My old vpr machine is leaking water out of the side of the water tank, any suggestions or is it time to get a new machine My old vpr machine is leaking water out of the side of the water tank, any suggestions or is it time to get a new machine
You can't post conmments that contain an email address.
Re: my old vpr machine is leaking water out of the side...
Sorry to say but it is time to get a new machine.
You can get a new tank but the cost is kinda high.
Please follow LINK for parts list. On line you can find the parts or at www.bunnomatic.com
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
Aloha, ukeboy57
Aloha, ukeboy57
VPR is a pour over "Volume Displacement" brewer. Required to completely fill the inner tank and heat prior to using brewer. BEFORE plugging in unit, water must be poured into upper tray and with brew funnel and empty pot in place. Keep pouring water into top fill tray until water drips out of brew funnel. Plug in VPR and allow it 15-20 mins to heat up. leave the pot as there may be additional water dripping. Remove power if there is any water spilling out from other places like the top pan cover or bottom of machine. With the initial heating done, take a full pot of water and slowly pour into the top filling tray. HOT steaming water should come out of the brew funnel to fill the (empty) pot. Prep is done and the machine can be used to brew a pot after 10-15mins of reheat time.
*** the machine you have needs to be checked for leaks in areas mentioned above. Water should only come out of brew funnel (if not present then the brew head or if that is missing then the brew pipe. All will need to be replaced prior to brewing.) Leaking under machine is an indication of leak(s) in pour tray,tank,tank cover, gasket, probe gasket. This machine like any used equipment should be checked out by qualified tech prior to use. Be aware that coffee vendors sometimes rent or loan brewers to customers.
It sounds like the tank isn't full. Unplug the machine and make sure
there is a pot underneath to catch water. Pour clean water into the
tank until it starts flowing out. Plug the machine in and let it heat
up. Then try brewing coffee.
The way your machine works is
that there is a holding tank for the water and it isn't actually
brewing with the water you just poured in, it is using the holding tank
water. If the holding tank gets low, and you pour water in all it does
is fill the tank but nothing will come out.
