Question about Microsoft Xbox 360 Console
I put a game into my x-box and when i push the button for it to go in it just makes two clicking sounds and doesn't play anything. I'll try over 30 times to efect the game and put it back in but it does the same thing all over again
  • 767 Answers
This is somewhat common for 07 and earlier consoles .
If you hear it spin 3-4 sec then stop with a OPEN TRAY
message . 90% chance you have a dead/weak laser.
Good news , the new lasers are cheap 20.00- 30.00 and not hard
to install with help from a youtube tutorial
Or you could have a shop swap it out for 50.00-70.00
But shop around for some one local so if there is problem
you'll avoid shipping it back and forth .
If you have any questions feel free to ask
Rob
Posted on Sep 05, 2010
  • Rod Sims
    Rod Sims Nov 11, 2010
    If had thought to ask for more help installing the laser or how to swap
    the old drives P.C. board to a new drive , I would have been more than
    happy to help you , I could have sent you a new laser for 20.00 .
    And you would have a working 360 . But you chose to be ungrateful
    and leave less then favorable feed back.
    Oh well .
    Rob
Why does the 30 amp circuit breaker behind the battery box on my 1990 fatboy click once when i push the ignition button? The bike won't start.
Try to reset the circuit breaker. also check for an earth fault on the starter motor .If this is not a circuit breaker and is a relay, you should make sure everything is ready for a start, (ie : in neutral, sidestand up and clutch in and that the battery is charged.) the neutral light being "on" doesn't mean it is in neutral. I hope this helps.
Mar 08, 2012 | Motorcycles
My ps3 will not read my games , but it will read dvd's
Blu-rays utilise a blue laser within the drive and DVDs use a red laser.
Sounds like the blu-ray/games reading blue laser has died and it'll need replacing.
http://www.ebay.co.uk/itm/270866380794
Very helpful and knows his stuff.
Hope that helps.
Dec 04, 2011 | Sony Playstation 3 (PS3) Console
Cd in macbook wont ejec
This can be a problem. First try rebooting the machine, and holding the eject button when you hear the startup tone. Hopefully, that will force-eject it.
If that doesn't work, you'll need to get creative. Get a playing card or something similar, and put some rolled-over tape on one side close to the edge, so there's a sticky side out. Turn the computer off, and try to get the playing card into the CD drive, with the tape making contact with the stuck CD. Reboot, holding the eject button when you hear the eject button again, and pulling the card out. Hopefully, the CD will come out with the card. If it doesn't work, just keep trying, and you'll get it out eventually.
Generally what causes this is keeping CDs in the computer for an extended period of time, especially while the computer is powered off. Make sure you remove all CDs before moving or turning off your computer.
Sep 07, 2011 | Apple MacBook Laptop Computer Mac...
Trying to open big fish games and get the message DRMactivator Application has stopped working - will not let me open any of the games. Have tried the fixing by going into settings etc and changing the...
If you are receiving the DRM activator error message do the following to correct the issue.
1 - Left click on Start
2.- Right click on Computer
3 - Left click on Properties 4 - Left click on Advanced System Settings
5 - Under Performance click on Settings
6 - Left click on Data Performance Settings
7 - Click on TURN ON DEP FOR ESSENTIAL WINDOWS PROGRAMS AND SETTINGS ONLY.
8 - Click on Apply and then OK.
UAC: (User Account Control)
Open up Control Panel, and type in user account into the search box. You'll see the link for "Turn User Account Control (UAC) on or off". Click it. Uncheck the box, and reboot your computer. hope this helps but if it still doesn't work just text me back and we'll try somthing else:)
Aug 07, 2011 | Computers & Internet
Hi, The game, Nancy Drew: Danger by design, doesn't work in my laptop. Every time I try to play the game, the screen freezes but I can hear the music at the back ground. All the other Nancy drew games...
The first thing you should try, is to update both JAVA and Flash. If it uses those, that is likely the issue.
Here are the links:
http://www.java.com/en/download/inc/windows_upgrade_xpi.jsp
http://get.adobe.com/flashplayer/
Be sure to uncheck the boxes that install toolbars. Also, it wouldn't hurt to make sure that Windows is up to date. Click the Start button, click All Programs, and then click Windows Update.
Jul 11, 2011 | Her Interactive Nancy Drew: Danger by...
Very low volume HK 695-01
There are several ways in which you can increase the volume.
First, the most obvious way is to use the volume control attached to the speaker unit itself. If that isn't working, there's also an icon in the lower right-hand portion of the task bar in Windows. Simply click the ^ button, select the icon that looks like a speaker, then drag that up to your desired preference.
If that doesn't work, click on Start, go to Control Panel, click on Sound, then search for your Speakers in the "Playback" tab. First, make sure it's set as your Default Device. There should be a green check mark in it. Double click on those, select Levels, then make sure Play Control is set to maximum.
If that doesn't work, then check the settings on your Sound Card. Make sure the wire going into the back is plugged in properly. You may need to update your sound card drivers. If you aren't sure who the manufacturer of your sound card is, you can find out by going to Start > Control Panel > Device Manager. The Manufacturer will be under Sound, Video and Game Controllers.
Once you have that information, you can go to the Manufacturer's website and update the Drivers. If this doesn't resolve the issue you are experiencing, or if you require more specific / additional information, simply respond to this thread. I'll be happy to assist you further.
Regards,
Aaron Busch
Senior Tech of LiveFix Support Services (LiveFix.net)
May 03, 2011 | Harman Kardon HK695 Computer Speakers
Hi i just got a fc twin and i am trying to get a nes mario/ duckhunt game to go in and i cant figure it out.. i have other games but they wont go in eaither
The front slot is made for NES games such as mario/duckhunt, and the back slot is made for SNES games. Make sure you put them in the right direction as well.
Good Luck,
Rodrick
Apr 22, 2011 | Vs Clothing FC Twin Video Game System for...
I inserted a new movie and I have no sound nor video with a green and blue lights on.
I had this weird problem yesterday knowing I have not done any video setting changes, nor recall a pending software installation. When I start the PS3, green light comes up and then nothing happens. Insert the Game into the slot, blue light blinks and again nothing happens. No video, no sound, and no, it’s not output setting problem as many others have guessed in forums. Try to assign your wireless controller and you’ll know. It doesn’t. If it was on, output and controller assigning I assume should be two separate things.
Solution:
  1. With the PS3 in Standby mode (Red light on), press and hold the Start button until you hear a single beep, followed by double beeps.
  2. Connect the controller using USB cable and press the PS button on the controller.
  3. Now, the system restore screen (or whatever they call it) will come up like this
  4. You have several options here for restoring the system, some will unfortunately wipe up all your data, others will make you lose the file naming. For me, I tried the option top-bottom and eventually had to do the Restore PS3 System. Luckily, all I had were demos, trailers, and game saves. only game I was really playing now was Prince of Persia. I felt terrible still though, but much better than if I was playing Ninja Gaiden or MGS right? Or let’s say a game Fallout!
Sharing it for others with same misfortune. Guess we’ll need the PS3 included in the backup plan then.
Nov 14, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont play discs
to me it sounds like your lens are messed up, try getting a dvd cleaner and use it on your ps3 man
Apr 10, 2009 | Sony Playstation 3 (PS3) Console
Will not come on
try resetting it this way, turn the lock button on then off, then push and hold the menu button and the click wheel center button AT THE SAME TIME for at least 30 seconds
Mar 25, 2009 | Apple iPod nano
Microsoft Xbox 360 Console Logo
189 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
