Question about Yard Machines Tecumseh 148cc Front Tine Tiller #21a 251e000
Ifound a Tecumseh Yard Machine Front Tine Tiller. It has a 5.50 HP. The tiller seems to choke out every time i crank it up. Can Someone tell mewhere the fuel filter is located???? i have replaced the air filter, cleaned the carb, and replaced the gas/oil.
  • 1,040 Answers
It sounds as if you still have Carburetor problems.
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked.
(If there is a small screen in the Carb., this can get blocked too. Make sure that it is clean as well.)
Reassemble and start. (If there is a small screen in the Carb., this can get blocked too. Make sure that it is clean as well.)
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Sep 09, 2010
Just helping someone who put gas in her oil fill. What do I need to refill oil? SAE 30 ?
Yes, the Tecumseh engine takes SAE HD30 motor oil. With a complete drain, it should take about 21 ounces to fill.
Aug 26, 2010 | Yard Machines Tecumseh 148cc Front Tine...
I'm looking for blades for a tecumseh 5.5 formula, can you guys help me?
Copy and past this into your browser's address bar. Then hit enter! Tecumseh parts galore!
http://www.m-and-d.com/scan/se=TECUMSEH/sf=category/st=db/co=yes/op=eq/sp=brands_results/va=category_name=TECUMSEH/tf=sku/ml=20.html
May 10, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Engine part for Tecumseh 6hp 195cc
The float and pin can be bought as a repair kit., and replaced.
Mar 24, 2010 | Mtd Products Yard Machines 158CC Tiller
I have an old pressure washer that uses Tecumseh H30 engine. After pumping the choke bulb on the carb, it will crank, run maybe 5 seconds and quit. Thanks
When you get it started, move the choke to the middle, then let it warm up. you might have to move the choke back and forth until it warms up, keep the throttle wide open.
Jun 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Repair Manual
http://www.smallenginesuppliers.com/html/engine-specs/tecumseh-engine-specs.html......
this is where i go for parts breakdowns and service literature.......hope this helps.!
May 20, 2009 | Yard Machines Tecumseh 148cc Front Tine...
Tecumseh Self Propelled Yard Machine - What size spark plug do I need?
You can download the owners manual for any Tecumseh engine here. You'll have to find the model number on the engine to do so.
http://www.tecumsehpower.com/frameset.php?page=CustomerService/OperatorManuals/index.php
May 09, 2009 | Yard Machines Tecumseh 148cc Front Tine...
Troy bilt tiller
either the carb needs cleaned or theres a vacuum leak
Apr 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Broken clutch cable connector, MTD Tiller
I found micro fiche on jackssmallengines.com . Click on the manufacturer's tab at the top of the page then you'll have the option to use an off-site tool to locate your machine. I used it and found my 1990 mtd rear tine tiller. I needed the cable that engages the tines - maybe the same as you. The part number for my 1990 model's cable was 746-0535. Dont know if it was still the same in 96 to 98. But look at the fiche and see.
Apr 04, 2009 | Mtd Products Yard Machines 158CC Tiller
Yard Machines Tecumseh 148cc Front Tine Tiller #21a 251e000 Logo
310 people viewed this question
Top Yard Machines Garden Experts
Phil Walker
Phil Walker
Dean Gruber
Tim Whalen
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
