Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Top spray arm fell off during wash - how do we reattach it?
  • Frigidaire Master
  • 43,501 Answers
It is broken and needs to be replaced...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 07, 2010
Whirlpool dishwasher quiet partner lol is not cleaning dishes on top rack
could be a few things clean inside filters and screens listen to it does the wash motor during wash sound strong like it tossing water around in there open the door during the wash see if kicks some water out at you. If it sounds and seems like its working ok then some units have a rubber check valve little flapper in the tube that goes up the back wall to the upper spray arm i have seem break off and clog that tub not allowing any water to the upper spray arm.
Dec 24, 2016 | Whirlpool Dishwashers
Tip
How to troubleshoot your dishwasher
<span>Instructions</span> <ol> Dishwasher Does Not Run <li> <br /> Make sure the power is on, door is latched and controls are set properly.<br /> </li> <li> <br /> Look to see if the door switch, timer or selector switch are defective. Solve this problem by using a screwdriver to adjust the door latch's strike slightly.<br /> </li> <li> <br /> Confirm that the power cord is plugged into the electrical outlet under the sink (if applicable).<br /> </li> Dishwasher Won't Fill <li> <br /> Check your hot water supply stop valve under the sink. Turn it counter clockwise to ensure that it is open.<br /> </li> <li> <br /> Turn off the power and wait for your dishwasher to cool.<br /> </li> <li> <br /> Look inside for a float located at the base of the unit. Lift out the float device and clean around the tube. Rinse off the float and reattach it making sure it moves up and down freely.<br /> </li> Dishwasher Doesn't Drain <li>Remove the air gap cover (short chrome cylinder located at the back of your sink) and clean it using a wire.<br /> </li> <li> <br /> Check the drain hose for kinks and blockages.<br /> </li> <li> <br /> Shut off the power to your dishwasher and remove the strainer located at the base of the cabinet under the bottom spray arm. Scrub it clean then reattach it to the appliance.<br /> </li> Dishwasher Leaves Film on the Dishes <li> <br /> Add a rinse additive to your washing cycle and see if this solves the problem. In addition, do not pre-rinse your dishes prior to placing them into the dishwasher. Food particles allow the detergent and drying agents to work more effectively.<br /> </li> <li> <br /> Listen to the spray arms during a wash cycle. If they appear to be moving too slowly, use a wire to clean out the spray holes.<br /> </li> <li> <br /> Make sure the dishes haven't blocked the detergent dispenser or jammed the spray arms.<br /> </li> Dishwasher Leaks <li> <br /> Cut back on the amount of detergent used during the wash cycle. Sometimes this alone will solve your problem.<br /> </li> <li> <br /> Make sure the appliance is level by adjusting the front feet up or down.<br /> </li> <li><br />Take off the lower front panel and check the hoses for leaks.<br /></li></ol><span><br /><br /><a href="http://www.ehow.com/how_2120626_troubleshoot-dishwashers.html#ixzz18lyYrfk2"><br /></a></span>
on Dec 21, 2010 | Dishwashers
Model No.FDB4315LFB0. The middle spray arm detached during a wash cycle. I don't know where or how to reattach it. The only port I can see is on the top wall and is round. The port on the arm is oval...
A part broke that holds it on...happens all the time...
that is not that hard to fix and you can easily buy the parts yourself online...
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Aug 23, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Upper rinse arm fell off. How does it reattach?
usually it will clip to the basket that holds cups and the like, and engages with the water outlet when the basket is slid into position. Some spray arms have a locking ring that, when the spray bar is held in place, rotates clockwise (if viewed from underneath) and locks the spraybar in place.
Nov 06, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Not enough pressure to top rack
PULL WASH ARM OFF OF THE TOP RACK AND SLAP AGAINST YOUR HAND AND SEE IF FOREIGN MATTER IS LODGED IN ANY OF THE SPRAY JETS. CLEAN AND REATTACH
Jul 22, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Jan 17, 2009 | Dishwashers
Broken nozzle and upper spray arm
Thanks for the help. Like the other guy said the "ninga star" thing unscrews and using the plastic part inside I just pop the spray arm back on. Screw it back and it works again.
Mar 15, 2008 | Frigidaire GLD2445RF Built-in Dishwasher
Need to remove wash module
a screw fell into the wash moduel. How do i remove the lower spray arm, ect Thank's
Feb 08, 2008 | Dishwashers
Spring on pickup/loading arm
it should have a hook from the frame of the cd player on top and bottom just attac it and it should work
Dec 22, 2007 | Audio Players & Recorders
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
111 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
