Question about H&B CA-8050BT CD Player
Is it normal during the installation of the H&B CA-8050 CD player it gets hot after working 15 minutes?
  • 3 Answers
If the stereo gets to hot even when it is off, the problem can be a bad conexion and you could solve it by crossing red and yellow cables. eject the radio, check your iso connector, you can tray to cut both cables and connect them again the red to the yellow and vice versa. Refer to your manual for further information on conexions. Check also that the stereo is keeping the values you give (radio station memorys, bass - treble adjustments, etc) If the conexions are wrong, the radio doesn´t keep these values when you take the ignition key off.
Posted on Jun 14, 2011
1999 astro/4.3L/starts cold /runs 10-15 min. then dies will not start hot new battery.new coil/clean filter/pump 2 yrs old installed new/battery shows 14 amps when running/ won t crank when hot either/...
car shuts off when it gets to normal operating range. it takes 10-15 minutes to reach normal range. causes: low coolant, failing coolant tempurature sensor, air in water pump, check the coolant temp. sensor. if it is bad it will send wrong info to engine when hot, and shut it down. ITS WORTH A TRY!! good-day!
Sep 15, 2011 | 1999 Chevrolet Astro
I have noticed that the cooling fan does not work on my bdp-S350 and am wondering if it only works depending on temperature, would greatly appreciate your help, thanking you in advance. Austin Donnelly,...
The cooling fan on your BDP-S350 should work all the time, because the system gets very hot in just a few minutes. Try playing a Blu Ray disc with the volume down, with in 10 minutes the fan should start running if not you have a defective fan or control electronics. Try spinning the blade of the fan when its on with a non conductive material ( tooth pick ).
But if the fan starts running with in 10 minutes of the movie ( Bluray ) all is OK and your system has a thermal sensor built in. Its done to prevent you hearing the wind noise during a quite passage of a movie ( some find it annoying ).
Mar 28, 2011 | Sony BDP-S350 Blu-Ray Player
My subwoofer is continuously powering on and off. It powers off after about 15 minutes of no bass during normal operation. Now it just goes on and off with a loud boom.
You don't mention the make or model so a generic answer is all you get for now.
Many Subs are designed to cycle off after a typical 15 minutes of silence, so what you are seeing may be normal. Some have a control to override that. Perhaps you could look for that control.
What you are hearing is NOT normal. Perhaps the sub's amp is not staying muted while the amp respondes to the demand to turn on. That would need a tech to look at it; or you could avoid the 'turn-on thump' by overriding the idle timeout.
Retrevo.com may have a manual.
Jan 12, 2011 | Audio Players & Recorders
The hot water recirc pump in my new house was equippped w/ this timer. There was no user manual, but it was set by the installer to run the pump during awake hours and shut it off during sleep hours. ...
1) Open link below so we are talking about same type of household system
http://waterheatertimer.org/Water-heater-recirculation-system.html
2) 15 minute interval is misleading.
Pins located on timer dial divide 24-hour day into 15 minute intervals.
You set timer pins and decide which 15 minute intervals you want ON-or-OFF. Do this by moving pins inward or outward with your thumb or ink pen. To check settings, manually rotate timer dial clockwise and listen for pump turning on-off..
Set timer pins for 4 consecutive 15 minute intervals, then timer runs for 1 hour.
After pins are set, then manually rotate dial to set current time.
Dial rotates as time passes, and pins click a lever that turns pump on-off.
3) 5-year Life span. Like all things plumbing, if you have hard water or sand-n-dirt in water lines, then pipes clog. And pumps clog.
Once motor begins to slow down, it overheats and burns out.
Water softener can keep sediment out of lines, but shortens life of water heater.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
4) Real question: do you need a circulation pump? Do you need hot water at your faucet? Can you schedule hot water use, or does recirculation pump have to run several hours per day?
Recirculation pumps causes water heater to run more, the pump consumes 25+ watts depending on pump, and water savings claims of 15,000 gallons per year are fabrication.
Realistic water savings is 700-2000 gallons per year, assuming several folks in the home use water sporadically across a full day, and each time water is used people are waiting for hot water. It also assumes that you never want cold water at the tap and that refrigeration ice maker line prefers hot water to cold.
5) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on pump/timer or any do-it-yourself project.
We are always less expensive than a service call.
Dec 18, 2010 | Taco 265-1 / 563-2 Combination Analog 24...
Our snapper shuts off after 15 or 20 minutes, does start back up after it cools - what do you think?
Could be the coil. Once it gets hot it shorts out and shuts the engine down then cools off and works again. OR it could be that the fuel cap doesn't vent and allow air into the gas tank causing a vacuum lock so fuel won't flow out of the tank. Just need to clean the fuel cap vent holes. Test for spark right away when it shuts down and still hot to find out if it is the coil. If the spark is gone when hot and normal when cold then it is the coil.
Oct 30, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Table top Wurlitzer percolator not working. Any suggestions?
Wait a few minutes for the unit to warm up and the percolator will function normally....about 10 - 15 minutes is needed...
Dec 25, 2009 | Wurlitzer Jukebox CD Player
Ilo ca 3000v cd player
The RCA connections on the back of the Ilo CA3000V are exclusively for XM radio input, and do not send a 'low level' signal required for your amplifier to operate. You will need to have a 'high level' input on your amplifier to get a signal from the Ilo, this will be driven off the speaker wires themselves.
Apr 11, 2007 | iLO CA3000V CD Player
H&B CA-8050BT CD Player Logo
107 people viewed this question
Top H&B Car Audio & Video Experts
xxxxxx xxx
Are you a H&B Car Audio and Video Expert? Answer questions, earn points and help others
