Question about Garden
Don't know how to routedrive belt on dixon 4516k zero turn lawn mower
5 Suggested Answers
  • 24 Answers
SOURCE: Ford YT-16-G lawn mowers
I need the model number of your mower. Like for example....09GN2151
Posted on Aug 15, 2009
bargainbin2
  • 123 Answers
SOURCE: 13.5 hp Craftsman lawn mower 5-speed
Here is a picture to help you place it on right. There are two deck designs pick yours.
Posted on Aug 29, 2009
  • 2239 Answers
SOURCE: I want to change the spark plug in my 1988 yardman riding lawn mower but don't know what size socket needed to remove it?
Most common size is 19mm
Posted on Mar 13, 2012
  • 21 Answers
SOURCE: i need the drive belt diagram of the cub cadet
3 yrs later.
To find belt diagram, Look for a diagram sticker underneath the driver side foot rest. (faces the ground). Goodluck people.
Posted on Jun 13, 2013
Mower blades start an stop on Dixon zero turn 42 in deck
PDF]OM, ZTR 5421, 1994, ZERO TURN: CONSUMER - Dixon
www.dixon-ztr.com/ddoc/DIXO/...USen/DIXO1994_USen_5421_.pdf
The information in this operator's manual applies to all Dixon ZTR Model 5421 Mowers. .... Before backing your Dixon Mower; stop, turn around and look. 13. ... startsvibrating, and any damage should be repaired before restarting and ... 13 GA stamped steel construction, 3 blades, 42" cut width, cut height approximately.
Sep 17, 2015 | Garden
Dixon 5020 mowerhow do i install drive belt on 5020 dixon
If, and I'm sure it is, like all other riders, remove the deck, turn the mower up on it's side and supported with a lawn chair or the like, it won't hurt the mower, remove the electric deck drive unit from the crankshaft by taking the center bolt out and pull it off, remove the clutch tensioner far enough to get the belt off it, then remove the belt from the motor pully and the hydrostat drive pully and pull the belt out towards the front. replace the belt with new one and put it back together.
Oct 15, 2014 | Garden
Belt pattern for blade drive belt on Dixon ZTR6022
Try googling for the owners manual to view that
Oct 04, 2014 | Garden
Troy Bilt Mustang XP mower belt diagram
https://www.partstree.com/parts/troy-bilt/mowers-zero-turn-lawn-mower/17wfcacp011-troy-bilt-50-mustang-xp-zero-turn-mower-2013/mower-deck/
Aug 27, 2014 | Troy Garden
Carb problems
check and see if all your carb jets or clean sound like some dirt got into one
Jul 07, 2014 | Dixon Ticonderoga NEW 52" DIXON ZERO TURN...
What weight of hydraulic fluid is used in a dixon lawn mower
The motor takes 30 SAE. the drives take 20/50 SAE motor oil. I contacted the manufacturer of the hydro gear drives to find out what was used when I rebuilt one. There is only one manufacturer of all hydro gear drives. Their recommend Mobile 20/50 SAE.
Apr 05, 2013 | Dixon Ticonderoga NEW 61" DIXON ZERO TURN...
How to connect a 4 post solenoid to a dixon 4516k mower
does it click when you turn the key if so you have a bad solenoid or a bad starter
Apr 13, 2012 | Garden
I need a left rear axle for a dixon mower it is bent so the chain jumps off, and a diagram of the rear assembly. It is blue with the levers between your legs, it has a 12hp motor. I am not sure what year...
You can eventually find your manual here:
http://www.dixon-ztr.com/node2171.aspx
There are a ton of manuals.... on that page. Looks like it will be a tedious hunt with out a model number.
If the link does not work go to
and click on support.
If you can come up with a part number you might be able to get it here:
http://www.lawnmowerpros.com/Dixon.htm
They also have parts manuals on this page:
http://www.lawnmowerpros.com/Dixon/Dixon-Parts-Diagrams.asp
Thanks for using FixYa.
Kelly
Mar 09, 2010 | Mtd LAWN MOWER PART # 903-0382 AXLE...
Garden Logo
276 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
