Question about Mercury PVCLE266 Motherboard
Monitor problem I connected my CRT monitor to the motherboard but it does not show
  • 45 Answers
Is it powered on? Check the power cables...
Posted on May 12, 2008
K8NF4G MOTHERBOARD IS NOT WORKING
Your Video Card (Graphics Card) is probably bad. To isolate the problem connect another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays the same NO Signal Message then your video card is bad. If the Borrowed monitor displays and works correctly, then your original monitor is bad. The fact that your monitor displays the No Signal Message on it shows that the monitor is ok.
If you have a laptop, the video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 30, 2012 | Asrock K8NF4G-SATA2 Motherboard
My emx-mcp61p-avl has power but no display no beep. video card is new and compatible with my motherboard. RAM is new also.
Just because the ram and video card is new does not mean they work. But since you say it has power, I'm assuming it boots up all the way except the screen is not displaying.
If this is a laptop try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
If it is a desktop try the steps below.
Try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor shows the display, then your original monitor is bad. If the Borrowed monitor does and same as your original monitor and does not show a display then your video card has an issue.
May 30, 2012 | Computers & Internet
When irower on cannot display
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 20, 2012 | ASUS P5KPL-AM SE Motherboard
Screen blank with white dot
Problem with;
1) Video cable:
A) Video cable connection on motherboard side is loose, and/or on back of LCD screen.
B) Video cable is damaged.
2) screen Inverter:
screen Inverter is bad.
3) LCD screen:
LCD screen is bad.
4) Graphics chipset:
Graphics chipset is bad.
Suggest you connect a VGA monitor to the VGA port (Connector) on your laptop.
See if the problem is the graphics chipset, Or video cable, Or display assembly.
You didn't state what manufacturer and Model Number of laptop this is.
All I can do is state generic information.
This is an example of a VGA Cable, and VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
The VGA connector will be on the side, or back of your laptop.
For the VGA monitor you can use a CRT type monitor, (Looks like a small TV), or a flat LCD screen monitor that has a VGA cable.
Laptop OFF, monitor OFF, connect the external VGA monitor to the laptop.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should show on the external VGA monitor.
IF not;
There are at least 3 display options.
1) Laptop internal monitor ONLY
2) Laptop internal monitor AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold down on the Fn key, and at the same time tap once on the Display Toggle-Over key.
(For an example HP's usually use the F4 key for a Display Toggle-Over key)
Display shows the same on the external VGA monitor?
You have a bad graphics chipset.
[ Some laptops have been erroneously stated as having a graphics card, when in fact they do not.
The GPU (Graphics Processing Unit) is soldered directly to the motherboard.
This is Integrated Graphics.
http://en.wikipedia.org/wiki/GPU
There is no changeable, replaceable graphics card. Therefore the solution is motherboard replacement ]
IF, the display is good on the external monitor, you have a problem with the Video Cable, and/or in the Display Assembly.
After diagnosing with an external VGA monitor, post back in a Comment.
Also post the manufacturer name, and model number of the laptop.
Regards,
joecoolvette
Apr 22, 2012 | Computers & Internet
Im useuing a lg crt 15 inc monitor, few days ago im connecting my pc with samsung lcd 22 inc monitor, but the problem is when im re connecting that crt monitor its only show out of frequency.
the resolution might be too high for the CRT monitor, try to lower the resolution if your going to connect the CRT monitor..., the 22 inc monitor obviously have much higher resolution that the 15" crt monitor. i think the max for that is 1024x800.. hope this helps :)
May 10, 2011 | Computers & Internet
Intel DG31PR Motherboard BIOS menu and motherboard LOGO not visible properly in my HP 7550 CRT MONITOR. but i plug LCD MONITOR and it show menu and logo properly. pls solve this problem to me because i...
The reason is that your CRT monitor has a low refresh rate, and the motherboard logo etc just displays for briefly seconds.....so your monitor doesn't react as soon as the signal is sent from the motherboard... Sorry you can't change monitor....
Jun 11, 2009 | Intel DG31PR Motherboard
Intel DG31PR Mother board BIOS menu
le quitas la bateria(pila) antes de encender, la enciendes y espera unos minutos. Luego colocas la bateria y actualizas la hora en el setup
entonces reinicia y problema resuelto
Jun 10, 2009 | Intel DG31PR Motherboard
Newly built computer starts up without using switch
No signal means, monitor has not been connected. (for crt s) and, on startup (for lcd s) . Easiest solution should be, PLEASE REMOVE AND PLACE THE RAM TIGHTLY AGAIN. i hope, it will solve the problem, if you have recently traveled with your cpu.
Apr 04, 2009 | Intel D915PGN Motherboard
My LG CRT monitor does not display any thing when powered on
My LG CRT monitor does not display any thing when its powerd on .
May 21, 2008 | LG Studioworks 563N 15" CRT Monitor
Mercury PVCLE266 Motherboard Logo
18 people viewed this question
Top Mercury Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Roshan Rijal
Roshan Rijal
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
