Question about Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger
Weed eater te 475 runs for a few seconds and then stops. Does not seem to be getting gas
  • Poulan Master
  • 7,482 Answers
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to seat the jet screws.
But before you seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
Weed eater runs but wont take fuel acts like running out of gas
Hello David,
You most likely have 1 or 2 problems causing this problem, both which have to do with the carburetor reservoir bowl.
1. The bowl is contaminated with dirt in with the gas causing the port to be clogged and won't allow gas to be siphoned into the carb /engine.
2. The rubber gasket on the top of the bowl is cracked due to the alcohol in the gas and needs to be replaced!
Rich Lilja
Sep 04, 2016 | Stihl FS 85 Weed Eater
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Weed eater starts but only runs for a few seconds and cuts off. prime it and starts but only runs for a few secounds and cuts off again
    check gas line in gas tank. See if Stone filter broke off of gas line.
    Very common with this new crappy Ethanol gas
    Aug 23, 2013 | Garden
    Poulan 446 Pro engine won't run
    its probably not getting any gas from the tank try putting your finger on the hole on the carberator and pull your finger should be wet if not take fuel line of the carburator and thenblow then take off the gas cap and blow through the hole on the gas tank it should flow freely throgh teh line to the carburator
    Nov 06, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
    How do I replace the pull rope on the TE 475 weedeater? I went to start it today and pulled on the rope and it all came out.
    How do I replace my pull cord on my weed eater TE 475? I have the parts diagram, I need to know where the cord attaches and what the steps are to rewind the pulley and attach the cord.
    Oct 19, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
    Craftsman weed eater wont run
    MAKE SURE YOU REPLACE THE CARB GASKETS. ALSO MAKE SURE YOU ARE USING FRESH FUEL WITH THE RIGHT MIXTURE. COMPRESSION SHOULD BE AT LEAST 90LBS
    Sep 24, 2009 | Garden
    Weed Eater GTI 15 won't run???
    Check the gas lines, one might be bad...
    Jun 01, 2009 | Garden
    My te 475 weed eater wont start
    Check the on-off switch? Try disconnecting the switch and see if it starts. If it does, replace the switch.
    May 18, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
    I replaced both broked fuel lines and it still doesn't start.
    Make sure the line is connected to the fuel cap if it has a pump ball.
    Apr 24, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
    Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Logo
    795 people viewed this question
    Top Poulan Garden Experts
    Roland W VanLue
    Roland W VanLue
    Phil Walker
    Phil Walker
    Are you a Poulan Garden Expert? Answer questions, earn points and help others
