Question about Fuji FinePix A400 Digital Camera
Bottom back it isn't working when I want to see the pictures
  • Bongolino May 12, 2008
    Can you help me?
  • saravanakumar sridhar May 11, 2010
    Wht happens when u turn to play mode
The imagem is appears black.
Posted on May 12, 2008
Can't lift rear bottom seat up to put down back of seat for cargo hauling. Seat bottom will not budge and I can feel the strap is still attached to the bar that should be moving up but isn't.
it is rusted to the latch. soak the latch under the seat with wd-40 and wait a day. then try again. if it doesn't work then use a screw driver to pry open the seized latch.
Apr 04, 2013 | 2000 GMC Yukon
Cant unlock tablet t301
I'm not exactly sure what you mean by "unlock". But, if you mean you see the main screen but don't know what to do next, that's easy. On the home screen you will see two icons down toward the bottom, one on the left (green, with a little picture of a lock which has an open hasp), this is the UNLOCK switch. Simply put your finger on it and drag to the right, then release. The other icon is gray and controls the volume. See the user manual here, and picture of the screen I am talking about is on page 7. Post back if this isn't what you were looking for. No reset necessary http://s3.velocitymicro.com/vmcruz/T301/manual/Cruz_Tablet_T301_User_Guide.pdf
Aug 12, 2012 | Velocity Micro Cruz Reader R101 Tablet PC
N325T water collecting at bottom and back internal wall freezing up
That sounds quite normal as the rear panel is the evaporator skin. Check the drain hole at the bottom isn't blocked
Apr 22, 2012 | Refrigerators
Step by step to setup mode in my nikon coolpix camera
See the illustrated instructions on page 17 of the manual. If this isn't the initial setup, see the details in the paragraph at the bottom of the page.
Jan 26, 2012 | Nikon Coolpix S210 Digital Camera
My fridge gets really hot on top and between the fridge and freezer where the door meets
next time send the model number and brand name.usually when this happens is the condenser fan motor isn't working.pull the fridge out,remove the bottom back panel and check the fan to see if it's working,if it is check the condenser coil to see if it's filled with lint and dust,it could just need to be cleaned out but if it's that hot most likely the fan isn't running,if you get this tonight check it now,if the fan isn't running you could blow the compressor,the condenser fan blows and keeps the compressor cool enough so it doesn't overheat by moving the hot air and the heat also esscapes through the condenser coil so if that's clogged with dust the machine will run hotter than normal,if the fan isn't running you can stick any window fan back there and blow it onto the compressor to keep it cool until you fix the condenser fan motor,this way you won't loose any food and if the compressor goes it's new fridge time,to much to repair.hope this helps and good luck with your machine.one more thing,i've found the fans not running and by pushing the blade it runs again,if this happens the fan could run and never have a problem or it could stop an hour later but i would change it out no matter what.if it's a G.E. fridge and the motor isn't running,most likely it will be the computer board,i've found 10 machines doing this and the temp. settings turning on and off or the evap fan motor in the freezer runs slow and then fast and the condenser fan isn't running or running slowly,this is why you have to send the brand name and model number.
Oct 28, 2011 | Refrigerators
Webcam isn't working or being recognized
Have you tried - pressing and holding the FN key (at the bottom left of your keyboard) and then press once the key with a little picture of a webcam at the top of the keyboard... like this
http://tinyurl.com/4x5kcag
If that doesn't work have you checked if the driver is installed for the webcam?
you can also try here http://www.testmycam.com/ to see if it is a software issue?
Aug 24, 2011 | Toshiba Satellite A305-S6883 Notebook
I need a picture diagram for the firing order for a 1978 custom pick up with the 318 v8
This is the firing order for all Chrysler Small Block Engines (273, 318, 340, 360). Top is the Left Bank, Bottom is the Right Bank (in case the picture isn't clear) 74dusted.jpg
Aug 24, 2011 | Dodge Pickup Cars & Trucks
My Magnavox TV give sound but no picture. When I turn it on the light in the bottom right hand screen goes green, then flashes to yellow and goes back to green. The screen does not change it is constantly...
You need to replace your backlight inverter.
Check that all voltages are coming from the power supply as they should. The power supply will be stamped with the correct amounts, and you just read with the multimeter to confirm.
After those check out ok, you will need to replace the inverter to "light" your screen again.
You can hear sound because the tv is ON, but the inverter isn't lighting the screen!
Hope this helps, please rate!
May 11, 2011 | Televison & Video
The agitar isn;t working right. Is there
The part you need is FSP# 80040 dog kit goes inside the upper agitator. installing them dawgs: You sit the agitator on the floor, put you feet on the base and snatch the top portion off of the bottom. You put all the dogs back in the cam set them up into the upper portion with a piece of pvc pipe or equivilent and invert onto the base, lining up the tabs on the bottom with the holes in the upper portion being careful not to smash the tabs on the base that hold the upper portion onto the agitator. Snap it all into place and gently re-install it being careful not to over tighten the nut. Watch this video:
Jun 06, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Hitachi 61SBX59B 61 inch has brightness and color problems
I would say the crt's are at the end of their life.
Sep 09, 2009 | Televison & Video
Fuji FinePix A400 Digital Camera Logo
18 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
