Question about Samsung CLP 300 Laser Printer
Loud clicking sound
My printer makes a loud clicking sound when feeding the paper through the machine.
  • 4 more comments
  • xzman May 15, 2008
    Anytime the unit comes out of standby and while printing, I hear the loud clicking noise. It started doing this after having it for 1 week.
  • Cynnagyrl May 15, 2008
    Clicks loudly prior to spitting out a print job as well as following for a few moments. Really annoying.
  • Anonymous May 20, 2008
    My printer makes a loud clicking sound when it starts up
  • F_B_B_O May 31, 2008
    I have the same problem plus prints are almost always partially faded.
  • scarybadger May 31, 2008
    Clicking sound when sat idling with power on.....just managed to get it going after the waste toner cartridge malarkey but anyone got any ideas on what the ticking is....read one review and it says, something might be loose, but that not really helping......anyone got any ideas, Samsung support have been shockingly bad.....
  • Z33ky Aug 13, 2008
    Megga thanks whitehorse1!
    I'd recently performed a cartridge toner refill on the large black toner cartridge which included sticking on a new chip over the old chip which unless performed the old chip will register an empty cartridge and will not allow one to print and soon after started experiencing the loud clicking noise when printing. After reading whitehorse1's solution I pulled the black cartridge and pushed it back in firmly and now I can print without the loud clicking noise!
We had the same problem, with a slightly different solution... it turned out in our case that the new toner cartridge's internal drum was too stiff, so the printer was trying to turn the toner spindle and failing, resulting in the clicking noise. Our solution was to manually turn the black center gear by hand a few times, and in doing so loosen the drum up a little, so that the printer could turn it. We put it back into the printer, and voila! No more clicking noise.
Thanks to whitehorse1 for his (or her) solution... though it wasn't the exact same problem for us, it was what put us on the right track. :)
Posted on Oct 18, 2008
  • 4 Answers
Mine did this after I replaced a toner cartridge (the round ones). Here's what causes the loud clicking:
Some (most?) replacement ink cartridges have a little square chip -- like a mini circuit board -- on them which gives the printer information about how full they are. This is located on the insertion end, right next to the round black thing with the little gears on it.
For the cartridge to go in all the way, and allow the gears to properly "seat," the square "circuit board" needs to "float" just a little on the spongy thing it's attached to. So when you push the cartridge in FIRMLY, the gears seat, and the "circuit board" will end up getting pushed in about 1/16 of an inch.
I think what happens in some cases (at least with mine) is some cheap replacement cartridges don't let the "circuit board" push in at all, which means the gears don't quite seat properly, and, as they are trying to connect on the printer's gear receivers, they are constantly connecting and disconnecting, causing that loud clicking noise.
On one cartridge just pushing in the "circuit board" really hard freed it up and allowed it to "float" (be pushed in little when the cartridge was then inserted). In another case, I ended up getting a butterknife and prying off the circuit board (breaking the plastic or glue seal that was holding it) then setting back in, on top of the little spongy sticky thing it's supposed to float on.
In both cases, the cartridges were then able to go in all the way, and the clicking noise stopped.
Hope this helps!
Posted on Aug 06, 2008
Re: Samsung CLP-300 red light on; Clicking noises
Mon 12/08/2008 3:36 pm
Elsewhere on this site I described a "solution" for CLP-300 Status-always-red problem, which is to somehow defeat the microswitch sensor actuated by the plastic thing on the upper-right-hand corner of the front cover. Subsequent hackery produced a small bungee cord + rope + a piece of wood; you wrap it around the outside of the printer, put the piece of the wood on the right -- over the stupid sensor -- and that seems to work! So I could print with loud clicking noises! ... *And* the same solution works with my stupid washing machine in the basement (broken latch)....
*Then* I followed "brookjones" advice and went in there and twisted the stupid gear on the black toner cartridge -- which *successfully stopped the clicking*! Thanx loads (I tried to register my approval with the little icons but I think I failed)....
I checked the gears on the *other* color cartridges, and they definitely moved with much more ease. The b&w cartridge was pretty stuck -- but turnable when I tried hard. I would suggest trying one of the other cartridges, which probably turn easier, so you can get a feel and see how hard and which direction they want to turn in.
-- good luck
j.g. owen * * * * * * * * * * * * * * * * * * *
web: http://owenlabs.home.att.net/
Posted on Dec 08, 2008
Adf won't feed, just makes loud clicking sounds
Normally ADFs have a top feed roller and a bottom feed which turns in the opposite direction . If the top feed roller is dirty / dusty , the original will not be pulled through , Also if the original is very thick ( > 130 140 gsm )
Dec 20, 2012 | Canon ImageRunner 1600 Copier
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
Auto feed will not pick up paper, makes a loud clicking sound.
Sounds like you need a paper pick up repair kit
Go to hp.com
support, put in your machine and something like repair paper rollers
And it will kick back a kit number.
Then go to the WEB, to one of the reseller or even ebay and put in the kit number and watch what happens.
They are about 10 bucks for the smaller printers, color could be more
Feb 08, 2010 | HP LaserJet 8500 Color Printer
Why the paper get stuck while copying, and the machine make a loud noise
it may be feeding from the wrong tray. i was trying to copy short paper and it was feeding from the long paper section. this caused it to stick ever time. make sure the machine is feeding from the right tray.
Jan 23, 2010 | Sharp AL-1655CS Copier
Machine started making a loud clicking sound and wont copy
fuser roller gear is cracked... or a spring holding the bypass is loose
Dec 11, 2009 | Sharp AL-1641CS Laser Digital Copier
Clicking noise
Sounds like a clutch has spun out to me...It's going to require tech.
Mar 13, 2009 | Brother MFC-8460N All-In-One Printer
Keeps saying no paper Makes loud clicking noise
The clicking sounds seems to be made by the small gears on the side of the tray. When you move the gears, it should push a plate beneath the paper upwards, and the paper with it, allowing the paper to be feed.
I'm not sure what I did to fix it. I removed the paper and cleaned both feeding rectangles (to the front of the tray -- nearest you). One is underneath the paper and the other is in the front, center.
I then made sure that, when I move the biggest gear (the one that isn't round) that the paper moves upwards.
Jan 19, 2009 | Brother MFC-8660DN 5-in-1 Laser...
Clicking noise
the clicking noise is the gear fro the paper feeding roller. seems that the gear is broken, need to have it replaced.
May 21, 2008 | Brother MFC 8500 All-In-One Laser Printer
Outgoing fax makes loud clicking noise
2 different problems here. 1st is with document feed and 2 is with paper feed.
1st prob seems to be with the paper feed roller not meshing at the gear. Probably a broken piece on the lower document tray assembly. No real fix for this unless you can strip it out and haywire it.
2nd prob is probably a poorly meshing drum unit. Examine the gear teeth on both the drum and the machine. As you have replaced the drum already (presumably with a brand new one) You might possibly find a missing or badly worn tooth on the messhing gear in the machine.
Oct 02, 2007 | Brother IntelliFAX 2800 Laser Fax
Samsung CLP 300 Laser Printer Logo
1,648 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
