Question about HP PSC 2355 All-In-One InkJet Printer
Can I print with card stock paper? - HP PSC 2355 All-In-One InkJet Printer
  • 111 Answers
SOURCE: paper jam
Not all printers support all paper types. Sometimes you'll get a jam because the paper you want to use isn't supported by your product. The HP.com site has a web page that describes how to diagnose paper jam problems.
Paper Jam page
On that page, scroll down to Step 6 where it talks about checking the paper size and type settings and see if that helps.
You can also review the paper size and type specifications for your printer to make sure the paper you are using is supported.
Product Specifications
Scroll down to the Paper specifications section of the page to compare what's listed there with the paper types you are trying to use.
Hope this helps. Good luck.
Posted on Oct 10, 2008
Dipu007
  • 2110 Answers
SOURCE: when i go to print
I think ur printer doesnot support this size ...
Posted on Nov 29, 2008
  • 105 Answers
SOURCE: Will this printer print on heavy card stock and
Yes the 2600 will print on heavy card stock and vellum paper. I had one and did some landscape proposals on this printer and also printed on card stock as well.
Posted on Oct 17, 2009
  • 82 Answers
SOURCE: I AM TRYING TO PRINT HEAVY STOCK CHRISTMAS CARDS -
If its heavier than 60 to 105 gsm (16 to 28 lb), then your printer can not take that type.
HP Specifications
Unless there is a manual feed on the back, the paper won't be able to bend well inside of the printer, hence the jam.
Posted on Nov 29, 2009
LHeruska
  • 94 Answers
SOURCE: Printer streaks on card stock
adjust your thickness guage as card stock is 3 or 4 times thicker than a 20lb plain paper stock. Here is link to a helpful media guide for HP printers.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/bpl05339/bpl05339.pdf
Posted on Jan 30, 2010
Testimonial: "Thanks. It looks good but I'll need to study it."
I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock...
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
Mar 19, 2011 | Office Equipment & Supplies
I wish to use my HP Photosmart C8180 to print heavy weight cardstock... is there a setting that I can select to do this?
Step Three: Check the paper type Verify that only recommended paper is being used for printing. The recommended paper types and weights for most HP printers include:
  • Plain paper, 20 to 24 lb (75 to 90 gsm)
  • Legal size paper, 20 to 24 lb (75 to 90 gsm)
  • Card stock, up to a maximum of 110 lb (200 gsm)
  • Envelopes, 20 to 24 lb (75 to 90 gsm)
  • Photo paper, 145 lb (236 gsm)
NOTE: Supported paper weights and types vary by product. Check the Specifications sheet for your product for more information.
If you use card stock up to a maximum of 110lb then there should be no special mode to enter to print on this type of paper. Photo paper weighs in at 145 lb maximum which is heavier and can be printed on without selecting any special 'mode.'
Good luck on printing on heavy card stock.
Jan 21, 2011 | HP Photosmart C8180 InkJet Printer
Paper jams with card stock
Lubricate the print head shaft. Not too much as it will collect dust.
May 04, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
Jan 30, 2010 | HP Color LaserJet 2600n Printer
Oct 17, 2009 | HP Color LaserJet 2600n Printer
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Jan 26, 2009 | Computers & Internet
    HP C4280 incorrect paper feed
    Check your printer's capability.
    Buy the card stock they recommend.
    If all else fails, print on plain and take card stock to a copy shop and have them do it for you.
    Walking there beats going nuts over stupid software or hardware problems
    Dec 16, 2008 | HP PhotoSmart C4280 Laser Printer
    Blinking yellow light
    I m not sure what the specification of the paper type you are using however if you are using card stock than you should use manual feed Tray and in the printer driver properties you should select paper type as Card-Stock to make sure there is no print quality issue.
    Nov 30, 2008 | HP Color LaserJet 2550n printer + HP Color...
    Paper keeps jamming
    To print card stock you must us the manual slot in the front of the printer and feed one at a time. Also open the back flap door so the card stock can exit out the back instead of trying to bend around for the try. That will give you the staight paper path that your thick stock needs.
    Jul 08, 2008 | Brother HL 1440 Laser Printer
    HP PSC 2355 All-In-One InkJet Printer Logo
    54 people viewed this question
    Seeker5211
    Seeker5211
