Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
MAGNAVOX 32MF231/37 WONT START IT CLICKS A COUPLE OF TIMES WHEN YOU PLUG IT IN AND THEN ABSOLUTELY NOTHING, NO PIC, NO SOUND, NO LIGHTS, NO NOTHING....HELP??????
Slinteriors
  • 8617 Answers
SOURCE: magnavox 51mp6100d/37 power light flashes and
you can get replacement boards from www.tvrepairworld.com you can call or send them a email they respond quickly.
Posted on Apr 16, 2010
Shuttle83
  • 1139 Answers
SOURCE: Magnavox 51MP392H/17 No pic only sound
Hello winwithrose,
The popping sound may have been a capacitor. The chance are the capacitor is in the HV section of the TV set and is part of the supply to the Horizontal section of the TV. First if you do not have electronics experience I would suggest you take the TV to a qualified TV repair shop. OK now if you have electronics experience I would say to unplug the TV, open the set up and do a physical inspection of the TV you will be looking for a capacitor that has exploded; if you find one look at the schematic for the TV and find its value. Then do so checks to find out why did the capacitor explode. Most likely the capacitor exploded because of wear and tear, but it always pays to check. Replace the capacitor with one of the same value and then turn the TV on, use your voltmeter to measure the voltage across the capacitor to make sure its the same or close to the value on the schematic.
These are the basics of what to do
I hope this helps
Thank you,
Shuttle83
Posted on Sep 21, 2008
freetek
  • 5568 Answers
SOURCE: phillips magnavox Rear Projection TV 7P6033W101-Dead
The clicking you hear is a relay that repeatedly connects, then disconnects the AC to prevent fire or further damage.
If it just fails to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Oct 31, 2008
Zero-G
  • 33 Answers
SOURCE: philips rear projection tv-wont turn on
Sounds like your Convergence chips failed, were your red/blue/green colors slowly seperating or was the picture starting to curve on the top or bottom or both? if so see below general post.
Also what model # is your TV and what size?
51MP392H/17
Actually I have this TV and you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got all my parts that worked:
Suburban Electronics http://www.suburban-elect.com/
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
What you need:
(2) STK392-120 OR STK392-150 IC chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
BTW if you don’t plan on trying this and are going to throw out the TV, I still need a IC convergence board for a 51MP392H/17 TV I'm fixing, I'm willing to pay S/H and buy your IC board that’s not been tampered with. Edwinkraus@hotmail.com
Posted on Nov 20, 2008
  • 46 Answers
SOURCE: my magnavox model 50MF23ID/37 is 4yr old. tv wont
If you hear a clicking noise that sounds like the ballast trying to power on the lamp, but nothing happens, the lamp may be faulty.
http://www.discount-merchant.com/
Here you can get your lamp that most likely needs replacing.
Posted on Mar 27, 2010
Testimonial: "thank i'll try it"
1995 MAZDA MPV. I THINK IT MIGHT BE COIL. REPLACED BATTERY. THEN STARTED A COUPLE TIMES WITHIN HOURS THEN NEXT DAY NOTHING. JUST CLICK WONT START AGAIN FULL START FEW TIMES DEAD NEXT DAY
u have to make sure nothing is draining the battery. It sounds like a drain or it may be a fault in the ignition (starter etc) if all else is working.
Apr 07, 2017 | Mazda Cars & Trucks
Wont start!! HELP!!!
Check your fuses. Likely burned one up for your ignition.
May 24, 2014 | 2000 GMC Jimmy
Wont turn over
The starter is most likely the problem,tap on the starter lightly with a hammer while trying to start the engine,dont get run over doing this it will take two people,if the engine starts,the starter needs replacing.
Apr 25, 2010 | 1998 Jeep Wrangler
My magnavox model 50MF23ID/37 is 4yr old. tv wont
Mar 26, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
42' plasma magnavox model # 42MF230A has no picture and no sound
I had the same problem with an Insignia 42" 1080p. Turn off the tv power and disconnect all cables (i started with power cable, then HD cables then HDMI). Wait 30 seconds with nothing plugged in, then I plugged everything back in (in reverse order) and it works fine.
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
MAGNAVOX 32MF605W/17
Hi my name is Eric,
I hope I can help you with your issue ,
 You main a bad mainboard, a repairman will charge about $450 to replace it , use google to try and locate one yourself
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Sep 26, 2009 | Philips 32MF605W Television
Acer Aspire One Netbook ZG5 will not turn on
you should be able to press ESC to exit hibernation, or remove the battery, remove the plug, press and hold the power button for 60 sec, and reinsert battery and power and turn on. when restarted, right click on desktop, click properties, and click the screen aver tab, click the power button, click advanced, and remove the check box beside enable hibernation on the "Hibernation" tab. it shouldn't do it again
Apr 20, 2009 | Acer Aspire One Netbook 8.9" Notebook
No pic no sound, power on
NO PICTURE NO SOUND THAN CHECK THE SESTOM CONTROL IC IT IS FAULTY
Mar 29, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Phillips magnavox Rear Projection TV 7P6033W101-Dead
Oct 17, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
87 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
