Question about Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
PICTURE AND SOUND SUDDENLY GO OUT. I SEE A MESSAGE THAT SAYS NO SIGNAL. THEY COME BACK ON AFTER I UNPLUG IT FOR A MINUTE OR SO. I'VE USED DIFFERENT OUTLETS. NO DISPLAY ON DVD WHEN THIS OCCURS. ANY IDEAS?
  • FEE523 Sep 05, 2010
    I do not have FIOS. I have cable. The tv is not dead. It displays "no signal"
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Two things may cause the “No Signal” message to come up are - no data available for closed captioning and a weak signal input. Your TV is in the Closed Captioning Mode. To turn it off simply bring up the on screen menu and scroll down to the part that says closed captioning and turn this function off! With the closed captioning block displayed and the program being viewed is not sending out closed captioning signals the TV will display, No signal! Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 05, 2010
  • 10,515 Answers
Press TV on the FIOS remote, then find the INPUT button near the bottom of the Fios remote and press it...press it again and again until it finally cycles to the Connection his Fios box is connected to.
Then press the STB button. That should get your TV back to the proper input.
But that will not fix his TV set if the TV is dead or does not display volume bars or the TV menu or any other on-screen display. That indicates the display is dead and either the power supply or the video board has failed.
So if the TV is black and displays nothing, then he needs a Sony repairman.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Suddenly no sound is coming from the tv
Unplug set and or a box if used for a while and plug back to let units reboot.
Look in menu to see if speakers are switched on or off.
Look to see if a DVD etc connected to a rear input has sound or not.
May 29, 2012 | Toshiba Televison & Video
I have a Canon Pixma 640. It's hardly been used since I bought it. Now suddenly there is an error message saying 'Error cassette, no paper, please load paper and press OK' I've done this...
This may sound patronising but are you sure there is paper in the cassette located at the bottom of the machine and not just on top at the back. There is also a button on the operation panel that selects which tray you are using. It could be as simple as that!!
May 26, 2011 | Office Equipment & Supplies
We've had a 42" LCD/HD
Tries tv unplug,replug it back like about an hour later.Most of the times tv will resetting itself back to the factory setting and will work again.If still have the same problems,tries pushes the power button on/off a couple times for trying to fire up the tv Tuner signal board,these off/on tries work with many LCD/Plasma HD tvs.But this kind of problems,eventually u have to change the tv Tuner signal board sooner or later.Because the tv Tuner signal board it is dying,and this solution is just a temp fixed for the delaying it for awhile.
May 25, 2011 | Televison & Video
I,ve connected my wii to the led tv using a wiii component cable(5 leads) but have used only 3 of them red green & blue 1,s leaving a red & white 1 left i have good picture but no sound help please
your cable is split into two different connections for your tv... the red green and blue cables are for HD only. They are their own little set. the yellow cable is your video cable for normal tv's. the red and white cables are sound cables, also for normal tv's. I would unplug the red, green, and blue cables, and use the yellow, red (right sound), and white (left sound).
Dec 31, 2010 | Nintendo Wii Console
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
47in Phillips-tv picture goes black still has
Could be the signal board has a bad cap, in this case it sounds like you are getting intermitten power to the inverters....when the tv goes down and of course you have audio....Shine a flashlight on to screen and see if you have a picture...look carefully. If this is the case..you have the above problem!
Nov 23, 2009 | Televison & Video
Frequent sudden loss of radio signal
It looks like the problem is solved by adding an extra mass to the system.
Jun 20, 2009 | Blaupunkt Tokyo RDM169
Bravia indicates no signal from Sony BDP S350 DVD
I once had a similar problem, although with a different TV. It was insufficient to just power down the TV -- I had to unplug the TV so that it would re-initialize. It solved my issue.
May 25, 2009 | Sony BDP-S300 Blu-Ray Disc Player
I cant see anything on my vizio 32 inch television
I just spent an hour trying to fix the VIZIO with the same problem. The screen had no picture at all, but could hear the sound perfectly!! But we i figured out the solution! UNPLUG THE CABLE BOX AND LET IT RE-BOOT! and it WORKED!!!!!
Aug 05, 2007 | Vizio L32 32 in. LCD HDTV
No screen and no sound power and battery indicator is on but hard drive indicator is off
Unplug the power adapter and take the battery out. After a minute, plug them back in and push the power button.
Jun 25, 2007 | Sony VAIO VGN-SZ460N/C Notebook
Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
96 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
