Question about Eureka Luxury Family 8-Person 2-Room Titan Tent
How to change belt on eureka vacuum model 5048b
3 Suggested Answers
  • 33 Answers
SOURCE: How do I change belt on Eureka Capture
lay your vacuum completely on its back on the floor, like you are going to vacuum under a bed, then turn it over on its "belly", you should be able to see the bottom of the unit, where there are 2 small wheels ..... look where embedded in the plastic are #'s 1-4 there are 4 screw pockets, 2 in front and 2 in rear, those are deep, so you need a phillips screwdriver with a long skinny barrel to get in the deep pocket.remove those 4 screws, stand the unit upright, then grasp both sides of the "hood" of the unit remove the the plastic cover, you should see the belt on the right side as you face the vacuum. If the belt is broken, just pull up on the brushroll , removing it from the base. Clean any hair,thread, etc.. from the brushes, and ends , place new belt over the motor shaft (looks like a nail sticking out toward the back of the belt area) slide the brushroll through the other loop of belt in the belt groove, then slide the stop sign shaped end pieces in the grooves in base , pressing down until it is seated in place, gently turn the brushroll with fingers watching the belt making sure it is staying straight , then place the hood of vacuum back in place, make sure it fits correctly, recline handle again all the way down, roll vacuum over again to place screws back in bottom of unit.
Posted on May 17, 2009
SOURCE: How do I change the belt on a Eureka Victory model
You need a phillips screwdriver. Undo the two screws, either side of the height adjustment dial. Lift off the cover. Now you should be able to see instructions and the old belt..
Remove the brush roll..put the new belt in place around drive pulley and brush roll pulley.. reinsert left end of brush roll first then pull to stretch the belted end back into it's place.
Replace cover.
Posted on Mar 10, 2010
Need belt for Eureka vaccum The Boss model 5848 AV-2. Can you give me a belt number for what i nee. Thanks.
The belt part number for the Eureka 5848 AV-2 vacuum is 61120A.
Should you need part numbers for other pieces of the Eureka 5848 AV-2 vacuum, click on the following site, http://www.vacpartswarehouse.com/Eureka-5848-Lightspeed-Whirlwind-s/1959.htm
Mar 14, 2011 | Eureka 5849A Boss Bagless Upright Cyclonic...
What Model replacement belt do I need for the Eureka model 2961 BVZ?
Greetings,
According to the Eureka Part diagram for your particular model vacuum, your vacuum uses Eureka Style U Belts. Eureka makes actually 2 different styles of U belts.
The first style is the standard U belt, Eureka part number 54312. This belt is probably the one that came standard on your model. You may purchase this belt from the link below;
http://eurekaservice.stores.yahoo.net/uprightbelt.html
The other type of Style U belt that will fit your model is the Eureka Extended Life Style U Belt, Part 61120B. The Extended U belt is more durable, and lasts longer then the Eureka Standard U belt. You may purchase the Extended U belt here;
http://eurekaservice.stores.yahoo.net/exlifubel.html
Now, if you are quite sure how to change your belt, you may visit the link below to see the owners manual for your Eureka 2961BVZ that will give you step by step instructions on how to change the belt;
http://eureka.com/service/manuals/80244.pdf
I really hope that this was helpful to you in finding and fixing the belt for your Eureka. If you did find this helpful, please be kind and rate my repair solution as helpful by clicking the thumbs up icon in the lower right hand corner below. I really do appreciate it, thank you.
Feel free to request a repair clarification if you have any questions about the procedure of installing the belt on your Eureka, I'll be happy to help.
Chris J.
Mar 12, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
How to change belt in eureka altima vacuum
Here is the belt you need to replace and the manual which has instructions:
Eureka Altima Belts
Owner's Guide
Dec 31, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
How do you change the belt on a model 5856
here is a link to the manual which has instructions and to the belts you need
Eureka 5856 Belts
Eureka 5856 Owner's Guide
Nov 22, 2009 | Vacuums
I have a Eureka Altima vacuum. The model number is 2996. I don't think my vacumm is sucking any dust. Plus, it smells like a burning leather. What should I do? I have tried to get help from others and they...
Sounds like the belt for sure. Here is a link with the owners manual. It shows how to get to and change the belt.
http://www.eureka.com/index.php?option=com_productdisplay&view=productdisplay&task=getproducts&productid=2&product_model=2991AVZ
Sep 18, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
How do I to change the belt on an eureka altima 12?
the belt is on the bottom right (looking at it from the front). the Eureka website does have the manual for download, http://www.eureka.com/service/manuals/80244.pdf
With the vacuum flattened (straightened) out, turn it over and remove the back roller cover, (2 screws) once off, the roller should just pop out on the opposite side (opposite from the belt). Don't forget to turn the roller to center the belt once you have it on.
Jun 14, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka Luxury Family 8-Person 2-Room Titan Tent Logo
144 people viewed this question
Top Eureka Sport & Outdoor - Others Experts
Are you an Eureka Sport and Outdoor - Other Expert? Answer questions, earn points and help others
