Question about Furuno NavNet vx2 1944C/NT GPS Receiver
I want to do a master re-set on a Furuno Navnet 2 , 1944 radar/plotter. Do you know the sequence of keys? Andy
    Scholar:
  • 111 Answers
Press and hold the alarm key whilst powering up. Also try it with the clear key while powering up again.
Posted on Jan 07, 2011
I have a Furuno Radome RSB0094-075 with a Navnet RDP 139 10.4" What I dont have is the antenna cable to connect the two units. What cable should i be ordering for this?? Thanks, Mike
That is a Furuno 1823C Radar -000-138-972 (10 meter Radar cable) $150.00 msrp from Furuno. Give their Camas Office a call or your nearest dealership. The Furuno number in Camas, Wa 888-834-9330
Nov 06, 2010 | Furuno NavNet vx2 1920C GPS Receiver
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Won't open the overlay screen
You must have a heading sensor input for radar/chart overlay. (i.e. PG500)
Jun 19, 2010 | Furuno NavNet vx2 1934CBB/NT GPS Receiver
How do i reboot my furuno navnet......recently installed radar and system not recognising teh radar installatio. no count doen on radar page greyed out overlay icons on the screen
Press and hold the "MENU" button during power on. Release "MENU" after boat appears.
Go through the installation wizard. You must select the radar type, "B" is 1834.
May 21, 2010 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Hello there, I have a 4' radar antena with a
ahh, this is an old one check the book.(ha, ha)
Press and hold menu during start up Choose "Installation Mode" Press "Menu" Select "Radar Set Up" Press "Next Page" Select "Radar Heading Alignment" Use knob and follow prompts, you will place the dotted line at dead ahaed and the
Select "Set"
Also, remember to TUNE VIDEO
Oct 08, 2009 | Furuno Navnet 1964CBB/NT vx2 Radar C Map...
Connecting power inside Furuno DRS4D
polarity is maked on the shield, on a sticker #1 is positive, #2 negative BTW, this is 48V DC (not 12V) supplied from a MFD8, MFD12, or MFDBB only.
Jul 05, 2009 | Furuno Navnet 1964CBB/NT vx2 Radar C Map...
Can I use my furuno gps navigator to supply position data to my rdp-139 chartplotter and if so which wires need to be connected
Yes the output forom the Furuno GPS (like a GP31) will be yellow and green, hook these to theinput on the plotter blue (or black) and white. Use Data1 on potter as the input and select a nav source of "ALL" in setup menu.
Jun 05, 2009 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Need owners manual for furuno navnet vx2 1834c
easy one, download here
http://www.furunousa.com/Products/ManualList.aspx?category=Products+%3a+NavNet+vx2+%3a+Radar+%2f+Chart+Plotters
Feb 22, 2009 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Radar Displays the image upside down
If this is on the radar screen, you'll have to set your heading alignment on your radar. The radar may be 180 degrees out. if this occurs on the plotter, then if you have a heading sensor attached or an autopilot, your heading may be off.
Feb 03, 2009 | Furuno NavNet vx2 GP1720C GPS Receiver
Furuno Navnet 2. Course up incorrect
you simply need an electronic compass hooked to it. without motion, the GPS does not know which way is up
Dec 19, 2008 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Open Questions:
Glitch transferring WPTS from NNVX2 to SD card G'day, After trawling through the answers section I couldnt find one to this problem so here goes..... I am having ongoing problems trying to transfer waypoints from the VX2 to SD card. OK, so I am going through the motions in: "system configuration" / "transfer data" / "download to SD card" / I select "ON" for "waypoints" and "settings"...this is where the fun begins. I've tried two ways without luck.... 1. the SD card out method. I follow steps above to get to final save/transfer of data / remove Navionics card / press "save" using the soft key / unit displays "insert SD card and press enter to continue".....I insert card....nothing happens. 2. I insert SD card early on. advance through the above steps again but once I get to the page where you select which data to transfer/save to card (settings, waypoints, routes, marks) the unit goes non-responsive and i cannot actually select "save" to begin the transfer as its essentially frozen. NOTE: When I remove the SD card, all functions commence working again as normal. Question: When the transfer beigins does the VX2 display a message such as "processing now" or "downloading data"? Secondly, how long would 500 waypoints and setting take to download? a few minutes or considerably longer? Background: I have 2x VX2 screens linked by NMEA (Use one for GPS and other for sounder) and getting the same result from both units/SD slots so dont think its unit specific. I am using a 4GB SD card off the shelf from the local electrical store. Happy to hand it over to to a more learned technocrat and sincere thanks in advance if anyone has any ideas.
Jan 06, 2013 | Furuno NavNet vx2 1944C/NT GPS Receiver
Furuno NavNet vx2 1944C/NT GPS Receiver Logo
198 people viewed this question
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
