I use a tascam dm24. i am getting drop out when my music is playing. i also get a static sound sometimes after drop out.
    Genius:
  • 1,224 Answers
Ok question when you play music is off cd or comp. or mp3 player
reason i ask is cause some cd formats and songs come with the distortion on them the manufacture does not see this cause mass production in cd's
turn onto a receiver fm tuner if static is still there power failure is common in the power house inside receiver these require maintenance and probably new power house conductor
dust in the system can create static also hair and dust are magnatized this can distort the sound quality professional cleaning of system is probably needed in this case
Posted on May 12, 2008
I get no response from my Tascam US-144 and windows 7.
Go to program,look for tascam folder and adjust channel 1&2 to analog.This should make your music program work fine.And then do research on both analog and digital recording.
-William Marcelin
Apr 09, 2010 | Tascam US-144 Sound Card
The click track on my TASCAM 2488 Mk 2 won't click
There is likely an amplitude setting (probably available in a menu) for the click. Make sure that is turned up.
Jul 18, 2009 | Tascam 2488mkii 24 Track Recording...
144 drops out
To see if it's your hardware, up your latency settings to "highest" via the tascam control panel. Also, be sure you are familiar with the various ways to up latency in your recording package: in cubase it's under device settings, vst bay. If this works, you know it's some setting somewhere. Try disabling your internet connections and setting pc performance to "background services" Also, read a pc optimization guide for daws - they are everywhere. Tascam will email one to you if you ask.
Lastly - try the asio4all driver. This fixed my pops, but when I understood all the various latency settings and set the tascam to highest latency, I could use the tascam driver. Highest latency on my p4 3.0 2gb ram pc means 12ms input and my output is 61ms.
If the asio4all driver works - it's a likely latency issue.
Jan 25, 2009 | Tascam US-144 Sound Card
Tascam CD-RW4U
Try adjusting the input level so the meter stays close to 0 when recording. It sounds like the levels are too hot.
Aug 04, 2008 | Tascam CD-RW4U CD Recorder
Tascam 144
Check pan control and then try another set of phones...accordianman
Feb 12, 2008 | Tascam US-144 Sound Card
Hellp!
Are you hearing the sounds from your speakers on your computer only?...accordianman
Feb 03, 2008 | Tascam US-144 Sound Card
Problem with tascam dm 24
Firstly well done for buying an excellent quality mixer. I take it you are referring to a software sequencer (if not why not) to take advantage of the DM24's firewire streaming and eliminate the need for a separate audio interface.
A choice of sequencer really depends on your application as they all have varying strengths and weaknesses, however one thing they all have in common is that the DM24 can be used as a control surface for all the major sequencers.
Cubase - easy to learn and user friendly, however the selection of virtual midi instruments and effect plugins is pretty limited and not great quality. Also it can be a bit unstable if you are using arrangements with lots of recorded audio parts. Its more at home with MIDI applications where you either have your own outboard synths or you have purchased a good set of softsynths.
Logic (Mac only) - Not quite as intuitive to use, however the selection of virtual instruments and FX bundled with the package are excellent quality. Also is a lot more stable for audio applications since it has been programmed to make more economical use of your system resources. This is a good choice if you are multitracking bands and have a lot of audio parts to deal with.
Sonar - this is basically the PC equivalent of Logic though there are a few differences.
Pro Tools- the biggie, and also the most expensive! This is a good all rounder, not had a huge amount of experience with it myself but pretty much every pro studio in the world uses tools and the built in plug ins are second to none.
Note all these have LE (learning edition) versions as well as the full versions, where the LE's are slightly stripped down versions of the full. Look at what your requirements are and make a decision based on whether you are likely to use the advanced functions of the full versions.
Finally if you have the budget, have a look at Reason. This is a virtual synth rack and can be used either stand alone or plugged into your main sequencer. Loads of excellent drums sounds, one great synth, one OK synth, the rex player which is excellent, and a good sampler. If you can justify the cost its well worth having.
Nov 30, 2007 | Tascam Quantegy 120 Minute Digital Audio...
75 people viewed this question
 Grubhead
Grubhead
