Question about Yamaha Audio Players & Recorders
My yamaha receiver rx v663,says vol fixed on zone2. it never did this before
  • Yamaha Master
  • 19,396 Answers
Hi.
The zone 2 pre-out is set to 'fixed'. Zone 2 indicates additional set of speakers tat can be connected to presence terminals through an external amp.
That means that the volume out from pre-amp to zone 2 is fixed to a standard line level Check the setup menu and find settings for zone 2, if there is no settings, that means that the receiver forces volume to fixed when a device is detected on connection to zone 2.
Most receivers work using only fixed volumes. Fixed pre-out is OK with most configurations, your Yamaha should be working fine with volume fixed on zone 2. Volume is controlled to an amp or other device connected to the receiver.
Posted on Sep 05, 2010
My Yamaha RX-V663 Receiver doesnt turn on. After the power at my house went off, it doesnt turn on anymore. How do i fix it?
Try holding the "straight" and "audio select" buttons and press power. this may return power if the unit is locked in protect.
Nov 23, 2014 | Yamaha RX-V663 Receiver
Zone 2 vol fix
I'm assuming you mean when you try to turn up the vol on zone 2 it says "zone 2 vol fix" and you want it to be "variable" giving you the control from the remote. Open the GUI menu (Receivers main settings menu) go to (options) select external zone or zone2 then select (Variable) If you have your receiver passing video to your TV it's alot easier to navigate the menu. If you still have problems, post a reply on this thread with your product list including make and model #'s and I can walk you thru the whole process. Hope this helps
Jun 15, 2010 | Yamaha RX-V661 Receiver
I have a Yamaha RX V665 and I am unable to change the volume
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
Jun 07, 2010 | Yamaha RX-V663 Receiver
Yamaha RX- V 663 - unable to change volume on Zone 2
Page 111:
PROBLEM: Zone 2 speaker settings are not available in "SET MENU".
CAUSE: "EXTRA SP ASSIGN" is set to a setting other than "ZONE2".
REMEDY: Set "EXTRA SP ASSIGN" to "ZONE2".
See Page 85
Mar 13, 2010 | Yamaha RX-V663 Receiver
Yamaha rx v663 video signal skipping
I'd leave it that way if it was me.
Jan 28, 2010 | Yamaha RX-V663 Receiver
Yamaha receiver RX-V663
Make sure you have an analog RCA audio cable from the source to the receiver. Digital coaxial or optical will not work for zone 2 or zone 3. By adding an analog cable it will not affect your main zone, it will always go to digital first. Hope this helps
Dec 29, 2009 | Yamaha RX-V663 Receiver
Switching from comcast to verizon fios my rx-v663
This usually means your receiver is not passing the HDCP copyright protection correctly. Try using component cables instead, if your receiver supports it.
Nov 25, 2009 | Yamaha RX-V663 Receiver
No volume in Zone 2
Get the original Yamaha remote, go to Set menu, manual setup, speaker setup, and look for "extra speaker." it needs to be set to "zone 2." This is off the top of my head, so it should be pretty accurate. Get used to doing this, though, as this amplifier assignment to zone 2 is prone to resetting itself in those Yamahas.
Sep 05, 2009 | Yamaha RX-V661 Receiver
On zone 2 of my yamaha rx v663 receiver it says fixed when I try to adjust the vlume and won't let me cut it up or down.
Check the setup menu of the receiver on zone 2 settings most likely the error is a fixed volume setting for this zone. If not found, reset factory settings and try to setup everything again. If the problems persists, contact your vendor if still under warranty.
Apr 12, 2009 | Yamaha RX-V663 Receiver
373 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
