Question about Echo Indigo Stereo Output Device for Laptop Sound Card
Acer 5050 (5056) not working with Indigo I/O
Hello Dear Experts! I can problem with laptot Acer 5050 (5056) and soundcard Echo Indigo I/O. Windows Xp or Windows Vista find soundcard, but write? then device can be work normally (code 10). Setup driver-filter (download from Echo Off.Site) did not yield results. CardBusControlller - ENE 712/714/810. Help me please...
  • 1 more comment
  • Uzopoza May 12, 2008
    Sorry, i have a little mistake - Windows Xp or Windows Vista finds the sound card, but writes that the device can not work normally (code 10)
    Hi Map!
    No, no. You misunderstood. integrated Realtek working correctly, but Echo Indigo I / O (external PCMCI card) does not work: (
  • Anonymous Dec 12, 2008
    uzopoza-- did you get this issue resolved?
    President:
  • 2,351 Answers
Hi Uzo, click on this Acer link to open.
http://support.acer-euro.com/drivers/notebook/as_5050.html
Under MS Windows XP, click the dropdown menu & choose,
Audio Driver Realtek Ver. 5.10.0.5273
A download window will open, click to Save. Creat a folder on you're desktop & name it sound driver. Save the download file into the folder.
If you prefer the MS Windows Vista, do the same as mentioned above.
The downloaded file will be compressed in a .zip format. Use WinZip to uncompress the files into the folder you created.
If you need the program WinZip you can download a free 45 day trial from this link.
http://www.download.com/WinZip/3000-2250_4-10003164.html
It is suggest that you check Add/remove programs & unstall any previous sound drivers before installing Acer's driver software. If you sound still does not function, please run windows update service. Code 10 can mean many different things, including you're system may contain a virus.
Explanation of error codes generated by Device Manager in Microsoft Windows XP Professional.
http://support.microsoft.com/kb/310123
Hope the Acer driver software gets you're sound to work.
Have more questions? Please feel free to ask.
Mike
Posted on May 12, 2008
Output activity showing but no sound.
Virtual outputs? in Echo console The phones output is Analog 1-2 and the line output is Analog 3-4. In the Echo console, you can choose between the Analog 1-2 bus and the Analog 3-4 bus in the upper right hand corner. In the Analog 1-2 bus make sure you have virtual output 3-4 muted. In the Analog 3-4 bus make sure you have the virtual output 1-2 muted. From within your audio application you can now assign your headphones output and your house (line) output. Hope this is some help.
Jul 25, 2007 | Echo Indigo IO Sound Card
Hello, I'm afraid that i'm going to sound ridiculously stupid. but i've just been told that in order to use my acer aspire one p531h obk for work that i need to use a softfone and a usb or blue tooth...
Yes it should be fine. That laptop looks to use a N270 processor so no problems with trying to get 64bit drivers. Laptop has a builtin soundcard and supports USB and Bluetooth.
Any new good USB or Bluetooth headset will come with drivers for XP, Vista and Windows 7 32bit. Vista drivers should work with Windows 7 if non are availble yet, but you will need to try 'em. I'm assuming you are not running Linux tho...
Jan 18, 2010 | Acer Aspire One PC Notebook
Install a new sound device
You probably need to install a device driver for your sound card if Windows does not support it by default. You should have a CD for the audio card which contains a driver, otherwise you can download it from the manufacturer's support site.
Here are some more steps on how to troubleshoot sound in XP.
Jules
May 15, 2009 | Echo Indigo Stereo Output Device for...
All of a sudden my Echo Indigo DJ soundcard will play both virtual CD players on my PCDJ software on one channel. For a while, I had cd 1 on one channel and cd2 on the other. I am using a pig tail plug...
I can run audio on 3 separate channels/outputs of my laptop
I use Tricerasoft Swift Elite DJ software but the areas you need to look at for troubleshooting are probably similar:
1) check the (PCDJ) software settings for selecting the channel outputs of your Indigo DJ on each deck/ player. NOTE: 1/2 and 5/6 are the same physical port (headphone port), while 3/4 and 7/8 are also shared on the Line Out port. So make sure you use for eg. one player uses 1/2, and the other player uses 3/4 ONLY IF you want them running out to separate channels on the mixer
I personally run both my decks off the same channel, ie 3/4 so that my software can do the mixing for me. My mixer only acts as an master control device where everything else connects
2) Make sure you check your IndigoDJ Console (installed to the Windows Start menu under Echo Audio, Indigo DJ), if you have any conflicts or if for some reason one particular channel pair gets inadvertently muted, resulting in no sound coming from the port.
3) I also use my onboad sound card (typically for previewing music or for an auxillary output). This is obviously controlled by the Operating system... in Windows is is through the Sound properties, default sound device. I recommend NOT using Indigo DJ as a default sound card -- but that is a personal preference.
So in this way you actually have 3 outputs for sound
As far as cabling is concerned, it depends on what you are connecting to. I use a 1/8 (mini computer) jack to 1/4 whcih then plugs into a direct box (eleminates any static hum etc), then from the DI box using an XLR cable to the mixer. Your setup may be slightly different.
Hope this helps!
Dec 01, 2008 | Echo Indigo DJ Sound Card
Gina Echo card over 10 years old
Did you try the WDM 605 drivers - and the WDM611 beta one (which looks pretty mature) - They can be found on many servers.
Sep 02, 2008 | Echo Indigo IO Sound Card
Phones 1-2 has both channels coming out of it
Had the same problem and fixed it today. It is the mute button. Whem you change from 1-2 to 3-4 if the mute button for 1-2 does not activate you will get the sound from 1-2 thru 3-4. Just change the setting and you are away. worked for me.
bruce
Jun 03, 2008 | Echo Indigo DJ Sound Card
Echo indigo io recording problem
dont plug mic into output, it is input
May 24, 2008 | Echo Indigo IO Sound Card
Soundcard
Is the outgoing sound dampened? You can go to:
Start -> Control Panel > Sounds and Audio Devices (or something similar) and choose Advanced Volume Control.
You can also doubleclick the speaker icon next to your systemclock on the bottom right of your screen.
In Advanced Volume Control, make sure the correct soundcard is selected. If not go to Options -> Properties and select the correct one over at Mixer device.
Anyhow. Make sure that the sliders for outgoing sound don't have the "Dampened" checkbox checked.
I hope this answers your problem, if not tell me.
Greetings,
DarkNeogen
Jan 25, 2008 | Echo Indigo Stereo Output Device for...
Output activity showing but NO SOUND!
Windows Vista Home Premium--Up to date This may be the problem. Vista is very much AntiPiracy. If you are ripping or such, Vista will give you grief.
Jul 26, 2007 | Echo Indigo IO Sound Card
Echo Indigo Stereo Output Device for Laptop Sound Card Logo
219 people viewed this question
Top Echo Computers & Internet Experts
Computer Links
Ben Armstrong
Andrew Taylor
Andrew Taylor
Are you an Echo Computer and Internet Expert? Answer questions, earn points and help others
