is being transferred from your washing machine. The washer must be cleaned first or the clothing will be reinfected upon washing.
The problem area is always just above the normal waterline where suds and soiled water splash up and don't get rinsed out.
To clean your washer add 1 cap of smelly washer cleaner to a full load of laundry in a hot cycle. The added bulk of the laundry will raise the water level to include the "splash area". Intermittent pausing to soak is a good tip for more extreme problems.
Jul 06, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Kenmore Calypso washing machine has an odor during washing cycle
clean the washer with bleach and a small amount of detergent
Apr 20, 2010 | Washing Machines
My washing machine smells sour and I don't know how to cure it.
I used 2 quartz of Clorox bleach running a full load without clothes. After that the odor has gone for good. Try that.
Oct 05, 2009 | GE WHRE5260E Top Load Washer
I have a soured smell in my dryer when it not running
Does it appear that the smell is in the cabinet rather than the drum? I'm guessing that bugs or mice are living in there. There are no components in the dryer case that would smell except for a slight electrical odor. Remove the case and look around! Look for droppings around the back.
Aug 26, 2009 | Dryers
Sour odor. Even though I take my clothes out right away.
The problem is that water sets in a filter area below the tub and sours, or smells like raw sewage. This is common on most front loaders, Whirlpool makes special tablets used in washer to take out the odor.
Jul 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Mold buildup around interior of drum - odor and spots on clothes
Posted in 2008
I've had my Duet for 5+ years with no odor until the past 6 months or so. Even changing to a more fragrant fabric softener didn't make my cleaned clothes and towels smell clean. I noticed it especially when I would grab my towel after a shower. For a while I thought someone else was using my towel and stinking it up. Then I realized it was the whole laundry. ( I was having my laundry done for me... otherwise I probably would have realized it sooner. After reading all the suggestions for resolving this sour odor I thought I would try some of the ideas suggested that I hadn't already tried. Then it dawned on me that about 6 months ago I switched from a powdered detergent (SA8, an Amwy/Quixtar product) and dryer sheets to a well-known well-ranked Liquid Detergent and a fabric softener. I only switched because my son like the way his friend's laundry smelled when he borrowed a shirt. I was using fragrance-free products. So I had fragrant laundry for a short time. Then it started to smell sour. Maybe this change was the cause. So I've ordered another box of the powdered detergent and I'm going back to dryer sheets.
In the meantime I'm still doing stinky laundry. Same day I order new detergent, I decide to wash a load with some very stained baseball pants. I sometimes use a small amount (1/4 cup) of Oxy Clean, with my detergent but I decided to go full-strength which on the box said 1 cup. Hot water wash. Put it in with the clothes. Same liquid detergent, no fabric softener. When I took out the laundry, for the first time in months, it smelled clean. No stale, sour odor. Next load, nice smell again. Decided to do one more load with 1 cup Oxy Clean again. I'm still going to switch back to the SA8 (which is by the way highly ranked by Consumer's reports) and dryer sheets.
By the way, a few weeks ago I had to disconect the water discharge line behind the washer. The sludgy goo that was in the line and machine where the two connected was disgusting, but didn't smell bad. I cleaned it out with my finger. Ugh!
So it's now several months later. My clothes smell clean, as does my washer. I switched to powder and only occasionally use liquid softener. Still occasionally use the full dose of Oxyclean with a hot load. I occasionally wipe down the door and seal... especially the bottom of the window, and always leave the door ajar when not in use.
May 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Gold Ultimate Care II, Commericial Quality, Super Capacity Plus...it smells. No really it has a terrible odor. It's a sour foul smell. Water and detergent and various clothes washing...
Whirlpool now has cleaning tablets to take the smell out washers. They say they are for HE front load machine but it works on all machines. They are called affresh washer tablets. Just buy some and put all three tablets in the tub with hot water and let the washer go through a cycle with just the tablet(no clothes). By putting all three in the washer at one time it will kill the smell. For later use the package is a three month supply. They cost under 10 dollars.
Nov 14, 2008 | Whirlpool Washing Machines
Odor when starting cycle
Check your water softener(If so equipped). This can cause foul odors in the water supply if not properly balanced or maintained. Good luck!
Sep 06, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
64 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
