Question about Nintendo DS Lite Console
Ds lite charging lite comes on but when i press power button nothing happens
Screen seems to be good, charge lite comes on but after i take charger off assuming battery is charge nothing happens tried different battery and a different charger same thing nothing happens,would i have to replace some chip or something?
I left to go to the mall one day and there were a whole bunch of little kids here and i put mi ds on the back of my sofa and wen i came back my ds didnt come on so i charged it for 3 days strait and on the charge button will come on but when it does it stays on for like 2 minutes then cuts of and mii game doesnt come on and the kid didnt do anything but play with it
Posted on May 24, 2009
  • 25 Answers
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
Posted on Aug 23, 2008
My ds lite just switched off and it was charged
Hi, so if you try switching on the ds lite, nothing at all happens ??
Does the green light flash even if it is for like a split second.If it does then it is more likely top be a blown fuse. If 1 of your screens flicker also, this could be your problem as the ds will not start up with a broken screen. Please advise
Jul 31, 2012 | Nintendo DS Lite Console
Nintendo wont charge or turns on. F1 & F2 fuses are good.
Check the L2 as well (under the power switch). Replace if necessary.
May 09, 2010 | Nintendo DS Lite Console
My DS lite is turning on then off
How did you break off the charging light?
Anyway, you probably need a new battery. The battery loses it's capability to hold a charge after each time it is charged so all you need is a new battery.
Feb 28, 2009 | Nintendo DS Lite Console
Nintendo DS will NOT charge
My guess is that the problem resides in the charger. You can buy a dual use charger for the DS and DS Lite at GameStop for relatively cheap.
Jan 13, 2009 | Nintendo DS Lite Console
Power gone on nintendo ds lite
Hey if you have a warranty nintendo might repair or raplace the Ds.I thought about replacing the charger or place the charger in another power outlet.I hope I helped.
Dec 30, 2008 | Nintendo DS Lite Console
DS lite, power is on but nothing happens
Ditto... except my daughter is 10. Both screens remain black, are fully charged and green light stays on for more than 4 minutes.
Sep 14, 2008 | Nintendo DS Lite Console
Dropped DS Lite - rattling
L2 inductor comes out sometimes when dropped and the DS keeps in fixed amber light when charger is plugged in. But you found it fast so good luck. Its pretty sure your DS will work again after soldering the L2 again in its place near the power switch. Just get the battery and charger out before doing anything to avoid a blown fuse also.
Sep 05, 2008 | Nintendo DS Lite Console
Nintendo DS Lite will not charge
GET A NEW CHARGER HAPPENED TO ME BEFORE my bad caps lol
Jul 18, 2008 | Nintendo DS Lite Console
Power problems with DS Lite
Really sounds like a dead battery. The DS will not work if the battery is bad even when it's plugged in. You get the quick flash of the power light and that's it.
Mar 29, 2008 | Nintendo DS Console
Beyond Repair?
I would try and get a new DS if I was u
Jan 04, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
402 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
