Question about Aquabot Pool Rover Above Ground Robotic Pool Cleaner
My aquabot pool rover is not running. power is going in but not working
5 Suggested Answers
SOURCE: Aquabot is pushing out water but will not move to clean the pool
We've had this happen a few times because we use and abuse our poor bot. I sent it out for repair twice. Then I ordered parts. Self repair was tedious for a non-mechanical guy like me but I did it. Often it is the belts that need to be replaced. Next the rubber tracts. It's worth repairing. And worth repairing yourself if you can.
Posted on Jul 18, 2009
  • 15 Answers
SOURCE: won't go in shallow end to clean
If your floats have started to absorb water, the unit may become reluctant to climb the slope from the deep end to the shallow end, although it may still at least start to climb and clean the wall. There are 3 installed floats in the unit bottom plate: 1 "h" float and 2 pocket floats. Aqua Service Distributors in Sequin, TX had a good price on replacements. Good people, too. S. Christian dansker01@msn.com
Posted on Aug 22, 2009
SOURCE: pool rover JR running slow
This has happened to me several times. Hair can get caught on the impeller. This causes the flap inside the jet to not close completely. Unplug the unit, remove two screws off the jet exhaust and gently remove the hair.
Posted on Aug 28, 2009
Geekman
  • 32281 Answers
SOURCE: aquabot is cleaning only one area of our pool and
The pool hose that is attached to the Aquabot gets set into a pattern so it moves to one part of the pool. Remove the pool hose and rotate it approx 100 degrees and re-attach it, then it will clean the pool. You may need to rotate the hose again to get the cleaner to clean the whole pool area.
Posted on Jun 03, 2011
How do you clean the filter on aquabot
I have a small stream nozzle on my hose that puts out a good but of pressure. I turn the filter bag inside out and spray it til it's white. I then turn it back in and spray water from the inside out. The bag is also machine washable if it still isn't clean.
Jun 18, 2014 | Aquabot Pool Rover Above Ground Robotic...
Pool rover has like patrolum jelly on it around bag
It is a type of algae. Wash it off and bleach it or tilex it.
Jun 01, 2014 | Aquabot Pool Rover Above Ground Robotic...
Pool rover goes only one direction
they usually do unles its et the other way.. if its working leave it alone..
Jul 29, 2012 | Aquabot Pool Rover Above Ground Robotic...
Rover only goes one way
I had this same problem. I took the Rover out of the pool, removed the filter, turned it right-side-up and shot a strong blast of hose water into the outlets where the water exits to propel the Rover. Do both sides over & over a few times. That should do it.
Blows fuse when turned on
Mine is doing the same thing, but I have searched and not found any solutions...
Jul 06, 2012 | Aquabot Pool Rover Above Ground Robotic...
My pool rover goes one way but wont turn around just keeps pushing against the wall
Hello Kathy,
I have the same problem. Do you already have a solution?
Regards,
Bob from belfium
Jun 10, 2012 | Aquabot Pool Rover Above Ground Robotic...
The aquabot doesn"t go all
If you can wiggle the cord and make the pool cleaner work, it sounds like an electrical problem. If this is the case, you need to have it serviced by a professional. There are a few things you can check first, though. Make sure that the filter bag is clean and clear of debris. Make sure that all lint, cloth, or debris is removed from the impeller.
Sep 10, 2011 | Aquabot Pool Rover Above Ground Robotic...
Online instruciton manual
Here is a page of articles from aquabot ,, lots of instructions you can view ..
http://www.123aquabot.com/Articles.htm
Please Vote !!
May 15, 2010 | Aquabot Pool Rover Above Ground Robotic...
Pool rover JR running slow
Mar 13, 2009 | Aquabot Pool Rover Above Ground Robotic...
Aquabot Pool Rover Above Ground Robotic Pool Cleaner Logo
147 people viewed this question
Top Aquabot Pool & Spa Experts
Robco Water
Robco Water
The Cover Guy
The Cover Guy
David Spradling
David Spradling
Are you an Aquabot Pool and Spa Expert? Answer questions, earn points and help others
