Question about SuperMicro SUPER TDLR (MBD-P3TDLR-O) Motherboard
I tryed to boot safe by pressing f8.. but its not booting, its still asking me to press any key to restart
  • SuperMicro Master
  • 27,725 Answers
sounds like a faulty lead try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Posted on Sep 05, 2010
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Windows install service
I do not understand your problem ?
Try this.... Start your computer in Safe mode, and then register theMsiexec.exe file. To do this, follow these steps:
  1. Shut down your computer, and then restart your computer.
  2. Restart your computer and press the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, press the F8 key when you see the Boot menu.
  3. Use the ARROW keys to select Safe Mode, and then press ENTER.
  4. If the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
  5. Log on to the computer.
  6. Click Start, click Run, type msiexec /regserver in the Open box, and then click OK.
Apr 27, 2014 | Microsoft Windows 7 Home Premium 64BIT...
How can i exit safe mode on my toshiba laptop
Click the "Start" button.
Type "System Configuration" (without quotes) in the search box and select "System Configuration" from the search results.
This will open Microsoft's System Configuration utility.
Click the "Boot" tab.
Clear the "Safe Boot" check box under "Boot Options."
Using the Windows Boot Menu
Turn on your computer.
Press the "F8" key repeatedly immediately after the BIOS screen appears.
The BIOS screen typically displays the logo of the computer manufacturer.
Select "Start Windows Normally" from the boot menu and press "Enter" to proceed.
or
during the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
Nov 02, 2012 | Toshiba Computers & Internet
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Microsoft Windows Vista and Windows 7 users
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
I have dell inspiron laptop, suddenly a problem occured I quot that :windows faild to start a recent software or hardware change might be the cause to fix the problem : 1-insert your windows...
Shut your computer all the way down. As soon as you turn it on, start hitting F8 about 3-4 times, that will take you to an advanced options menu. Select "Last known good configuration" and that should work
Mar 08, 2011 | Computers & Internet
Wont boot up after an improper shut down, how can i make it boot up?
Try tapping F8 while booting and go to boot with "last know good configuration" if that doesn't work hit f8 again while booting and go to "safe mode" and do a system restore :) hope this helps thanks
Dec 30, 2010 | Acer Aspire One 10.1" Netbook Computer -...
How do i start up in safe mode (i have a spyware virus)
Restart your computer and as your computer restarts but before Windows launches, press F8. Use the arrow keys to highlight the appropriate safe mode option, and then press ENTER.
Hope this helps.
Dec 29, 2010 | Computers & Internet
My daughter put a password on my computer and now its on a blue page asking for a password how do i rest the computer
Hi Dianegooch20
There are two types of user 1. Administrator 2. User
If you are a user and haven't set the administrator password then you can try to safe boot the steps given below
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Dec 01, 2010 | Computers & Internet
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
Windows vista will not boot on a toshiba laptop
First try boot options.
On start up press F8, you get different boot options listed.
Select "last known good configuration"
If this doesn't work, try "boot into Safe Mode". Then restart once safe mode loads.
If neither of these work, you may have to attempt a "repair" of windows.
Get a Windows Vista Operating system disk (same version of Vista, Home or Premium).
1. Boot from it (put it in CD drive and restart the laptop).
2. If you still get the same problem start up, you need to set the laptop to boot from CD.
3. Restart laptop, press Delete key or F2, or F12 (it should say one of these on the screen) to enter the Setup. or another key to get "boot options"
4. In Setup (BIOS) Use Right Arrow to find the Boot Options. Use the instructions to move the CD-ROM to first position, above HDD (hard drive). Press Esc, then F10 to save your changes and exit.
5. The Windows Setup CD Rom should now run. It should come to a screen where you are asked to press R to repair windows.
6. When it comes to the command prompt, restart the laptop
Hopefully the laptop should boot OK again.
Jan 25, 2009 | Computers & Internet
SuperMicro SUPER TDLR (MBD-P3TDLR-O) Motherboard Logo
Top SuperMicro Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Tony
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
