Question about Ariston Technologies AWD121WH
I want to change the bearings on my Ariston AWD12 washing Machine do I need to take off the drum spider
  • 183 Answers
SOURCE: replace drum bearing
To complete this repair correctly and to prevent problem re occuring within months you must change the inner drum spider at the same time as the bearing kit, otherwise you are wasting your time, to complete the repair if you have not done one before will take you aprox 1 to 3 hours depending on space available and practicle ability, here goes, remove lid and outer case from machine to do this remove bolts on lower back and two side bolts (under small white covers) remove bolts along top edges both sides on top of macnine, remove cabinet, remove motor, remove hoses, remove heater and thermostat wires, noting location for refitting, remove suspension leg pins and lift outer drum assembly complete fron lower frame, split two halves of outer drum by removing bolts around centre seem, split drum in two, remove drum pully, refit pully bolt and drift inner drum out having put nut back on drum spider thread to avoid flaring shaft, using hammer knock shaft through bearings, then using a chisel or similer object knock out bearings and seal, reverse process refitting new bearins and spider, make sure to replace centre outer drum seal, as these are prone tro leaking I suggest you also seal with a layer of clear silicon, and problems contact me again, not really a job for a novice. Good Luck you will need it. Regards Advisor
Posted on Aug 30, 2007
barkencoa
  • 3463 Answers
SOURCE: Ariston Margherita 2000 AWD12 Advantage washer dryer filter clean
To clean filter, remove the lower plastic panel at front of washer.
Unscrew the pump filter cover anti-clockwise to remove and clean.
Please rate my fixya solution.
Thanks.
Posted on Feb 13, 2009
barkencoa
  • 3463 Answers
SOURCE: How to I remove the drum from a Hotpoint WM64
Remove top cover and rear panel.
Remove belt and drum drive pulley.Remove clamp that secures door seal
Remove top control console panel.
Remove door lock.
Remove screws top and bottom holding front panel, remove front panel.
Remove spring clips holding plastic drum front, lift to one side plastic drum front cover.
Tap drum shaft to remove drum from container, remove bearings.
Please rate my solution.
Thanks.
Posted on Sep 04, 2009
Testimonial: "Your solution answered my question, but left me with another. How to remove the bearings from the drum. "
  • 5 Answers
SOURCE: how to change drum bearings
Right - all washing machines are pretty similar except between manufacturers such as Dyson, who use such things as three seperate drums.
The average washing machine is simply a motor attached by a belt to a drum, with a programming unit that connects to a door sensor and heating element, and a seal that goes around the drum.
Since we are dealing with Hotpoint, the first thing to do is take off all panels from the front, the top, and the back.
From the front: You will be able to see your drum, and should be able to undo the seal. Basically at this point, unscrew everything attached to whatever I describe - remembering where they go. Now the front seal is sometimes attached to the case that surrounds the drum - usually with a heating element attached to it on some models.
From the back: You will see the belt attached to a flywheel that turns the drum. Rotate the drum to check that the rumbling / banging noise is still occurring. Check that the drive belt isn't damaged or worn as this can cause problems. Unscrew the huge bolt that holds the flywheel on to the drum (rotate anti-clockwise). This will usually take a lot of force and is better to use a large spanner, lock it in place, and turn the actual drum with your hands if you can't undo it. Now when this comes off, you will be able to pull the drum free. Move it around until it comes away. The bearings may drop off the drum's shaft so retrieve them. Check to see if they fall apart as this indicates the bearing's seal has gone totally. This is the part to replace. Buy a replacement the exact same size for your model of washing machine and reassemble - ensuring that all screws go back in the right place.
Hope this helps. Remember that it is just a case of unscrewing things in the right order. You learn best by just doing - so if you are mechanically minded - this sort of thing will be a doddle. If you get stuck and can't remember how to reassemble it - call out a repair man and watch how he fixes it as this will of course allow you to try it if it goes bad again ( a common problem I've been told with Hotpoint and Zanussi models since they are manufactured using cheaper parts than others. )
Posted on Nov 09, 2009
  • 152 Answers
SOURCE: Replace drum bearings on hotpoint aquarius wf000g
You really don't want to know how but here it is. The bearing is located in the rear shell and is not removable the rear shell has to be replaced which means removing the tub assembly from the machine and completely disassembling. With 30 years of appliance repair the last one I did took about 3 hours.
Posted on Feb 26, 2010
Why does machine not click into stage two after filling up with water. It seems to not want to spin cycle pump still working?
If the drum is not turning, the motor control board is faulty. This may just be a bad solder joint, but you'll need someone with electronics knowledge to check and repair it.
Sep 14, 2014 | Ariston Technologies Ariston AWD12 Front...
HOW TO FIX O9 ERROR CODE?
F09: Machine Setup Error Found (AWD12)
Setup error or incompatible EEPROM
Control Microprocessor Version
Ask for EEPROM Spare Part indicating Microprocessor version
Reflash EEPROM
Check electronic controller
Dado
Sep 09, 2014 | Ariston Technologies Ariston AWD12 Front...
Why my washing machine unable to switch on?
If there are no lights, check the fuse in the plug.
If the machine comes on but the drum does not move, the motor control circuit board probably has a burnt connection or bad joint. This may also be the cause of the fuse blowing.
Jun 05, 2014 | Ariston Technologies Ariston AWD12 Front...
Ariston awd 1200 fills,advances and empties, but will not wash or spin.Belt ok, drum rotates free. Any advise?
The fault is on the motor control board, which is on the bottom left when looking from the back of the machine. There's a good chance that one on the connectors will have over-heated and burned the track. I fixed ours by utilising an unused connector on the board and swapping the pins in the connector.
Mar 23, 2013 | Ariston Technologies Ariston AWD12 Front...
Mashine make noise and vibrating a lot
Hi, your washing machine makes noises because all the clothes and other materials are not balanced evenly--one side is heavier than the other--causing the drum to hit the sides of the washer wall.
Sep 29, 2010 | Ariston Technologies Ariston AWD12 Front...
Throws the drive belt. Drum appears loose.
Sounds like drum bearings?? not for the faint hearted! could cost around 100 to get engineer to repair.
Aug 02, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston Margherita 2000 "AL109X" very noisy when spinning
To start ensure that machine is well balanced, and that the load is well distributed inside the drum.
If the problem is not balancing, then the most common is a broken drum bearing spider or a bad drum bearing. A symptom of drum bearing problems is the drum having excessive play when you spin by hand.
Also struts and springs must be checked.
Apr 18, 2009 | Ariston Technologies Ariston AWD12 Front...
Thanks.
Feb 13, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston Technologies AWD121WH Logo
59 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
