Question about Hoover S3765-040 WindTunnel Bagless Canister Vacuum
I have a Hoover Windtunnel Canister vacuum model S3765. The main motor goes on fine but when I use the motorized carpet floor head, the main motor turns off (the motor in the attachment stays on).
  • 1 more comment
  • denise_bossy Sep 05, 2010
    It is the main motor that stops when I start the motorized head, so section also stops. It seems like the vacuum can't support both motors running at the same time.
  • denise_bossy Sep 06, 2010
    The problem seems to be in either the main motor itself or in the connection between the hose and the circuit to the main motor. Sometimes if I let the main motor run for 10 minutes without moving the vacuum, then I can carefully run the motorized head (as long as nothing jiggles the main hose where it clucks into the canister). Lately even this fix isn't working.
    This is not normal behavior; when the main motor shuts off there is no suction. So the motorized heads spins, but then spits back out all the dirt. Normally both heads work together to vacuum carpets. Now I can turn on the main motor but when I turn on the motorized head, the main motor cuts out. It is not a problem with the motorized head as far as I can see, but a problem with the main motor or a connection with the main motor.
  • 3,083 Answers
Hate to say it, but this vacuum sounds like "lemon" should have been it's middle name, as reported on these net reviews:
http://www.amazon.com/Amazon-should-selling-since-Hoover/forum/Fx15VTMCB3VVG0C/Tx3SKTXNJGI0DTC/1/ref=cm_cd_dp_ef_tft_tp?_encoding=UTF8&asin=B00008UI0R&store=kitchen
This blog explains a switch problem fix, which could be your problem:
http://www.amazon.com/Broken-buttons-Heres-real-problem/forum/Fx15VTMCB3VVG0C/Tx34W1XDNY219O7/1/ref=cm_cd_tp_ft_tft_tp?_encoding=UTF8&asin=B00008UI0R
It seems like either these are very good, or very faulty, from reviews.
I would run it into a vacuum repair shop and see what they think, they deal with tricky problems all the time.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 06, 2010
  • 787 Answers
I'm pretty sure this is normal behavior.
  • 944 Answers
In motorized carpet floor head, mode the suction will be different from
normal one.In this mode main motor will switch off and attachment stays
on.Two motors can stay on at the same time.The suction will be more if
the main motor stays on.So in this mode only the attachment motor stay
On.If you want to make both motors run in carpet floor mode.Then you have
to give short the main motor circuit with attachment motor so both will run.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 06, 2010
    Have you done continuity testing on the control board and find the circuit is damaged.?
  • 2,272 Answers
The suction is provided via a large motor, while the brush-roll is powered by a separate, smaller motor, which does not create any suction. The brush-roll motor can sometimes be switched off, so hard floors can be cleaned without the brush-roll scattering the dirt. It may also have an automatic cut-out feature, which shuts the motor off if the brush-roll becomes jammed, protecting it from damage.
So check the brush roll and clean it.then again check if motor turns off .
Check out.Keep updated.Thanks.
Posted on Sep 05, 2010
Hoover S3765
If you light and nozzle motor both go off at the same time, you might have a bad power cord. Mine had this problem which I could verify by jiggling/twisting the cord near the strain relief on the nozzle. It would go on and off as I did this. The cord is cheap to replace, around $13 for the part shipped. Part number is 59134072.
May 30, 2012 | Hoover S3765-040 WindTunnel Bagless...
The carpet brush won't revolve on the Hoover S3765. After 5 months I replaced the belt and the salesman gave us model 38528-036. Is this correct? The rotating brushes are not hard to turn; it's just...
this is the part for the belt, 38528036. you can get it at sears website or service center. also make sure you clean the caps on the side of the brush. take them out and remove hair and dirt. put a little or mineral oil and install them back.
good luck to you.
Feb 08, 2011 | Hoover S3765-040 WindTunnel Bagless...
Hoover S3765-040 vacuum cleaner. At high motor speed, starts to smell something burning. Opened the motor assembly; removed the motor from its housing; powered it; and see major sparking where the bushings...
You are correct, the motor is done. Look at your local vac store for a quality vacuum made by Sebo or Miele. Replacing motors in chinese made vacs is a waste of money as the whole product was made to last only a couple of years
May 31, 2017 | Hoover S3765-040 WindTunnel Bagless...
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
My daughter's S3765 bagless canister has good
That means that you need to replace the belt. Here is the belt you need for your model.
Dec 20, 2009 | Hoover S3765-040 WindTunnel Bagless...
Belt will not stay on hoover windtunnel s3765
The Hoover Windtunnel™ Self-Propelled models have two belts, a flat belt and the V-Belt. This V-Belt is the one that drives the Brush Roller. After about three months, most belts stretch out causing them to slip. This means the brushroll turns slower or not at all and the self-propelled becomes increasingly harder to push. It is recommended that both belts should be changed at the same time.
May 23, 2009 | Hoover S3765-040 WindTunnel Bagless...
Hoover s3765 windtunnel power head does not run
I have the exact same problem as you have. Have you found a solution since you posted on Mar. 18, 2009? Thank you.
Mar 18, 2009 | Hoover S3765-040 WindTunnel Bagless...
Carpet power head will not stay attached to telescoping wand
to answer your last statement, if you do not have a receipt, the warranty will go by the date ofyour serial number. the first 4 digits are the month and year. this model usually has a 1 year wty. the wand button may not be protruding as far due to dirt under the metal band. however you may still have an issue with the neck on the powerhead which will require shop service.
Jan 18, 2009 | Hoover S3765-040 WindTunnel Bagless...
Hoover S3765-040 WindTunnel Bagless Canister Vacuum Logo
240 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
