Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
When you turn it on the power button in front flashes 3 times and the tv dosent turn on
Is there a way to test the fly back to see if it is working or not....i had a guy look at my tv and he said he would have to take it out to check it...
  • RCA Master
  • 8,617 Answers
If the front led blinks 3 times slowly then shuts off its most likely the flyback. Its available at the following link for under 50.00 and they will provide free tech support on line so you can change it yourself takes about a half hour start to finish. You will need Flyback number 259296 Heres the link
http://servicemanuals.vstore.ca/
Posted on May 12, 2008
No sound or pic, red light flashes on the front?
solution
step 1 : at first test your fly back transformer
step 2 : A.C. transformer test
step 3 : test your TV tube just leak problem, I think
Send report :babul_jpi90@yahoo.com
Jul 28, 2011 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Sony Trinitron color TV 36 inch
hello,
You should examine the input power of the TV. If you dare to open the back of the TV You should examine the by using the tester to test the continuity of the voltage input of the TV. i guess voltage regulator need to be tested.
Be careful high voltage inside the TV.
The best way is to contact the vendor of the TV or sony service center in your area.
may this help,
melnavz
May 12, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Mitsubishi projection tv picture and sound turn off but the power button remains on with no picture or sound turn tv off real quick and then back on and works for 2 mins then turns off again what could be...
Here's the basic troubleshooting:
  1. Make sure that no front panel buttons are inadvertently stuck in an "engaged" position.
  2. Disconnect ALL devices from the TV.
  3. Press the SYSTEM RESET button and hold for 10 seconds. Proceed if the problem still exist.
  4. Press and hold POWER and MENU buttons simultaneously for 20 seconds. Proceed if the problem still exist.
  5. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours.
  6. If it still shuts down, press the DEVICE and MENU buttons on the front panel simultaneously and hold it for 5 seconds to activate the Error Code Operational Check. The status LED indicator will then flash denoting a two digit code.
  7. Count the number of flashes then pauses for about a half second then flashes again. The first number of flashes indicates the first digit of the error code and the second number of flashes indicates the second digit of the code. For example, if the error code is "35", the LED will flash 3 times, pauses, then flashes 5 times. The error code is repeated a total of 5 times.
Please let me know the code you got and I'll tell where the problem lies and how to fix it.
Dec 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Power light flashes 3 times then nothing
this sounds like the typical bad fly-back transformer that is also known as the high voltage transformer, n=-Not really a repair for a novice so unless you know all of the safety notices with this set please do not attempt this repair as why save 100 bucks for something that could seriously kill you!!!!!
Sep 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV wont turn on...red power button flashing
HI. this is a malfunctioning fly back transformer. it is connected directly to the picture tub, and is part of the main power sector as well. The fly back transformer can become covered with lint overtime. this will induce a very violent arcing effect that will usually blow the entire power sector.
Replacing the fly back and affected components will fix this issue.
Jul 30, 2009 | Sony Televison & Video
more than likely the sony has a bad flyback
It is available from
www.electronix.com
Thanks Guy
May 19, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
RCA D52W25
Thats possibly the flyback causing that. If you need more help with the problem or how to change the flyback, let me know
May 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
