Question about Tecnik TKL9290 Front Load Washer / Dryer
Filter I cant unscrew the filter at the front right hand side base. Ive lost my manual! Is this the filter and does it open anticlockwise?
  • dave helples May 12, 2008
    I'll try, thanks for your help.
  • dave helples May 15, 2008
    dauphine, You're a Guru. Turned the machie upside down, opened the filter, A pair of tweezers! Wife apologised and were still together, the object was one I couldn't get blamed for; so an even better result.
    Champion:
  • 207 Answers
Yes, that's where filter is and it does open counterclockwise. If it seams stuck than don't force it since it frequently happens that some firm object accidentally placed in with the clothes drops trough the basket and prevents turning of filter.
What you can do would be to give filter a slight nudge, try turning it both ways, moving that foreign object with vibrations and if that doesn't help than unplugging and turning machine upside-down should do the trick. I've experienced identical problem several times with a hairpin and once with .22 unfired bullet! Just be patient with it and do not use excessive force.
Posted on May 12, 2008
  • Ljubomir Vucinic
    Ljubomir Vucinic May 19, 2008
    Hehe, I'm glad my advice was helpful..err.. I mean fixya ;-)
How to open up paslode
Use this link to parts schematic http://www.paslode.co/uploadedFiles/Cordless_16ga_straight_finish_Parts_Diagram_Schematics.pdf
Remove filter cover (1) and filter (2) remove 4 x cap screws (3) then remove top cover (5) disconnect spark plug lead and fan supply led then rotate head anticlockwise and lift it off, slide out front extrusion (56) remove 2 x screws (68) at bottom front of gun (1 each side) remove 4 x screws (80) from left hand housing cover and 1 x screw (59) from left side of handle bracket (83) Note: Do not remove right hand screw from bracket (83) you will now be able to lift the right hand housing and remove it from the groove in the nail channel, the barrel, combustion chamber and nail channel assembly can now be swung up and out of the right hand housing
Jul 01, 2014 | RTO Paslode 902000 IM250 Ii Cordless 16...
Filter on washing machine
down the bottom on the right hand side is a flap,,, open it down and you will be looking at the front end of the pump,, unscrew the plastic screw type and pull it out.. if you cant pull it out after you have unscrewed it ypou will need to tilt the machine on its back and undo the one screw at the bottom near the pump, slide the whole plimpth right and it will clip off,, now undo the 3 screws around the pump,, and the pump will drop down,, you can unscrew it from its housing then empty the **** whats inside it,, then try unscrewing it once all the **** is out... then put it back together the way it came undone.
Oct 19, 2012 | Bosch Logixx WAS2446 Front Load Washer
Where is the filter on a AW1560W washing machine
There is a small 4 inch square door on the bottom right of the front of the machine. Press the right hand side of the door and it will pop open. Pull out the small drain hose, drain off any excess water, unscrew the corcular filter cover to extract it. Instructions and pictures can be found on page 17 of your user manual. If you do not have a manual, you can download one here:
http://www.usersmanualguide.com/tricity_bendix/washing_machine/aw850w
Please rate this solution
Jul 21, 2011 | Tricity Bendix AW850W Front Load Washer
Where do I find the filter that needs to be changed
Hi
There are two types of water filter fitted to this model they are both located in the top right hand corner of the refrigerator section.
1. The standard water filter looks like an upturned bowl, to change this you need to unplug and switch off the unit, turn off the water supply and unscrew the filter around 1/4 turn anticlockwise.
Replace the filter and tighten the bowl checking that the O rings are in place. You may make a bit of a mess with water dripping out as you remove the filter bowl. These can be quite stubborn if they have not been changed before.
2.Pure source filter is on the face of the unit next to the thermostat, again shut down the unit and turn off the water before removing the filter, there is a small button lower right on the face, when you press this the filter should pop out, again spilling some water.
It is vital that you prime the system properly before using the water or ice this means running at least 2 gallons of water out of the water valve on the front to make sure that all the air is out and that pure water is in the machine.
You manual is available at this link
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241856000en.pdf
Hope this helps
Gordon
Apr 26, 2011 | Frigidaire FRS3R5EMB Side by Side...
Water is leaking from the bottom and does not discharge from drain hose
Part of the problem is that your filter is clogged. Remove the front bottom panel by unscrewing 3 small screws at the base. At the lower right, there is a filter cap that you need to unscrew by hand. Be sure to put a small pail before you unscrew it because a lot of water will come out. Then clean the filter and screw it back in.
In terms of the leaking, that started with my washer just recently. It's not the filter....think it's the rubber seal in the front. If you pull back the rubber, there are small drainage holes that can get clogged. Cleaning helps, but doesn't solve it.
Feb 25, 2010 | GE WSXH208A Front Load Washer
Cant find oil filter on a 2002 alero 2.2 liter
The oil filter on a 2.2 liter...if it is an ecotec engine is right there toward the front of the engine on the right hand side. It is a cartridge filter. Just unscrew the cap, pull out old filter with the cap. Make sure the gaskets that come with the filter are replaced and snap new filter inside the cap and replace.
Jan 07, 2010 | 2002 Oldsmobile Alero
Draining water from washing machine
Filter is normally down r/h side of machine it unscrews anti clockwise..Good luck
Oct 10, 2009 | Whirlpool AWM6100 Front Load Washer
Bosch WFF1201
At the bottom of the machine on the front, there is a plastic cover (remove by turning the plastic screws a quarter turn anti-clockwise and pull off cover). The filter is behind this cover on the left hand side. It is unscrewed by hand anti-clockwise. Tucked into the plastic cover, you should also find the spanner to adjust the feet on the washing machine. good luck and rate me....
Feb 17, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
208 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
