Question about Makita RF1101 Electric Routers, Fixed & Plunge Routers
My makita 3612B plunge router will not turn on. Power switch is working fine so what else do I need to check?
Makita plunge saw blade not sprining back to housing
233479-2 is the correct ordernumber
Drukveer 11 pos 30 only a spring is responsible to push the whole machine also with the sawblade up.
The machine has had an accident or something is piece of wood or something on top in the mechanics of the machine that will block him.
Oct 05, 2015 | Makita SP6000K1 6-1/2" Plunge Circular Saw...
What hp router is best to make cabinet raised doors
I used to use a Ryobi 2.5 hp and it worked fine but if you are concerned go higher hp. It's probably more important that the router is a variable speed model. The bigger the size of cutter required for raised panel doors the more torque and revs are produced. You need to ensure starting on slowest speed and adjust up to speed required. Speed should be based on size of cutter and to me is set by sound( a nice hum, not screaming) and vibration( NO VIBRATION)! The cut needs to be done in several passes, maintaining constant feed speed,( don't burn your expensive cutter) allowing cutter and machine to do work maintaining the hum and no vibration. And of course set your guards etc!! If this is on going work for you perhaps look into a spindle moulder with attachment to take router cutters
Cheers Capt Mark
May 10, 2014 | Makita RF1101 Electric Routers, Fixed &...
How to replace on off switch on makita router model 3600b
go to makitausa.com and you can download a breakdown for this tool. If you need more assistance let me know and I will help
Dec 28, 2011 | Makita & Plunge Router
My 12 year old plunge router 7529 does not start. It worked just fine a couple of days ago and all then sudden... nothing. Any suggestions!
A 1 year old router...that suddenly stops working. My suspicions would be brushes first then the switch.
There are 3 different types of this router Type 1, 2, and 3.
Parts can be found here:
http://www.ereplacementparts.com/porter-cable-7529-type-plunge-router-parts-c-129_1672_1985.html
Brush is item 3 and switch is item 4.
pdf of diagram: http://www.ereplacementparts.com/images/Porter_Cable/7529_TYPE_1.pdf
Thanks for choosing FixYa,
Kelly
Kelly
May 11, 2011 | Porter Cable Garden
I have a makita rd1101 2.25 hp router it has adjustable speed. the router has been used maybe several times. Just recently while using it the speed will drop down for a few seconds and then rev back up...
Vince, it sounds like you will have to replace your variable speed module. It is item number (5) in the breakdown and runs about 80.00.
The part number is 631397-2.
http://www.makita.com/en-us/Modules/Tools/ToolDetails.aspx?ID=270
Click on the Parts Beakdown Icon on the left hand side of the page. I hope this helps, let me know if there is anything else you need.
Nov 25, 2010 | Makita RF1101 Electric Routers, Fixed &...
Rf1101 makita router lost serious power and is sounding wounded
You dont have to take the armature out to look at the commutator, just remove the brushes (unplug tool first) and get a flashlight and look into the brush tube and slowly turn the shaft by hand and look for a discoloration or unusual look on the comm bars. The slight burned smell might have come from the speed control or the switch itself, but look at comm and then go from there. You can get a breakdown for this tool at Makitausa.com. Let me know if you need any more help
Feb 19, 2009 | Makita RF1101 Electric Routers, Fixed &...
Freud 3 one fourth plunge router variable speed won't run
Hi
First check the power suply cord(conductivity),the on/off switch, the fan and the armature,the brushes and the wires.
best regards savumihai71
Jan 05, 2009 | Freud FT2000E 3 Router
Makita RF1101 Electric Routers, Fixed & Plunge Routers Logo
80 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
