Question about HP Pavilion dv4000 Notebook
Hi, I have hp entertainment note book Pavilion dv4 1106em. I am facing touch pad problem, my touch pad starts moving randomly when i place my finger over it, i have tried many setting like lowering the sensitivity of syneptic touch pad etc. but it does n't work, when i restart my computer, touch pad works well, after some time it loses control and starts even clicking randomly. can anybody help me? please
    Guru:
  • 689 Answers
You should be able to disable it altogether,thing about another mouse,common manufacturers fault
Change operating system (to Linux!)
reinstall OS
Posted on Sep 05, 2010
When I load papers into the document feeder on top of my HP Officejet 7210 All-in-One printer to scan these documents, the PDF file (scan results) have a multi-color series of lines from top-to-bottom on...
  1. Remove all originals from the document feeder tray.
    NOTE: It might be easier to work with the automatic document feeder if the document feeder tray is removed first.
  2. Lift the cover of the automatic document feeder. Figure 1: Lifting the ADF coverc00222493.gif
  3. Lift the lid on the HP all-in-one, and locate the notch near the top right edge of the lid backing. Figure 2: Locating the notch near the lid backingc00222494.gif 1 - Notch 2 - Lid backing
  4. Place one or two fingers in the notch, as you lower the lid of the HP all-in-one. Keep your fingers in the notch until the lid is almost closed. Figure 3: Inserting fingers into the notchc00222495.gif
  5. Push against the top of the face plate with your thumb as you pull the bottom away from the right side of the HP all-in-one with your fingers. Use a slight twisting motion to help release the face plate on the right side.
    CAUTION: Do not pull the face plate all the way off yet. There is a plastic catch on the far left inside of the face plate that helps secure the face plate in place. If the face plate is pulled straight off, the plastic catch on the inside of the face plate might be damaged. Figure 4: Releasing the face plate from the right side of the HP all-in-onec00222496.gif 1 - Releasing the right side with a slight twisting motion
  6. Slide the face plate to the left until the plastic catch on the left side is not touching any part of the HP all-in-one, then pull the face plate away from the device. Figure 5: Removing the face plate from the HP all-in-onec00222497.gif 1 - Sliding the face plate to the left 2 - Pulling the face plate away from the HP all-in-one
Cleaning the rollers or separator pad Follow the steps below to clean the rollers or separator pad.
  1. Once the face plate of the ADF is removed, use the blue-green handle to lift the pick assembly. Figure 6: Blue/green handle and the pick assemblyc00222498.gif 1 - Blue-green handle 2 - Pick assembly This allows access to the rollers and the separator pad. Figure 7: The rollers and the separator padc00222499.gif 1 - Rollers 2 - Separator pad
  2. Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
  3. Use the damp cloth to wipe any residue off of the rollers or the separator pad.
  4. If the residue does not come off using distilled water, try using isopropyl (rubbing) alcohol.
  5. Use the blue-green handle to lower the pick assembly.
Reattaching the face plate of the ADF Follow the steps below to reattach the face plate to the front of the automatic document feeder.
  1. Hook the face plate onto the left side of the HP all-in-one so that the plastic catch on the far left inside of the face plate catches on the notch on the front of the automatic document feeder. Figure 8: Hooking the face plate into the left side of the HP all-in-onec00222500.gif 1 - Notch 2 - Plastic catch
  2. Line up the right edge of the face plate with the right side of the HP all-in-one, and then press on the right side of the face plate until it snaps securely into place. Figure 9: Snapping the face plate into the right side of the HP all-in-onec00222501.gif
  3. Place your hands towards the center of the face plate, and press until the center of the face plate snaps into place. You should hear two clicks; one when the left side snaps into place, and one when the right side snaps into place. Figure 10: Finishing re-attaching the face platec00222502.gif
  4. Close the cover of the automatic document feeder.
  5. If you removed the document feeder tray, reattach it.
Dec 07, 2010 | HP Officejet 7210 All-In-One InkJet...
HP Mini Touch Pad Right Mouse button auto click...
it may be a setting on the touchpad that you can set in control panel
Apr 24, 2010 | HP Mini 1000 Netbook
Toshiba a300 synaptic touch pad scroller stopped working
Hi there.
The touchpad drivers could be corrupt, try reinstalling the touchpad drivers again.
Go here to Toshiba Support fill in the details of your model laptop and download the synaptics touchpad driver and reinstall it, see if that helps.
http://uk.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=UK
Good luck and thanks for choosing FixYa!!
Jun 01, 2009 | HP Pavilion dv4000 Notebook
Hp laptop touchpad mouse problems
IF U HAVE REPLACED THE DRIVERS TO THE MOUSE DEVICE THIS INCLUDES ALL THE PROGRAMS THAT THE SITE HAS TO RUN THEM. THEN ITS A HARDWARE PROBLE IN WHICH THE ACTUAL CONTROL FOR THE MOUSE CAN BE REPLACED.
May 25, 2009 | HP Pavilion DV6700T Notebook
Hp touch pad keeps clicking like crazy....
Try the following steps...
1. First clean the touch pad with a dry cloth.
2. Disconnect the battery and the AC adapter and any other device that is connected to the NB and hold down the power button for 2 mins. This will drain the static.
3. Go to device manager and click on the + sign beside mice and other pointing devices, select synaptics / alps touch pad driver, right click on it and uninstall it. Now go to recovery manager > advance options > hardware driver installation > select the same driver and reinstall it.
This should fix it....
otherwise, go to hp.com/suppport and download the latest bios available.
you can also run a spyware scan if all the above steps do not work. go to www.filehippo.com and download antispyware program and run a scan.
Hope it helps..
Regards,
Anup
Apr 08, 2009 | HP Pavilion DV7-1023CL Notebook
Touch pad scrolling problem
Use alps one as well as check weather your touch pad is lock or not
Mar 14, 2009 | HP Pavilion dv4000 Notebook
Touch pad scroling up down problem
Try these links and update drivers Quick Launch Touch PAD
Hope this will help you
Thanks & Regards Nandu :)
Laptop Touchpad - cursor random dragging problem
On my acer all I have to do is press function F7, Function is the button with 'Fn' on it. I am not sure if that works for HP, but its worth a try. Also, is there a switch near the touchpad? Sometimes there is one that switches the touch pad on and off. You can also try other Fn(function) F1 or Fn F2 etc. and see if one of the other "f" buttons work.  I hope this helps, let me know how you made out. Good Luck!
Jan 16, 2009 | HP Compaq dc5700 Microtower - Free Flat...
Touchpad
You can go to the Control Panel (Select the start button and then either "Control Panel" or "Settings" and then "Control panel") and double click the Mouse properties icon.
Then you can select the "Device Select" tab and check the box marked "Disable Touch Pad when USB Pointing Device is present."
That is also where you can permantly disable the touch pad by simply selecting "Disable Device" and "Disable Button"
Hope that helps.
Jul 09, 2008 | HP Pavilion dv4155cl (EC321UA) PC Notebook
HP Pavilion dv4000 Notebook Logo
110 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
