Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Water just keeps running
Once the first cycle is done, the water will start running but the drum is not filling up. After a while the water will stop and the cycle will not finish.
    Genius:
  • 1,073 Answers
Check the drain hose to make sure that it is not stuck too far down in the house stand pipe it only need to be in the pipe 5-6 inches
Posted on May 12, 2008
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
I bought a top load washing machine model number WF T7239 UL on 05Nov2010. Water sensor does not seem to work. Water just keeps filling up the drum and starts overflowing once filled.
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Nov 06, 2010 | LG Washing Machines
Hotpoint aquarius drum fills to top with water
will it stop when you stop the cycle? if so your pressure switch could be the problem however if that does not stop the water you intake water valve is most likley the problem
Feb 06, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
Jan 31, 2010 | Whirlpool Inglis IP4400 Washer
My He3 begins to fill the drum with water (very slowly) after the cycle is done, I have to turn off the hose valves after the cycle to keep this from happening. Any ideas what is letting the water back...
sounds like you have a bad water valve..if water is come in try to unplug the washer if water stop you have a bad control if it keep filling you have a bad water valve
Sep 20, 2009 | Washing Machines
Sits Pretty Doing Nothing,ARG!
Any codes on the front?. Try here to see if it's any help: Type in MAV6000 only
http://servicematters.com/maytag_library/html/index.html
Danwan
Sep 12, 2009 | Maytag Atlantis MAV6000 Top Load Washer
WFD 2460 will not start wash cycle after it has filled with water
Isolate power and water supply and gain access to the main drum motor. Check for condition of carbon brushes by removing them and repla
ce if severely worn. Check wiring loom around motor and right back to module controller. The clicking is obviously power being supplied to motor via the loom to the motor. finally check for any dry solder joints or burnt areas on the circuit board controlling the motor.
Dec 07, 2008 | Bosch Logixx WFT 2806 Front Load...
Water keeps filling!!
sphion effect while the water comes in the water goes out ..because you never said that it overflows,,,so just put your drain hose up the height of the machine before it can go down,,,drain hose to low...onthejob
Nov 16, 2008 | Frigidaire FTF530FS Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
