Question about Whirlpool Duet GHW9150P Front Load Washer
Control panel locked. How do you unlock it? Cant find manual.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 05, 2010
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 | GE Dryers
I cant unlock it
When you enable the Control Panel Lock function, you can lock all of the projector's buttons, or all of the buttons except the Ppower button. The remote control can still be used to operate the projector.
1. Press the Menu button, highlight the Settings menu, and press Enter.
2. Select Control Panel Lock and press the Enter button.
3. To disable the Control Panel Lock function, select Off in the Control Panel Lock menu.
4. Select Yes and press Enter to confirm the setting.
5. Press the Menu button to exit.
*- Or press and hold the Enter button on the projector's control panel for seven seconds. A message is displayed and the lock is released.
If you need a manual for your unit, goto here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=140128&prodoid=63085205
and click "Users Giude".
Jun 19, 2012 | Epson Powerlite S7 3lcd Video Projector,...
The controls locked is displayed. what causes this and how do i get the controls unlocked.
Jan 11, 2011 | Whirlpool GEW9250 Electric Dryer
My washer is locked and i cant unlock it i already tried the control unlock , lock bottom and its still lock i need to take out the cloth that is inside
You have a door lock issue not a control panel lock issue.You can manually unlock the door.Start by unplugging the washer,remove the front lower panel at the bottom of the unit their are 3 small screws on the very bottom next to the floor ,remove them then pull out on the bottom of the panel to remove.Now you can reach up inside the unit near where the door handle is on the outside and you will feel a small ring that you can put your finger thru.pull down towards the floor on the ring and that will manually unlock the door. While there clean out the drain pump strainer right there in front in case its clogged if in does not drain properly in will not unlock the door.Make sure to put something under the pump to catch the water that will come out..At least you can get your clothes out. After checking the pump if that's not the issue write back and we will diagnosis from their Good Luck
Sep 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control locked light is on and cant get the washer to do anything
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent children from manipulating the controls and accidentally starting the appliance.
With the lock turned on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite, Maytag Epic or Whirlpool Duet), the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem other than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance.
Jul 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control panel locked,how to unlock
The Control Lock is actually a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. This can usually be reset and does not require a technician.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured front loader, the following link explains how to lock/unlock this feature:
If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem or main control board issue).
Please post back if you still need assistance. I hope this helps you.
Apr 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I cant find my book and my washer wont do anything the control locked button is red and nothing works
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. It can inadvertently be set following a power outage, or by leaning against the control panel.
If this is a Maytag Epic, Whirlpool Duet, or Kenmore Elite, the following link explains how to lock/unlock this feature:
These instructions are also printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
NOTE: If you cannot locate your owner's manual, you can download or print a FREE copy at managemylife.com. Just type in your model number under the "Manuals" link and you will find your manual listed in a .pdf (Adobe) format.
Feb 09, 2010 | Maytag EPIC MFW9700S Front Load Washer
Control locked
On some front loading washer there is a button that when held for 3 to 5 seconds will lock the control panel so young children can't change settings. Look at your control panel for writing under a button that will tell you to hold down to lock or unlock panel.
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Unlock the control panel
I think it is the Control On button and the cancel button. My locked and I can get it to shut off but it won't come back on.
Dec 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a maytag quiet series 100 dishwasher and it will not run a lock light comes on and i have replace a broken handle assembly but light stays on
the control panel is locked. dont know your model number to tell you what buttons you hold to unlock it, but some models have a lock button you hold down for 3-5 seconds. other models just have a lock light, and have a line indicating 2 buttons that you hold down for 3-5 seconds. if you cant find which buttons to hold down, refer to your owners manual. once the control panel is unlocked, it will run again. shane
Sep 01, 2009 | Dishwashers
Whirlpool Duet GHW9150P Front Load Washer Logo
23 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
