Question about Kenmore Refrigerators
Refrigerator not getting cold, freezer works and is cold but nothing happens to the climate in the refrigerator even when adjusting the control/setting
  • Kenmore Master
  • 17,130 Answers
If the entire cooling off the fridge is down then it is important to get this checked for the performance of the compressor and gas pressure.
If the pumping of the compressor is down ,thenit is possible that the cooling can drop. Just shut off fridge for about few hours and restart. If the cooling does not return then the compressor is faulty.
The same goes for thelower gas presssure.
If the cooling of the freezer is intact then the fault can be the failure of the fan, blocking of vent which can be rerlated to the thermostat or auto defrost timer.
Posted on Sep 05, 2010
My refrigerator part doesn't get cold anymore, only the freezer top get cold, even with temp adjusted to nine
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 24, 2011 | GE Refrigerators
Freezer works now and fridge still warm
your right the air is not getting through the cold coil / when you defroated it . did you remove the back of freezer . if not there is still 2 in of ice back there blocking the air flow/ now a good defrost is needed but you need to correct the problem of why this happened . either the timer / heater or defrost termminator is bad . usualy its the heater.. mm hope this helped .. feed back pls
Feb 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer working but Fridge not cooling... Tried adjusting temp to max cool and nothing. Unblocked vents, still nothing... Pulled off back panel cover to vacuum and brush... still nothing... help??? In case...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Oct 26, 2009 | Amana ARB1917CSR Bottom Freezer...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator is not getting cold
Unplug it and let the freezer thaw for a day - there is likely ice buildup between the freezer and refrigertor side - which is not letting cold air get to the refrigerator side. Remove all food from the freezer and the refrigerator, and let the freezer totally defrost (allow 24 hours with the doors open) then plug it in and you should see a noticable difference. If that does not work, the fan could be bad. There are two fans, one in the back of the fridge down low on the outside, and one in the freezer behind a back panel on the inside down about half way. Try the defrosting first which should be the solution, and the easiest fix.
Aug 15, 2009 | Kenmore 53642 / 53644 Side by Side...
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not cold/Freezer cold.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
Jul 03, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Both freezer and fridge Not cold on top
sounds like the circulation fans are jammed/seized or faulty -try a full defrost and see what happens after that.
Apr 04, 2009 | Refrigerators
Freezer Working, but Fridge side is not cold.
ou most likely have a defrost problem is there a large build up of frost in the back wall; of the freezer??
Jan 26, 2008 | Frigidaire FRS26KF5C Side by Side...
Refrigerators Logo
59 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
