Question about Singer 5062 Mechanical Sewing Machine
I have a model 4562 singer sewing machine. the case that holds the bobbin in out and i can not figure out how to put it back into the spot. Please held
4 Suggested Answers
SOURCE: Where can i find a
called a local service tech.
Posted on Jul 07, 2008
SOURCE: I have a Singer Sewing Machine Model 4562 T I
Change needle. It should be alright
Posted on Oct 17, 2009
SOURCE: Singer 4562 t bobbin case won't fit properly, what am I doing wro
Make sure the bobbin case sets sort of on top and not under the ridge of the metal ring. There is a small latch on the upper left of the bobbin case. It is metal. rotate the latch to cover the bobbin case and this should stabilize the case without making it immobile
Posted on Aug 01, 2010
How to thread the bobbin on a singer electronic 4562?
Do you need to wind the bobbin? If you just need put in the bobbin, make sure that the needle is in the highest position and that the presser foot is up. Slide open the cover by moving it towards you. Pull about 4" of thread from the bobbin and hold the bobbin such that the thread is coming off in a counter-clockwise direction. Put the bobbin into the bobbin case and secure the thread in the notch near the center bottom of the bobbin case. Next guide the thread into the notch to the left (near 7 on an analog clock). Hold onto the thread and slide the cover closed. To bring up the thread, make sure that the needle is threaded as well. Turn the hand wheel slowly towards you while you hold the needle thread with your left hand. Turn the wheel until the needle comes back out of the needle plate. Pull gently on the needle thread. You should see a loop of thread around the needle thread. Gently untangle this loop until you get to the end of the bobbin thread. Pull the needle thread through the opening on the left side of the presser foot. Then pull both threads to the back of the machine.
Most Singer sewing machines are available here: http://www.singerco.com/support/instruction-manuals . The direct link to the manual for the 4562 is http://www.singerco.com/uploads/download/435_5_8_10_16_22_dial.pdf . The details and images for winding the bobbin is on page 13. Inserting the bobbin and raising the bobbin thread is on pages 15-16.
I hope this helps.
Sep 23, 2015 | Singer Sewing Machines
I have a Singer 4562 T sewing machine. When I try to sew the bobbin case is jumping out of the housing. With the slide closed I sew until everything gets a mess on the underside. When opening the housing...
pl open the entire bobbin housing two scrwes with suitable screw driver and clean .test the latch on the bobbin case,look for steel tension strip screw replace the unit ,also replace needle
Dec 11, 2013 | Singer 7442 Mechanical Sewing Machine
Singer 4562
here is a link for a free manual, then information of how to insert the bobbin case into the machine
Sep 08, 2013 | Sewing Machines
My bobbin on my Singer 4562 keeps bunching up the threads, can you help?
If you have the black bobbin case you must make sure you use only a good mercerised thread, there should be enough gap between the edge of the bobbin case and the silver adjuster to allow the thread to pass through, if there is not then you must slacken off the two screws and move it over a fraction.
Aug 11, 2011 | Singer 2732 Mechanical Sewing Machine
I have a Singer model 4562 T sewing machine, and threading the bobbin, the bobbin case just kind of popped out. I've tried just sliding it back in, but no matter which way I put it in it doesn't seem to...
The bobbin case is designed to be removed for cleaning. Take off the needle plate if it is still on the sewing machine. Make sure that the needle and presser foot are fully up. Guide the forked end of the bobbin case under the feed (more or less centered). Then pull the bobbin case under the rim of the position plate. Pull on the side opposite the forked end of the bobbin case. With a small screw driver, turn the lever (at about 10 o'clock on a 12-hour analog clock) towards you. This will lock the bobbin case into place. Make sure that the bobbin case isn't locked too tightly. It still needs to move slightly as the bobbin turns and the needle comes through that plate.
Replace the needle plate and lock it down. Then insert the bobbin and close the slide plate. The manual shows the procedure to remove and replace the bobbin case on the 4562 on page 39. Singer has the manual on the support page: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/435_5_8_10_16_22_dial.pdf .
I hope this helps.
(I hope that the locking lever hasn't broken. That may require a service person to solve the problem. I'm not entirely sure where that lever is connected to the machine. Some Singer part diagrams are here: http://www.singerco.com/support/replacement-parts-chart . The 4562 may use the same diagram as the 4572, http://parts.singerco.com/CPpartCharts/4_4999/4572.pdf .)
Jul 01, 2017 | Singer Sewing Machines
Jan 27, 2010 | Singer 7442 Mechanical Sewing Machine
yes you can get help from youtube.
How to Fix / Repair the Hook Timing on a Sewing Machine
Oct 16, 2009 | Singer 132QRFB Mechanical Sewing Machine
I don't not have the Instructions on how the bobben should be threaded in the bottom of my sewing machine. I have tried everything that i can think of but it well not thread. If it dose come up it dose not...
The manual for this sewing machine (Model 4562) is available and may be downloaded at no cost from Singer.  The Link to that page is: http://www.singerco.com/accessories/manuals.html
Inserting a wound bobbin is found on page 15.
Aug 09, 2008 | Singer 7462 Mechanical Sewing Machine
Singer model 2732
It is either inserted incorrectly or the bobbin case needs replacing. Check the bobbin case by running finger tip around the outside of case, if rough spot needs replace. There is a ltch that is spring loaded you must hold back with small bladed screwdriver while inserting case for proper placement
Oct 25, 2007 | Singer 2732 Mechanical Sewing Machine
Singer 5062 Mechanical Sewing Machine Logo
93 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
