Question about Whirlpool GEW9250 Electric Dryer
Drayer whirlpool control locked - Whirlpool GEW9250 Electric Dryer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To unlock the controls you
Posted on Sep 06, 2010
  • Rylee Smith
    Rylee Smith Sep 06, 2010
    Hi
    Thanks for using FixYa. To unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Drayer stops after a couple of min
You mean the Heat or the Motor turning the Drum?
Jan 17, 2013 | Whirlpool Dryers
Wat is code me68 in electry drayer frigidaire
You have a stuck button on the control panel try lightly tapping them with finger to see if it will unstick
Jan 20, 2011 | Frigidaire ATF6000ES Front Load Washer
My drayer heats up very slowly since one week .what could be the problem
sounds like it could be more than 1 problem 1 the heating element could be shorted and only running on a partial element 2 you could have a blocked exhaust vent and its not allowing the hot air to circulate properly
Jan 07, 2010 | Whirlpool Dryers
Whirlpool Gas Dryer (ggq9800pw1) - No Heat
You have a leak somewhere in your gas system, Either from the gas valve or some other tubing. In this situation unless you understand how it works I would recommend getting a tech out to look at your system. That way you know that it is being done properly.
Jan 02, 2010 | Whirlpool GGQ9800L Gas Dryer
WHAT IS 'CONTROL LOCK' ON THE WHIRLPOOL DUET
Control Lock is a designed safety feature that allows you to lock/unlock the control panel to prevent small children from manipulating the controls. To lock or unlock the control panel, click on the following link:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
If this does not fix your problem, please let me know. I hope this helps you.
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer dryer, Dryer is stuck on control lock
look to the far right buttons labled control lock, hold it in for 3-5 secs, to unlock
Mar 23, 2009 | Whirlpool ET8CHEXSQ Dryer
L G DRAYER , HEATER NOT WORKING
Had the same problem on a whirpool drayer. Get our multimeter and check which heat fuse is broken. Take that one out and throw it in the floor until you have conductivity again. Clean drayer vents and heater. This worked for me, good luck. http://www.youtube.com/watch?v=UuFQOuSlzlw
Nov 03, 2008 | LG DLE2532W Electric Dryer
Tumble dryer
Can be a few things. Start by resetting your circuit breaker. The dryer motor can run with partial power but the heating element cannot. Make sure your not set to a no heat setting. After those checks you have to get into the mchine to check your heating element and thermostats.
Apr 12, 2008 | Whirlpool LER5636P Electric Dryer
Drayer working but no heat
No heat may mean that one side of the 240 volt circuit breaker is tripped or one fuse of the 240v circuit at the fuse/breaker box is tripped. Just replace/reset the fuse or breaker which ever you have.
Dryers will have controls working but not heat if it happens to be that particular side of the 240v circuit that tripped or fuse burned.
Jan 30, 2008 | Dryers
Whirlpool GEW9250 Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
