Question about Briggs & Stratton Garden
Bolens MTD push mower with B&S 4.5HP 10H902-0285-E1 (SN-03122354).. Runs rough (pulsing) after cutting on an incline where mower was tipped to the right (carb) side.. It seems as if oil leaked over into the carb/intake.. removed carb, cleaned, replaced diaphragm, and reinstalled.. now running smoother but low RPM and will hardly cut without bogging down or stalling.. I cannot find any adjustment screws on this model carb - is that correct? I cannot find a diagram of the linkage springs.. and should I suspect a blown gasket somewhere?
    President:
  • Briggs & Str... Master
  • 1,545 Answers
This is probably not a blown gasket issue. A bad head gasket can allow oil to enter the cylinder head/combustion chamber if it's not sealing off the valve area. A simple suggestion is to check on the engine opposite the carb side for the oil/crankcase breather. It will have 2 screws holding it onto the block. It has a type of filter media in it that traps excessive oil and oil vapors from the engine. It is also connected by a tube to the air filter housing. When you tipped, you probably put too much oil in the breather and it was inducted over to the air filter/carb intake side.
Clean or replace the breather after checking it and also make sure you haven't overfilled the Briggs with oil and only use SAE 30 in the engine. Muti-viscosity isn't recommended in summer unless you run synthetic, then it is OK.
Please vote on this solution.
Posted on Sep 05, 2010
Testimonial: "Thank you - sounds like excellent advice and I'll sure let you know what I find."
  • 5 more comments
  • destindave Sep 06, 2010
    Well... that wasn't the problem.. I finally removed the carb again and danged if the diaphragm wasn't pulled in from the edge a little and misshapen - actually separated into 2 halves in some places.. my guess is the carb housing isn't making a good tight seal all the way around.. off to the parts place tomorrow for another diaphragm and maybe a new carb housing..
    When I installed the last diaphragm I believe it came with a gasket too but the old one didn't have one on so I didn't use it.. seems to me the instruction mentioned not using one for my particular model..(?) Any thoughts on that?
    Thank you for your help..
  • Roy Cagle
    Roy Cagle Sep 06, 2010
    First, a diagram of your carb's linkage/springs for you: http://www.lawn-mower-shop.com/carb2.htm
    Secondly, from the Briggs site;a parts breakdown of your general models carb..(includes the whole engine assembly too). http://bsintek.basco.com/BriggsDocumentD...
    I really hope this clears things up for you as I haven't worked on these tank mounted carbs before.
  • Roy Cagle
  • Roy Cagle
    Secondly, from the Briggs site; a parts breakdown of your general model's carb..(includes the whole engine assembly too). http://bsintek.basco.com/BriggsDocumentD...
  • Roy Cagle
  • Roy Cagle
  • Roy Cagle
    Champion:
  • 225 Answers
If you suspect a carb problem that's causing the diaphragm to pull in then just buy a replacement carb, they are very cheap and come with a diaphragm kit in the box.
Posted on Nov 28, 2014
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,917 Answers
Need to adjust govener or ead gasket blown
Posted on Nov 27, 2014
    Problem Solver:
  • 13 Answers
You have a float problem its either sticking or spring too weak.
Posted on Nov 06, 2010
Bolens 13ac762f
if blades are turning mower is cutting better to go forwards though
Sep 11, 2013 | Mtd Garden
Where can I find a Briggs & Stratton 450 series 148cc magneto?
best place is from a B&S mower shop. Try e-bay as well as they are available on line. may be you know some one who has a mower that is not going that you can get the unit from it.
Jun 17, 2013 | Garden
What is the spark plug gap on a 4.5 HP 21" cut
With out the model # of engine or plug not 100% certian but 99% of those mower engines run a .8 or .9mm plug gap you will be preety safe setting it at that
Regards
Brad
Feb 05, 2010 | Mtd Products Yard Machines 158CC Tiller
L have a Bolens 12 Hp ride on mower purchased new 1992 l have not used the mower for the last 7 years due to update to a larger mower.L'd like to have the bolens as a spare mower. What is missing from my...
Bolens is now owned by MTD. Find parts for your machine at http://www.bolens.com/webapp/wcs/stores/servlet/topcategory_10151_15953_-1 or your local MTD/Bolens dealer
The bigger challenge you will have is getting the engine running again unless you have maintained it the past 7 years. My free advice is get the motor running and make sure the tractor still functions before you start adding accessories. Once you have driven it around the block once or twice, then get the parts you need to operate the deck. I think these parts will be a little pricy.
I say these things because of a similar experience with a International Cub I got. I spent a lot of money to get the mower running before I got the tractor running, reliably. I didnt get my fair value from my $ as a result. I then bought a geenuine Troy and have never looked back. (MTD owns the Troy brand now also.)
Good luck with your project
Thanks for using FixYa.com
Please vote
positive comments appreciated by volunteer question catchers.
a
Dec 12, 2009 | Radio Communications
Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Aug 04, 2009 | Garden
Yard machine 21'' push mower runs 2 to 3 seconds cuts off.
Tip the mower up on it's side with the dipstick tube on the down side and collect it in a suitable container. The gas you can do the same. When I drain old fuel, I mix it with a lot of fresh fuel and a bottle of dry gas then run it in my car.
Apr 23, 2009 | Mtd 22" Yard Machine Push Mower
I have a bolens 36" ride on lawn mower 12 hp and i have have broken the cutting deck bels and i have bought the reokacement but i cannot work out how it goes on correctly the model number for the bolens is...
Hello can I please get your model number please. To find out where it is please refer to the link below:
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10151&LeftNav=true#
Then click on the "click here" to find out how to find it out.
Dec 01, 2008 | Garden
Garden Logo
2,332 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
