Question about Breitling Navitimer World 715 A24322 Watch
I have a navitimer world which i bought second hand a couple of months ago, but it seems to be losing time, it loses a minute or 2 a day, and every few days i need to reset the time,i wear it all day and take it off during the night,i am wondering if the self winding movement is sufficient for it or should i be winding it manually every day. Thanks Jimmy
    Problem Solver:
  • 5 Answers
Without seeing the inside works (movement) of your new (to you) watch and its parts, it's impossible to tell exactly what is going on, but no need to worry, as that's what competent watchmakers are for. Probably just needs a new spring, which wear over time due to many factors, including temperature, shock and corrosion. Basically, when you wind up any mechanical watch (whether automatic or hand-wound, regardless of age), you're tightening the spring which in turn is what powers up the watch (powering up the gears as it returns to its original position--i.e., unwinds, accuracy dependent thus on the spring among other factors). Sounds to me like it just needs a routine service, mechanical watches being no different than are automobiles, which require regular service as well. In the case of a watch, this will entail a cleaning, fresh oil and regulation, with old springs often simply swapped out for a new ones at that time by a watchmaker; routine services are a standard procedure which can be performed by any competent independent watchmaker, and don't cost a lot either. Most watch manufacturers recommend such service be carried out every 5 years or so, and while some can go longer (especially if not worn daily, same as a car when it comes to oil changes/service intervals), it's important to remember to service your mechanical time pieces which, if you do, will provide you with decades of reliable time keeping. All the best.
Posted on Jul 31, 2012
4 Suggested Answers
smitty5609
  • 243 Answers
SOURCE: Twenty year old Timex Automatic (self-winding).
If its a good watch, take it to a watchmaker. Dont know to find one 30 yrs ago they were inevery city
Posted on Oct 05, 2011
  • 10 Answers
SOURCE: watch stops or loses time every time i wear it.
normally automatic watch need to wear at least 8hrs in a day ,then it works for next 30hrs.if it stops or loosing time, it indicates that needs service with lubrication .
Posted on Feb 23, 2010
  • 2501 Answers
SOURCE: WATCH ON DESKFOR 24 HOURS
When a watch is on a desk, the balance wheel is vertical, when you are wearing it the balance wheel horizontal.
Has the watch been dropped onto a hard surface?
If the balance wheel bearing is worn or has suffered a large shock, then the shaft may move in its bearings or the bearings damaged, which may give the problem you decscribe.
Take it to a watch repairer to have it adjusted or repaired.
Posted on Dec 27, 2010
Replaced battery on Timex Indiglo WR30, now it loses time. Second hand hangs uo when it reaches area between 11 and 12, then continues on seemingly ok
need to put in fresh battery I know you may have just bought new one but it is old check for date on back package
May 13, 2017 | Timex Watches
My Juicy Couture watch keeps losing get time about 30 minutes just bought it 2 weeks ago
Take it to a local jeweller and ask them to calibrate it which is done electronically. Fakes are renown for losing or gaining massive amounts of time.
Dec 29, 2016 | Juicy Couture Watches
My omega deville ladies prestige quartz is losing time. There is no second hand on the watch and the minute hand seems to tick every 10 secs or so. It has just had a new battery replaced by omega...
Yes. The minute hand ticking every 10 seconds is normal. Losing time is either battery or a movement malfunction. Only a trained watchmaker (or presumably Omega) can determine which. Take it back to Omega
Oct 10, 2012 | Omega De Ville Prestige Quartz Small...
My Carrera automatic does not keep time, it loses at least 2 minutes a day
2 minutes a few months is OK but 2 minutes a day is too much. Bring it to service center for clean & service.
Feb 17, 2011 | Tag Heuer Automatic Chronograph Series...
My A24322 is not working. Pl let me know how to get this started. Is this an automatic watch or a winding watch?
Your watch is an automatic (self winding) watch which can be started by swinging it gently from side to side for some minutes to wind the spring up.
For details see their web site by inserting the following link into your search engine http://www.breitling.com/en/index.php#/models/navitimer/navitimer-world/.
Self winders rely on being used to keep them wound and operate best if used every day.
Jan 08, 2011 | Breitling Navitimer World 715 A24322 Watch
The digital display of my Breightling Navtimer does not match the minute hand on the watch, it is out by about 4 minutes. How do I synchronize the time?
If you go to http://www.breitling.com/en/index.php#/bwt/ you will see "download ....world time". This is not the usual user instructions but a program that runs on your PC.
I have not tried it but this may be of help. If not, contact Breitling and ask them.
(I am envious, it looks a smart watch!)
Jun 07, 2010 | Breitling NEW BREITLING NAVITIMER WORLD...
Watch erratic. Slows suddenly between days of working well.
Sounds like a failing battery to me. Its very common for a watch to loose time when battery needs to be changed.
Jan 09, 2010 | Timex Watches
New watch is losing 5 to 15 minutes a day
This could be that the battery is slow. Newer swiss watches have a indicator in the movement of the watch that makes the sweep second hand skip every few seconds to indicate that the battery is slow. On regular japan made watches the watch just simply starts slowing down. Your watch could be new but the battery in it could have a long shelf life.
May 11, 2009 | Kenneth Cole KC1104 Wrist Watch
Breitling Navitimer World 715 A24322 Watch Logo
219 people viewed this question
Top Breitling Watches Experts
Ansel Alberto
Ansel Alberto
deton8 von Splosion
Are you a Breitling Watch Expert? Answer questions, earn points and help others
