Question about Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair
Pride mobility celebrity 3 wheel scooter every thing works except foward & reverse
  • 944 Answers
This problem could occur due to various reasons.So lets find out what could be the cause.
1)Check lever is in correct place.Levers control the switch that controls the brake.if the brake is disabled this will stop the scooter from moving forward or backward.
2) Check the brush in the motor,If it is stuck release it and tighten the caps.
3)Thumb levers that control forward and reverse motions.See the the lever is not detective one and it is working properly.Take apart and check the wiring connections.
4)Check free Wheel lever is jammed which is located on the drive motor,and check the lever is not bent.
5)throttle lever is worn out sometimes you have to replace it.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 05, 2010
I have a celebrity pride 3 wheel scooter and when i move lever to forward or reverse all it does is click but no movement
Have you checked the speed pot is not turned down too low?
No flash / beep codes.
I would check motor connector on drive unit, motor brushes.
May 24, 2014 | Pride Mobility Products Pride Celebrity XL...
Why does my scooter stick in reverse & wont go forward
Your wigwag pot sounds faulty you can very often buy a good used one on eBay
Apr 24, 2014 | Pride Celebrity X 3-Wheel Electric Scooter...
Why does my scooter stick in reverse when i push forward & stop when i push reverse
Hi, it could be that the throttle has turned around within the throttle lever therefore no longer centre, look under the throttle stem, you should see a cross head now that should be in align with you when sitting on the scooter...you will need to loosen the throttle and realign if that is the case...
Regards
Rob
www.gewizrepairs.co.uk
Apr 24, 2014 | Pride Mobility Products Pride Mobility...
Pride mobility scooter celebrity x flashing 5 times not working
Hi remove key put freewheel lever into drive & replace key .turn on...,... good luck.,
Nov 04, 2012 | Pride Celebrity X 3-Wheel Electric Scooter...
Lost key to Pride Celebrity Scooter. Have an extra key for another Celebrity scooter. Are keys interchangeable? Thanks, DJ
DJ should work try it if all else fails call Pride @ 1-800-800-8586 ask for tech Support and ask to get a set of keys or You can replace the keyed switch with a on/off toggle switch Hope this helps
May 05, 2011 | Pride Mobility Products Pride Mobility...
I have a celebrity scooter that powers up great and every thing seems to operate properly except it will not go forward or backward. It makes no sound when engaging thumb switch.
Make sure the drive lever/freewheel brake is engaged. Usually it is on the lower back bottom of the scooter or check your owner's manual.
Oct 29, 2010 | Pride Mobility Products Pride Celebrity XL...
Brake not holding on incline
remove wheel then using screw driver
remove brake then replace and re screw
replace wheel
ted mobility centre penge 0208 676 0944
Mar 30, 2010 | Pride New Mobility Celebrity 3 wheel...
Rally PRIDE 3-WHEEL SCOOTER
Sounds like you have a bad throttle pot. You`ll need to check the resistance on it or take it to a dealer.
Dec 29, 2008 | Pride New Mobility Rally 4 Wheel Scooter
Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair Logo
90 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
