Question about Plextor ConvertX PVR (PX-TV402U-NA/MAC) (PXTV402UNAMAC) Video Capture
I have this unit, and the driver CD for windows XP. Now, I am installing this unit to my new computer running windows 7. Do I need a undated driver, or my existing CD will work. My unit model number is convert X PX-TV402U
  • 166 Answers
It will work though it will show certain problems while performing it's functions. Updated driver is necessary as Windows 7 and XP are different.
Also, sometimes, the drivers won't get installed as it is made for XP.
Posted on Sep 05, 2010
Plz help to get my scanner work.............. BENQ 5000B Scanner For Windows 7 32-bit
Hi ,
You need to use the install cd that came with your unit but probably it won't run under Windows 7 .
The only work around possible is to install a virtual version of Windows XP on your drive : http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
Wish you good luck , otherwise you will need to purchase a compatible unit .
Regards .
Dec 14, 2014 | BenQ Office Equipment & Supplies
Drivers of ben Q scanner 5000 serial no ISHA503447SS0T
Hi ,
You need to use the install cd that came with your unit but probably it won't run beyond XP . Starting from Windows 7 ,
the only work around possible is to install a virtual version of Windows XP on your drive : http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
Regards .
Jul 04, 2014 | BenQ 5000U Scan to Web Scanner
I have ask you already how to install the dual boot os(Windows xp and Windows 7 ), but i don't complete yet .Can you explain to me again step_by_step in great detail ? because when i install windows xp...
Hello, this is how I dual boot my laptop with windows xp and windows 7
1. Backup all you important files, use an external hard-disk if possible
2. Make sure you have two drives or partitions: usually drive C and D
3. Insert your xp cd, do a quick format of drive C and install
4. Boot into windows xp and format format drive D if necessary
5. Insert your windows 7 DVD and follow the prompts. When it asks you to upgrade or new install, choose new installation
6. When you are asked to choose a location choose drive D
7. Complete your windows 7 installation
8. Thats it, you can now install drivers and programs
When installation is complete you will see both os options: windows 7 and previous version of windows (i.e xp)
I have done this numerous times without the need for any other step or software. The only rule is to is to install xp first, then windows 7.
All the best
Jul 11, 2011 | Computers & Internet
My Acer Aspire 6920G does not detect nor play bluray discs after switching to Windows 7. I may be missing drivers but have no clue what and where to get them. Please help.
Hi goodevening
there so so many reason why does not detect a blueray disc after you switching windows 7
1st may be your cd/dvd driver have a problem,
(solution) try to use other cd/dvd driver
2nd may be the window 7 installer you've use have a missing file.
(solution) try to re install the o.s but dont use the same cd you've use try other installer.
3rd your blueray disc is the problem
(solution) use your blue ray disc in other p.c window xp if running in xp try to use other pc using a window 7, if running in other unit may be your pc need to upgrade.
May 14, 2011 | Computers & Internet
Lan setting went off after formating my pc
Try restarting your computer several times if the new OS you installed is XP. However, if your new OS is Windows 7, there is still no problem. If you have not yet installed a windows 7 drivers cd,you will need to get the driver cd for windows 7, and I'm sure there are other things you've not noticed. Otherwise, if your drivers have been correctly installed, just restart your system; the lan driver will automatically install on system start up.If it doesn't install, you should get the lan drivers, depending on your product. Finally, I have both HP and DELL drivers, but I don't have a site yet. Hope the above information helped.
Apr 21, 2011 | Computers & Internet
I was running Windows XP Professional with motherboard drivers given on purchasing the computer. Then I installed Windows 7 Ultimate and the drivers are not working. I'm on Intel Pentium 4 series. When...
Hi, the problem here is that you may well not find the drivers for windows 7, and to re install XP you will need to reformat your hard drive; for this you will need to change your primary boot device to CD Rom, and then boot with your XP disk in drive, selecting boot from CD when it appears. Re partition and reformat and after reboot it will start to install XP.
Hope this helps
Sep 09, 2010 | Intel Computers & Internet
We install windows xp prodesional on this motherboard, but it shows absence of audio driver. what is the reason?
If you got new motherboard you should have got new driver of driver which is the need of your motherboard.
Install your driver inside the CD-ROM or DVD-RW to run your disc on computer.
Add your driver by following the instructions of the installation process.
If you have not the same driver then find it by right clicking on the my computer>device manager
And then find your audio driver.
Feb 27, 2010 | EliteGroup P6STP-FL Motherboard
775i65g Drivers for windows 7? please help
windows 7 will use the xp or vista drivers.
you may need to install it manually
1.) click start
2.) right click computer
3.) click properties
4.) click device manager
5.) make sure your driver cd is in the cd drive
6.) right click any device with a yellow marker and select update driver
7.) follow the on screeb instructions for windows 7 to browse and install the drivers for you.
If you have an internet connection run windows update
the drivers will be in the updates.
if you have to download the drivers then u will need to unzip it to a folder and specifiy that folder when you choose to update your device. (6.7 above)
drivers can be downloaded from the manufactures web site for your device.
Feb 26, 2010 | Asrock 775i65G Motherboard
HP 520 Notebook. Shuts down before installing new OS.
I agree a clean install is always the better, fresh start J
OK it sounds like missing drivers, what you have to do is create a new installation CD that will load the drivers for your laptop as it boots. I haven’t try this method with windows 7, but I know it works well with Windows XP. Try and create a new Windows XP CD with the drivers see: http://unattended.msfn.org/unattended.xp/view/web/35/
The start a new installation with this Windows XP CD and reformat you computer, after that you can do a new upgrade to windows 7
Nov 25, 2009 | Office Equipment & Supplies
Plextor ConvertX PVR (PX-TV402U-NA/MAC) (PXTV402UNAMAC) Video Capture Logo
276 people viewed this question
Top Plextor Televison & Video Experts
Electro Med Services...
Are you a Plextor Televison and Video Expert? Answer questions, earn points and help others
