Display panel on dv9040us has opened up
The display panel on the left bottom corner where the lock is, has opened up and it now difficult for me to close the laptop nor open, with great difficulty i need to press the panel togather and close the laptop and vice versa while opening. suggestions for me to get this rectified. my location area is baltimore, MD 21206.
    Scholar:
  • 72 Answers
Could you post a picture of your problem? The issue is probably that the screws holding the monitor mount to the rotating piece have stripped and come out, and the small piece that is meant to stay screwed in is spinning freely. This can spread that area out and pop open the monitor casing.
You can pop off the small rubber "feet" that go around the monitor to gain access to the screws. You may be able to position the monitor in the correct angle and screw it back in with a precision screw driver. If this was the problem then this is most likely a temporary fix. If the screw has come out once, then the groove is stripped and it will happen again. You'll either need a new screw or most likely a new hinge in the future.
Regardless, try posting a picture and I'll be able to help you more.
Posted on May 12, 2008
Samsung ue65js9505
There is no repair to a broken display panel. Contact the authorized service center for Samsung to get it replaced. The display panel to this TV is not available at open electronic spare part market. If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 14, 2016 | Samsung Televison & Video
NO AUDIO COMING OUT.
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the left top left corner of the display window. It will make search easy. Some times, the ads attached with each posts both at the right and bottom, might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs now. Will be updated daily. Detailed description about common faults to Plasma TVs are described here in detail. It is very difficult to type all of them here.
Aug 20, 2012 | Panasonic Televison & Video
Display problem
Sounds like the LCD has some damaged crystals in it. Try connecting the netbook to an external pc monitor using a VGA cable. Hold the Fn key and hit the F8 or F7 key until the display shows on the external monitor. This will determine if it's a driver/settings or display issue. If the display is fine on the external monitor, the LCD display on the netbook is the problem. Good luck!
Jun 06, 2012 | Computers & Internet
Resolutions too high,k how to change?
Windows 7:
  1. Right click your desktop, click Personalize.
  2. Bottom left corner, click Display.
  3. Top left corner, click Adjust resolution.
Windows XP:
  1. Right click your desktop, click Properties.
  2. Click the Settings tab.
May 23, 2011 | Computers & Internet
HOW DO I CHANGE THE FONT SIZE. I WANA MAKE IT LARGER.
One way to adjust/set the default size (to get a larger font size) is through your Control Panel - Display - Settings window, where you can select a larger font.
If you are using a browser (e.g. Internet Explorer), there is way to increase (or decrease) the font size (displayed on the screen) using the "magnification" option at the bottom right corner of the screen. Simply click on the "magnifying glass" and increase/decrease the value, e.g. to 150% .
Jan 02, 2011 | Acer Aspire One PC Notebook
How do I change resolution on monitor?
that is easy
go to control panel
go to appearance and themes
go to display
go to settings
near bottom is screen resolution select the resolution supported by your video card.
Nov 18, 2009 | HP Compaq WF1907 Monitor
White screen
you have to open the panel and then have unscrew the screws of your mobile after you can see the display connector at top or any corners of the bottom of the display if you refix that connector you will get display orelse have to change the display.
Oct 30, 2009 | Nokia N70 Cellular Phone
Water in LCD display
Once you get a dead pixel (black dots), there is no way to repair that part of the screen
Sep 20, 2009 | Computers & Internet
My computer wont open
Hi woc169! Your problem may be related to an HP recall/repair announcement regarding left side hinge defects. Go to http://www.hp.com/#Support or call the number at the end of this message. Hope this helps!
HP Limited Service Enhancement for Left Display Hinge
HP has identified a hardware issue with certain HP Pavilion dv9000, dv9100, dv9200 and dv9400 series notebook PCs.
Step 3: Identify the symptoms Ifyour computer’s product number is listed above, and the notebook PCexperiences one or more of the symptoms listed below, contact HP duringthe Duration of the HP Limited Service Enhancement to determine whetheryou are eligible for a free repair. Symptoms of a broken left display hinge include but may not be limited to the following:
  • Whenopening or closing the display panel, you may hear popping or cracklingsounds from the bottom left corner of the display (left hinge area).
  • When opening or closing the display, the display may feel loose or wobble in the lower left corner.
  • The plastics surrounding the left display hinge may show cracks or breaks.
Service enhancements and free shipping
NOTE: This HP Limited Service Enhancement program is available in the United States and Canada through May 31, 2009.
  • Free shipping Ifyour notebook needs to be returned to HP for repair, the shipping costsare free. HP will immediately send you a postage paid container inwhich to send in your computer, and we will pay the return shipping. AfterHP receives your notebook PC, HP will use its best efforts to repairand ship your notebook to you within 10 to 14 business days.
  • Post-service warranty The HP repair warranty covers the left hinge repair for 90 days after HP returns your notebook PC.
Contacting HP To contact HP in North America call 1-866-671-7362 from 6:00 am to 11:00 pm MST, 7 days a week.
Dec 16, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
David Payne
David Payne
