Question about Gateway Computers & Internet
Dropped my laptop. It didn't shut down or anything it ran just fine. When I turned it on this morning it would not start and prompted me to do a system restore. Started that but it didn't complete because it ran into an error. How do I fix it? Should I try recovery using the disc? My laptop is a Gateway MT6729
  • 95 Answers
Hi adaery,
If your laptop still boots up to bios you should be ok, you should use the recovery disc so that you can check if there is a possible damage done to your harddisk.If it lets you install a new os you should be ok. Update me on the current situation.
Hope it helps,
thx
Banaple
Posted on Sep 05, 2010
  • adaery Sep 05, 2010
    Ok. I will try the recovery from the disc. Will let u know.
    President:
  • 2,571 Answers
When you dropped it you will have caused the Hard drive arm to contact the surface of the hard drive, damaging it.
Unfortunatly, it looks like it damaged the Boot files, Its worth a try with the recovery disc, you may need a new hard drive if it fails with the recovery disc
  • banaple Sep 05, 2010
    If you can open the laptop also try to unplug/re plug your harddisk that might fix the problem.If not if you have a stock harddisk try putting it on. Also try to transfer your important files to another harddisk before using the recovery disk.
    Thx Banaple
  • Roy
    Roy Sep 05, 2010
    banaple is tight, it would be worth taking the hard drive out and refitting it, you may as well re fit the memory while your at it.
    Good luck
2004 900 efi mountain cat no start, seems like no spark
try unplugging the throttle switch to see if its ok. then of course replace...thats a quick sled
Sep 01, 2017 | Arctic Cars & Trucks
2003 Liberty. Starts and shuts off
may be a thermostat working intermitently , water pump the same or overheating, keep a look out for anything that is unusual
Jun 03, 2017 | 2003 Jeep Liberty
98 ford explorer wont start.. started fine shut it off and it will not start turns over but wont start
Use a bottle of yellow HEET dry gas to remove any moisture problem in the fuel.
Clean / replace air filter.
Top off ATF to MAX level.
Use starting fluid to aid starting.
Nov 25, 2012 | Motorsports
I dropped my acer 5111 laptop and the screen broke i know how to fix that but the problem is ive tested it linking it up to my tv with hdmi and when it loads up everything is either slow or not loading...
If it didn't go to sleep before you dropped it, then it's not going to sleep after you dropped. It's shutting down or malfunctioning because of something else. You could have caused the memory to shift, or the hard drive to shift or something that happened because of the sudden impact.
May 13, 2012 | Acer Computers & Internet
2003 NSR125 lights all went out on the way to work this morning & Rev counter dropped to zero and didn't move although the bike didn't shut off as soon as i turned the engine off no electrics...
you will need to find out if the battery is being charged when the motor is running.if it isnt you will have to check wiring from the charging system.There could be a problem with the regulator/rectifier unit.
Jun 17, 2011 | Honda NSR 125 R Motorcycles
I have a used Dell Inspiron 8200, it has not been cleaned out but it worked fine when I got it, I ran a System Restore and used it until about four days ago when the computer froze. I shut it off, (did not...
Severe corruption. Since you can no longer boot in any way in it it's going to be extremely hard to fix it. Better just reinstall Windows from scratch. Use the recovery cd that should have come with the laptop. If you don't have it then just use a disk borrowed from a friend and the key on the label.
Jun 14, 2011 | Dell Inspiron 8200 Notebook
My brand new LG Cosmos Touch phone won't turn on. Installed battery and ran through start-up and phone seemed fine. It then downloaded updated software, still fine. Plugged in charger to charge battery...
I bet you got help and fixed it already, but I had the same problem. Just before it stopped working, I dropped it in a puddle by a curb and I thought that killed it. I didn't realize that my battery was dead! That was it, so charge it!
Feb 18, 2011 | LG Cell Phones
When I boot up the screen is all colors and lines
It sounds to me like your cable is loose to the lcd or the video card is not properly 100 percent seeded into the mother board. Prolly the cable in one way or the other, perhaps bad cable.
Nov 21, 2008 | Toshiba Satellite A215-S7422 Notebook
Toshiba Satellite shuts down and won't boot up again.
Have you installed any new hardware or loaded any new software lately? If not you might have some corrupt files. Reboot the laptop in safe mode. Just hit F8 a few times. It should give you a menu. Arrow to safe mode and hit enter. After it finishes booting to safe mode, do a system restore. Click Start>click Start>Accessories>System Tools>System Restore. Choose a date before a couple of days before you noticed anything happening. Restore will take a few minutes. When it's restored and booted, I want you to do one more thing. Click on start>run>type in cmd and hit ok. This will take you to your command prompt. Type chkdsk /f It will tell you it can't run it right now do wan't to run it the next time you start up? say yes. Close the window. Restart the computer and the check disk program will run and fix your errors.
If this has fixed your problem please rate it as fixed. If nit, just add a comment add I'll be happy to help you out more. Thanks.
Apr 10, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
41 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
