Question about Linksys Wireless-G Broadband Router
Wireless G Broadband Router
I purchased my router in 2005 and now Linksys says warrenty has esxpired. My problem now is I am disconnected. Can you help me get re- connected?
Thanks,
Melissa
  • Jeffrey Pedimonte
    Jeffrey Pedimonte May 11, 2010
    Melissa,
    Who is your internet service provider and what is the modem that you are using? this will help to properly help get your connection back.
Some thing like that happen to me my old laptop had a wireless (g) card in it and my router was a (g) the new laptop did not require a card. the new system is (n) so I had to buy an (n) router and a wireless (n) card. Although I think the (n) router will work with a (g) card. also if you have a disk you might have put a pass word on it during the original install. but you can always try to reset the modem and router simply by removing the power sourceor useing the reset buttons..Good luck
Posted on May 12, 2008
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "192.168.1.1" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696 Wireless G-Broadband Router support http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 27, 2013 | Linksys Wireless-G Broadband Router
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
Blinking power light - router not working properly
Blinking power light on the Linksys routers indicate 2 things. 1st is firmware problem, 2nd is the worst one which is defective router. You can still revive it if you can reload the firmware. If not, it's a dead one and you need to purchase a new one. And man, your router is a very old one. You must switch to wireless G router, its 5 times faster than your wireless B and it only cost 30 or 40 bucks
May 09, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
How can i reset my Linksys Wireless-G2.4GHZ Broadband Router settings
Try to reset the router. This should resolve your problem. That model has a small hole were you must press with some a paper clip for exemple for a few seconds. This will reset the router to its original state.
Nov 07, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G 2.4GHz Broadband Router
If you press and hold the button o the back of the router that says reset for 30 seconds, the router will restore factory defaults. Then, your routers password will be reset to "admin"
Apr 12, 2008 | Linksys Wireless-G Broadband Router
Linksys BEFW11S4 wireless router disconnects
upgrade the latest firmware to this router that will fix your problem..log in to linksys.com/downloads..and download the latest firmware version
Nov 18, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
Wireless G broadband router
Please go to www.linksys.com/download and download firmware version of your router. For manual upgrade call linksys at 18003267114 or check out other linksys numbers.
Oct 15, 2007 | Linksys Wireless-G Broadband Router
Linksys Wireless-G Broadband Router Logo
42 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
