SOURCE: spacemaker beeping loud and f3 message driving us crazy
The error code F3 indicates an oven sensor problem. The oven sensor is most likely the failed part. The oven sensor probe must have the correct resistance readings at specific temperatures. When the electronic range control (ERC) cannot identify the correct resistance of the oven sensor or the resistance is way out of specs F3 will display.
I recommend calling a service technician to diagnose and repair your oven.
SOURCE: What does the F3 alert
F3 is a shorted keypad. Unfortunately you need to replace your touch pad to correct the issue. This can happen sometimes from moisture getting into the keypad from boiling water, or it can happen for no reason at all.
Sorry there is no parts available for the microwave.
Good Luck please rate 4 thumbs up and please leave a testimonial
Error code F3 on many models of
microwave oven means a problem with the touch panel, (tact switches).
Replace the switch panel to fix the
fault. Spares can be aquired through your GE dealer. Visit GE's web site for a list of dealers and spare parts suppliers.
Hope this helps.
