Hard drive problem
Hi I have an e machine PC and i was having problems with my PC recognizing its hard drive so I took the hard drive out and placed it in another PC and it still did not recognize the drive. Is something wrong with my mother board. Is there anything I can do to save my PC? I have everything saved on that Hard Drive and I cannot access it..Please help
  • 4 Answers
Go to My Computer right click and select properties and under Device manager click under Disk Drives uninstall the drive. If you cannot see your hard drive then select scan for hardware changes. Also when you start your computer click on F12 and go into BIOS settings and check if you can see your hard drives
Posted on Oct 05, 2014
  • 37 Answers
You said that the HDD didn't get recognized even when it was connected to another computer. In that case, the problem is with your hard disk drive, not with *********** board. Get the hard disk checked by a technician.
Posted on May 13, 2008
Dell desktop 520 doesnt recognize hard drive
Sounds like a bad hard drive or a BIOS problem. If you have access to a working PC, try connecting the hard drive (providing the connections match) and see if it's recognized. Try borrowing another hard drive to see if your machine recognizes that one. Your bios is a good place to begin.
Jan 02, 2014 | Dell Computers & Internet
Have an acer aspier 3620 - it is saying operating system not found and giving me an error pxe-e61 - media test failure, check cable, it isn't even recognizing hard drive - took out hard drive and put in...
Yes, you have hard drive problem, you get PXE error becuase when it cannot bootup from hard drive, it will try to bootup through he network instead. The hard drive must show up in the BIOS. You can verify by try it in another laptop if you can.
Nov 13, 2009 | Acer Aspire 3003WLCi Notebook
I plugged my seagate into my mac OS and backed it up first, then went to my pc running windows xp and tried to locate the seagate drive and couldn't. Can I only use the Seagate on one machine or another?
If you are planning to use the Seagate Hard Drive on a PC and MAC better format it on your MAC Computer thru disc Utility and choose MS-DOS. This should solve the problem.
Mac has the ability to recognize a FAT, NTFS and MAC File System for the hard drive but the PC Computer cannot recognize MAC File System.
Check on your mac the File system of your hard drive.
MAC OS Extended
MAC OS Extended (Journaled)
If this is the file system then you now know that it will not be read by PC.
Also formating it with the use of PC will only result in an NTFS File System, and it can be read by Mac but it is only in a Read Only mode. You cannot copy paste or even erase on the drive having an NTFS on a MAC.
Aug 13, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Dell Latitude C610 doesn't recognize hard drive
when you took out the old hard drive
there is a black hard drive connector
this would have holes to push on to the new hard drive
without this, it will not plug into the motherboard
be careful if one of the pins breaks the hard drive wont work
Jul 21, 2009 | Dell Latitude C610 Notebook
My simpletech signature driver 320 is not recognized by my PC
I had the same type of problem and found when I took the cover off that the harddrive worked loose from the plug. Pushed back into socket and reassembled, works great.
Dec 29, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Hard Drive won't boot Windows
yes.. because the booting information and booting files are sored only in active primary partition of a hard drive. i.e primary drive. if you remove the primary it wont recognize the OS with out booting information. you should need to reinstall OS.
Dec 22, 2008 | HP Pavilion dv6000z Notebook
The motherboard cannot detect the hard drive/ hard disk
You cant install xp on one machine and then move the drive to another. By nature the xp install is tied to the hardware of the machine it is installed on
May 22, 2008 | Dell OPTIPLEX GX110/200 PIII-866MHz 256MB...
Won't recognize my USB
i have a feeling its not the hard drive thats bad i think it sounds like the case .
you can try buying another case and transfering the hard drive to it the case is around $20.00
Nov 30, 2007 | SimpleTech 250GB USB2.0 7200 RPM External...
HDD not recognised
HI Your Hard Drive is previously formatted and have done different partition provided by your previous machine where you took this hard drive from. Use "The Partition Magic" Software, it will help you to fix and repartition your hard drive in the new format. I have this problem before and now my hard drive can connect with any computer. The key in this issue is any hard drive goes with the original machine has been formatted and do its own partition from manufacturer so if you take it out later for use with other machine, you will need a software to completely rearrange the new partition in universal format so other computers can recognize it. This manufacturer purpose to protect your data from hacking, stealing once you take it out from the original machine. That is why when you connect it to other machine, this hard drive will not be recognized. I has this partition magic software and can make you a copy so you don't have to buy it. Just read the instruction and you can fix it for both 2.5" and 3.5" HD. Please email me at joe_dao2003@yahoo.com and provide me your mailing address, I can send the copy software to you. Regards, pingping
Jun 15, 2007 | Hitachi Deskstar T7K250 250 GB Hard Drive
Computers & Internet Logo
371 people viewed this question
David Payne
David Payne
