How can i get to the setup wizard page to set up my netgear router
  • 398 Answers
Open up Internet Explorer or Firefox and type 192.168.0.1 in the address bar. Also check the bottom of the router as it will give you the login details there.
Posted on Sep 05, 2010
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
I lost my password to my netgear. How can I retrieve it?
Go to NETGEAR Router.
After connecting the Router into your network, you must configure it. You can do this using the Smart Setup Wizard -- where the wizard will attempt to auto-detect the type of Internet service you have through your ISP -- or you can configure the router manually. It is recommended that, if you aren't used to setting up Internet connections, you let the Smart Setup Wizard do some of the work for you.
To configure the router, you'll use the information that you filled out earlier in the Installation Guide.
To get started:
  1. Select Yes if you want to use the Smart Setup Wizard.
    or
    Select No to configure the router manually.
  2. Click Next.
Nov 06, 2010 | NetGear WGR614 Router
I lost my password and lost the WGT624 installation CD, how can i get the router to work on a new laptop
If you have lost the password to access the router page then you have to reset the router
Ensure that you have all the details regarding your internet connection before resetting the router
If you reset the router you can run the smart setup wizard and get connected by entering correct information in all the pages of the wizard
If you are looking for the wireless password:
Access your router page ( Open Internet Explorer --> Type 192.168.1.1 and enter it--> Login name(default)-admin, Password(default)-password) --> GO to wireless settings,under Wireless settings you will find the wireless password.
Jan 17, 2010 | NetGear WGT624 Wireless Router
Trying to connect netgear wgr614v9 router to new toshiba computer with windows 7 ....setup says unsupported operating system....what do I do
As netgear setup disc doesnot support Win 7.
U need to manually setup the netgear product
-- hard resett the router using a restore factory setting hole on the back of the router
-- open the netgear router page using www.routerlogin.com
-- Username - admin , Password - password
-- run setup wizard
-- if it detects dynamic ip then press next
-- and on the left u will see wireless settings under setup .
-- secure the network using WPA_PSK(TKIP)
-- and then apply .
In case if it will detect static or fixed ip .
Then click on " Basic settings "
-- Under router MAC address
-- select "use computers MAC adress "
-- Apply
-- And then Powercycle the network..
-- And u will be able to go online ..
Jan 02, 2010 | NetGear WGR614 Wireless Router
How to install and will this box allow my desktops(2 of them ) to both be connected to a wireless network?
There are 2 ways to setup Netgear
1. Setup Wizard (which guides you through a setup wizard)
2. Manual Configuration (you need to put all values in router manually)
Here we are not discussing Setup Wizard as Manual configuration is far much easier then auto configuration
To configure (config) Netgear we need to get into router page
To open router config page
1. Open Internet Explorer (Start>>all prog>>Internet Explorer)
2. Type in address bar 192.168.0.1
3. In username box type admin (where it says gateway 192.168.0.1 requires username & password)
4. In password box type password (word password itself)
After this you will find Netgear ADSL Wireless Router Setup page
Here we need to select Basic Settings (as shown below)
after this you will find next page as
Here in this page (Basic Settings Page)
Does your internet connection requires login, Select Yes
Select Encapculation as PPPoE
Login is Username as provided by your ISP
Password is your password for broadband connection as provided by your ISP
Keep Idle timeout as 0
after this simply press apply without changing anything else
Now We Need to click on ADSL Settings Page
Now on ADSL Setting Page We got only 3 options
Multiplexing Method Should be LLC-Based
VPI 0
VCI 35
now just press apply again
By this time your router should be only (you can check it by opening any website on Internet Explorer or by router status option on netgear page)
To Config Wireless
Click on Wireless Option (on left hand side blue panel)
It should display next page as
Here in this page
Wireless Network Name (SSID) Alpha-Numeric name which would be displayed as your wireless network name
Region Here Select Your Region
Channel: Select whichever channel give you best sighal (9, 11, 13 are recommended)
Keep the TIck on Enable Wireless Access Point
Keep the Tick on Allow Broadcast of Name (SSID)
Can Untick Wireless Isolation
Then Jump to Security Options
Select WPA-PSK (Wi-Fi Protected Access Pre Shared Key)
then in WPA-PSK Security Encryption type in anything of your own choice but alphabets and numbers both should be there and make it between 8 to 63 characters long.
WPA-PSK Security Encryption Key is your password for wireless network
Now Press Apply and your router is ready for wireless too
After doing this you can change MTU (Maximum Transmit Unit) size to 1400 from WAN Setup Option
You can find WAN Setup Option in same blue panel on left hand side of screen
Here you just need to change MTU to 1400 and need not to change any other setting
Now its all done and router is ready to send wireless signal to your system/laptop
Nov 26, 2009 | NetGear WGR614 Wireless Router
NETGEAr support
not sure exactly why you would need the setup software... you should be able to plug it in and access the routers firmware and set it up that way.
here is the link to the site for your hardware.
http://kb.netgear.com/app/products/model/a_id/2591
Jun 01, 2009 | NetGear WGR614 Wireless Router
default access to router is http://192.168.1.1
login/password is with your instruction booklet.
May 07, 2008 | NetGear VS-WGR614 Wireless Router...
Netgear DG834G v3 Installation
connect the yellow (or blue?) ethernet cable to your computer, this should connect to the router (router should be ON)
Now, in internet explorer type 192.168.0.1 (this should be the defualt gateway for the router on default settings.
Now you're into the router, there should be a setup wizard button in there.
See if you can set it up using that
Regards
Tony
Feb 28, 2008 | NetGear DG834G Router
First use the Netgear setup wizard:-
Enter http://routeraddress e.g http://192.168.0.1
Click Setup Wizard (top left)
Then for With AOL make sure you have set these values in the Netgear
ADSL settings as PPPOa
VC 0,38
MTU setting to 1400
If you still have problems
Start -> Control Panel -> Add/Remove Programs -> select AOL Connectivity
click Add/Remove -> use the repair option
Follow instructions to repair.
Once complete make sure modem is configured and switched on and
try restarting AOL.
It should search for your connection, find it and allow you to log on.
Feb 06, 2008 | NetGear DG834G 54 Mbps 802.11g Wireless...
Netgear router
Go to routerlogin.net, the username is: admin, and the password is: password, OR 1234.  You can follow the setup wizard or manually assign the IP address.  I hope this helps!
Dec 27, 2007 | NetGear WGR614 Wireless Router
Computers & Internet Logo
David Payne
David Payne
