Question about Goodman CKL30AR30 Air Conditioner
LED light The LED light on my control board is not coming on. I am getting power to the unit.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
This is so simple, I'm gonna let my grandson answer this one.(7 yrs old) ......hi.check the power sucking in the transformer & blowing out of it, ok....ok? ok! It sucks in 120v electricity and slow in down to 24-28volts so the small parts can use it..WELL , what can I saybut.......Thank-you-very-much! .
Posted on Aug 25, 2008
Why does it have audio, but no video?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electronicshelponline.blogspot.com/.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Jul 28, 2015 | Televison & Video
No picture no sound on a Vizio HDTV10A. The green light comes on then turns to amber after a couple of seconds
your Main board went bad, common issue with these units. Need to be replaced, in tv land it called main board in computer world mother board. your unit has only two boards power board and that is good cause you get a amber to green to amber led. good luck Vizio field tech
Feb 01, 2013 | Vizio 32" l32 hdtv 10a high definition...
I have a split a/c hitachi model number RAS-3HQE5 it stopped working the other evening, i have power to the outdoor unit when i removed the cover i found a mouse shorting across the power supply...
The shorrting could have damaged the control board and so the board commands must be checked. The output to the outdoor unit comes from the processor in the indoor unit and so checking the working of the processor is important. It is possible that the short could have damaged the circuit and so a trace is need on the tracks that was shorting.
Tip: Check the LT circuit from the mains as the high voltage could have flown into to damage the circuit.
Aug 31, 2011 | Heating & Cooling
HDMI/ DVI inputs failed approx. one month after connection of Denon home theater receiver with HDMI pass-through feature "on." Gear successfully re-connected via component video...
hi welcome to fixya
i want to clarify first the problem sir so as of now the problem with your tv won't power on then you are using again the old main board is that right ? when you use the new replacement main board the tv is functioning will the only problem is that the HDMI / DVI inputs doesn't work. and now you encountered power supply problem like won't start up or something that cut the supply in which the stand by indicator is turn off so as my idea it has a problem with the old board. but before you come up with the board making sure all the connectors coming from the power supply is properly connected to the main board as will as flexible and lvds cable for the T-con board is properly inserted.just let me know if is that what you are asking for so i can give you additional solution thanks for consulting the fixya.
Aug 30, 2011 | Televison & Video
I have a furnace 90+ . I have no power at the t-stat..no led, blank screen, and the blower will come on. The furnace is tied into a control panel. I can jumper the the unit at the furnace to have the A/C...
either a thermal switch is open or the pressure switch is closed at start up the system checks all of these before sending power to the T-Stat
Sep 29, 2010 | Heating & Cooling
No indication of power to the unit. I opened the unit and removed the cable connecting the main board to the LCD controller board. I disconnected it from the LCD controller board side. When power is...
If you hear a flickering sound the power board is bad .However since you have found the lcd board to be faulty you might as well replace it.Look for it on line by part number.Or to save yourself some headache use a good board from a working monitor.
Good luck
Sep 16, 2009 | Acer AL1923 19" Monitor
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 21, 2009 | LG WM-2277HW Front Load Washer
Philips 42pf7321d/37 blinking power board question
The probleis with one of the maina boards and trouble shooting would have to be done to see which board is bad.
Aug 17, 2008 | Philips 42PF9630A 42 in. Plasma Television
Coleman 15k will not come on
Here is the troubleshooting guide for your unit. Hope this helps.
TROUBLE SHOOTING GUIDE
TROUBLESHOOTING
Symptom Remedy
1. Remote does not turn on system
- Check and replace remote batteries if the display fades while
any button is activated or no display is present. - Point remote towards IR receiver during transmission. 2. System does not turn on, no green LED & no beep
- Check wiring. (see "installation instruction")
- Check modular cable to receiver.
- Check diagnostic LED status in the upper unit control box.
3. System does not turn on even when receiver green LED is on.
- Low or over voltage condition, check diagnostic LED status in the upper unit control box.
4. Fan runs but no cold air.
- Evaporator temperature sensor reaches low limit, defrost mode.
5. System runs continuously in the cool mode
- Remote was set for "I feel" mode and is left in a heated environment (sun etc.)
6. System runs continuously in the heat mode
- Remote was set for "I feel" mode and is left in a cool environment
1. Diagnostic LED (green)
(Note: Located on the control board in the upper unit control box.)
a) The LED is on when the 12VDC is adequate and communications are
present.
b) The LED is flashing fast and steady when in the freeze mode. Evaporator has frozen and the freeze proctection switch is engaged.
c) The LED is flashing slow and steady when the delay on break timer is
activated.
d) The LED is flashing 1 cycle on and off for one second with high or low
12VDC. Check the incoming 12VDC power for OK.
e) The LED is flashing 2 cycles on and off for one second with a
communication problem. Problem with the control board in the unit and the remote.
Hope this helps.
Jeff
Rate me Please!!!
Jul 29, 2008 | Coleman Mach 15 Air Conditioner
Goodman CKL30AR30 Air Conditioner Logo
71 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
