Question about GE Refrigerators
My GE profile french door bottom freezer drawer does not, & never has, closed unless I slam it with all my might & push hard at the same time. I have owned it for 3 years & this is driving me crazy. It runs constantly & freezer items have the white layer of frost on them if it doesn't get slammed hard shut. Even when I push/slam it frequently does not close. I have defrosted it, tried it totally empty of items, checked for anything behind the drawer, checked the seal for damages. If friends stay at my house without me monitoring it, it is basically left open.
  • jodypetersen Sep 06, 2010
    Hi There,
    Thanks so much for trying to answer my question. I did figure out the problem finally. My builder, who installed it, never bothered to level the fridge. Once I raised the front up at least 1/4 inch higher than the back it is working well & sealing fine. Geeez!
  • GE Master
  • 1,711 Answers
This problem usualy is fridge level problem.
You need to adjust slightly hieghr at front 1 to 2 cm and be also very good level so the drawer guides not been blocked.
If you do this and not be fiexed then you have to replace the drawer guides.
Posted on Sep 08, 2010
  • 3,083 Answers
I'm thinking that the doors may be slightly out of adjustment, not allowing the freezer door to seat properly. Here's a blog on how to adjust GE Profile doors:
http://www.ehow.com/how_5678804_adjust-ge-side-side-refrigerator.html
You might be able to bring your model up at the following website, and it has diagrams to aid in troubleshooting:
http://www.appliancepartspros.com/
Here is a comment from homeownershub.com about closing the freezer door:
Don't shut it so hard and fast. There s a duct carrying cold air from
the freezer section to the refrigerator section. When you close the
door hard, a pressure wave travels through that duct and opens the door
to the other section. The freezer compartment is usually smaller so
there is less volume to absorb the air pulse traveling through the
duct. f you close the refrigerator door slower, the air will go out
around the refrigerator door and not travel through the duct between
compartments.
Not sure if that might be your problem. If the damper is closed, it will not allow the freezer door to close easily and fast. Maybe that's what's going on.
Anyway, hope this helps, and thanks for using FixYa.
Posted on Sep 05, 2010
GE FRENCH DOOR REFRIGERATOR DOES NOT MAKE ICE
First thing to check is if the freezer temperature is going down low enough for the ice maker to work - around 10 degrees. The icemaker thermostat will not activate the mechanism (cam motor) unless this requirement is met.
Nov 27, 2013 | GE Profile PFSF6PK Bottom Freezer French...
GE French door fridge problem. When you close one door the other door pops open alittle most of the time. Is this normal on french door fridges?
Hello, In a word, Yes. It is totally normal, when you close a door it pushes air into the unit and depending on how it is closed the other door will "pop" open slightly from the "push" of air. Thanks for coming to fixya. macmarkus :)
Jun 20, 2010 | GE Profile 20.7 Cu. Ft. Side-by-Side...
Top lock on GE Profile Fridge is broken
bad news you have to replace the door gasket
they only sell them in pairs and not cheap
Jul 03, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
Bottom freezer door/drawer won't close all the way on one side.
Remove all the food from the freezer and then the drawer from the cabinet. Now using a silicone based lubricant, lube the tracks up real well. Be sure to clean the tracks first if gunked up. Make sure nothing small fell out of the basket over time and is laying on the floor in the rear of the freezer section. Once done, you should be fine.
Eric Campion
Feb 21, 2009 | LG LRFD25850 French Door Refrigerator
GE Profile 25.1 cu. ft. fridge is too large for door entrance
yes you can, or just removed the bottom drawer, open the upper doors and slide the refrigeraro thru the doorway by just swinging it thru. a mover friend of mine showed me that trick at it work great.
Jan 24, 2009 | Pds GE Profile Bottom-Freezer Drawer...
Bottom drawer does not properly close
Okay, I fixed it for now. The design for this bottom freezer drawer is not good. What happened was most likely that my son slammed the door, and it bounced and was slightly open. Overnight, ice started to form all over the compartment, including inside the drawer guides. Some ice was probably obstructing the drawer glide from sliding shut.
What I did, not thinking this was the solution, was to prop chairs against the drawer to close it while I searched for answers on the Internet. In the meantime, some of this ice must have refrozen in the closed position (due to the weight of the chairs). When I went to check it later, I had a little trouble opening the drawer. I gave it a hard yank and some small frost flew off, as I opened the drawer.
It was not easy sliding it due to the frost. I then moved it out and in until it felt smooth, and finally closed the drawer and it stayed in the shut position.
Kids are instructed to close the drawer gently and visually check that it is sealed. There is also an air passage between the refrigerator unit and the freezer so that when you close the double french doors, some air pushed to the freezer section and momentarily pops the drawer open. You should make sure that the drawer closes before leaving the kitchen. If you are on vacation, prop chairs to make sure both the freezer drawer and the french doors stay closed. This is important if you're in an earthquake area as a small tremor could open the doors and you'll get a fire when the lights stay on and burn through the wiring (as others have noted).
Dec 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
120 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
